Auto-expanded drop-downs when a page loads (RH8)
Participant ,
Apr 28, 2010 Apr 28, 2010
I'm not sure if this is possible, but can anyone tell me how to make DHTML drop-downs automatically display as expanded when a page loads?
Many thanks
Jonathan
1.7K
That kind of defeats the purpose of dropdowns, don't you think? You can write a javascript to show all the dropdowns on load.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
Participant ,
I know what you're saying and it is an odd request, but for my release notes it would be useful to show every category by default but allow the user to collapse the ones they are not so interested in.
Jonathan
Apr 30, 2010 Apr 30, 2010
You can use the following script:
setTimeout("ExpandAll()", 1);
function ExpandAll()
    var links = document.getElementsByTagName('a');
    for(var i in links)
        if(links.className == "dropspot" || links.className == "expandspot")
            TextPopup(links)
Put it in your topic, or in a separate script file that you link to the topics. This script cycles through the hyperlinks in the topic and when the link is a dropdown or expandtext link, the script expands the dropdown/expandspot.
Greet,
Willam
Participant ,
May 04, 2010 May 04, 2010
Willam, thanks for that. I tried it with the script in my page and a linked .js file, but it didn't work.
Does it work for you?
Cheers
Jonathan
It worked on my test project... Does the script work when you insert it into the topic itself? If not, please share an example topic so I can have a look. If it works, I'll amend the script.
Using the ShowHide script is also a good idea, but requires the user to click before all content is displayed. You can amend that script to work on page load.
Greet,
Willam
Participant ,
Here's my test page:
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="generator" content="Adobe RoboHelp 8" />
<title>New Topic</title>
<link rel="StyleSheet" href="RHStyleMapping.css" type="text/css" />
<script type="text/javascript" language="JavaScript1.2">//<![CDATA[
+setTimeout("ExpandAll()", 1);
    for(var i in links)
            TextPopup(links)
//]]></script>
</head>
<body>
<?rh-script_start ?><script src="ehlpdhtm.js" type="text/javascript" language="JavaScript1.2"></script><?rh-script_end ?>
<h1>Title</h1>
<p><a class="dropspot" href="javascript:TextPopup(this)" id="a1">Drop1</a></p>
<div class="droptext" id="POPUP253491555" style="display: none;">
<p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam
  nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat
  volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation
  ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat.
  Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse
  molestie consequat, vel illum dolore eu feugiat nulla facilisis at
  vero eros et accumsan et iusto odio dignissim qui blandit praesent
  luptatum zzril delenit augue duis dolore te feugait nulla facilisi.</p>
</div>
<p><a class="dropspot" href="javascript:TextPopup(this)" id="a2">Drop2</a></p>
<div class="droptext" id="POPUP253472254" style="display: none;">
<p>Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper
  suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem
  vel eum iriure dolor in hendrerit in vulputate velit esse molestie
  consequat, vel illum dolore eu feugiat nulla facilisis at vero eros
  et accumsan et iusto odio dignissim qui blandit praesent luptatum
  zzril delenit augue duis dolore te feugait nulla facilisi. Lorem ipsum
  dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh
  euismod tincidunt ut laoreet dolore magna aliquam erat volutpat.</p>
</div>
<p><a class="dropspot" href="javascript:TextPopup(this)" id="a3">Drop3</a></p>
<div class="droptext" id="POPUP253509108" style="display: none;">
<p>Duis autem vel eum iriure dolor in hendrerit in vulputate velit
  esse molestie consequat, vel illum dolore eu feugiat nulla facilisis
  at vero eros et accumsan et iusto odio dignissim qui blandit praesent
  ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat.</p>
</div>
<?rh-script_start ?><script type="text/javascript" language="JavaScript1.2">//<![CDATA[
if( typeof( TextPopupInit ) != 'function' ) TextPopupInit = new Function();
TextPopupInit('a1', 'POPUP253491555');
TextPopupInit('a2', 'POPUP253472254');
TextPopupInit('a3', 'POPUP253509108');
//]]></script><?rh-script_end ?>
</body>
</html>
May 05, 2010 May 05, 2010
The script works for me in WebHelp. You can increase the timeout if you have problems in WebHelp (1 means one thousand of a second). Increase to fix your problems.
If you're using CHM, the script doesn't work. (I normally don't test on CHM ).
The following script works for WebHelp and CHM:
    var divs = document.getElementsByTagName('div');
    for(var i in divs)
        if(divs.className == "droptext")
           divs.style.display = "";
Set the timeout for WebHelp to 200. 1 is fine for CHM.
Greet,
Willam
Participant ,
Hi Willam, thanks again, but I'm still getting the following script error when I preview my page in WebHelp, even with the timeout set to 200.
Participant ,
Willam, it works fine if I remove the "+" symbol from the start and end of your script. I wasn't sure if this was part of the script or not, so I included it anyway.
Thanks for all your help!
Jonathan
OK. Glad this one works.
Greet,
Willam
Jul 16, 2013 Jul 16, 2013
I wanted to reopen this, as I am trying to use the script to make glossary entried display opened. To answer the pretty obvious question of why, the project is a data dictionary, and it seems easiest to use a glossary entry for field definitions, allowing me to write/edit once and use many times, as the same definitions can appear in lists in multiple topics. Otherwise I would use tables.
I used the script you provided, and it works, but only on the first link in my topic. I am not much for javascript and suspect that I need to wrap code around each link on the page, which may make the whole idea too time intensive.
At any rate, here is a bit of the code as I used it:
<title>Topic Title</title>
<link rel="StyleSheet" href="default.css" type="text/css" />
</head>
setTimeout("ExpandAll()", 200);
    for(var i in links)
        if(links.className == "glossterm" || links.className == "expandspot")
            TextPopup(links)
//]]></script>
<body>
<h1>Topic Head tab</h1>
<p>this is the description of what the tab does. Primary fields include:</p>
<p id="p1"><?rh-glo_start class="glossterm"?>Definition 1<?rh-glo_end ?></p>
<p id="p2"><?rh-glo_start class="glossterm"?>Definition 2<?rh-glo_end ?></p>
<p id="p3"><?rh-glo_start class="glossterm"?>Definition 3<?rh-glo_end ?></p>
I am using WebHelp. As I mentioned, Definition 1 displays with the expanding hotspot definition showing when the topic loads, as I would like. The others do not.
Jul 17, 2013 Jul 17, 2013
Try this method: http://www.wvanweelden.eu/blog/2012/08/03/expand-drop-downs-default
It's one that should work much better. (Since I now now much more about RH internals than in 2010.)
Please post back if it doesn't work.
Greet,
Willam
Thank you, Willam. Your referenced script works perfectly.
Collin
Jul 18, 2013 Jul 18, 2013
Great. Thanks for letting me know.
Greet,
Willam
I'm curious as to why you are using dropdowns when you want the content automatically displayed?
I have seen people want a single dropdown expanded when the link is from another topic and the target content is in a dropdown but you haven't said that is the requirement here.
@petergrainge
Participant ,
I want my content to be displayed by default so that it can be read from start to finish, but I also want to give my readers the choice of collapsing sections they're not interested in, as some will be quite long. I know I could alternatively use standard dropdowns and let my readers open the sections they want to read, but someone wanting to read everything would have to manually open them all or I'd have to include your Show/Hide All script.
This seemed like a good idea last week, but I may change my mind!
Regards
Jonathan
RoboHelp Documentation
Download Adobe RoboHelp
