I'm recording in FMR and when I go to preview my recording I recieve a blank screen...using Preview; From this slide or Next five slides. The only way I can preview is to publish the project or in the browser. Can anyone point my in the right direction to fix the problem...thanks in advance.
And your version of Captivate is?
If it's version 3, have you looked at this?
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hey Rick,
Thanks so much...my Captivate 3 "Preview" works now. I removed the Adobe Flash Player 10 and reinstalled Adobe Flash Player 9 however when I go to the "Control Panel" the "Flash Player 9" doesn't show up although the "Adobe Flash Player ActiveX" appears (not sure why but it works).
I also need to do 10 - 20 minutes sessions of live recordings and I was wondering if there is a better software for live recordings which can be easily edited.
QB Accountants, Inc.
Brent Ervin, ABA
Advance Certified QuickBooks Pro Advisor
Certified QuickBooks Enterprise Pro Advisor
qb-accountants.com
Hi Brent
You can *TRY* using Captivate in Full Motion Recording (FMR) mode for this. However, it won't be optimal. While this mode of recording is certainly possible, it's far from being really user friendly and easy to edit. Sure, Captivate offers some limited editing tools that allow you to slice, dice and splice, but that's about it.
If you are serious about recording full motion, check out something like TechSmith's Camtasia Studio. Actually, it's helpful to have both Camtasia as well as Captivate in your toolbox so that they may complement each other.
Cheers... Rick
Rick,
Thanks so much. I will check it out.
Brent Ervin, ABA
qb-accountants.com
Ph: 815-215-8151
Fx: 815-215-8158
Please be advised that, under current IRS rules and standards, any advice contained herein is not intended to be used, and cannot be used by any taxpayer, for the purpose of avoiding penalties that may be imposed on the taxpayer by the IRS. Any information contained in this email does not fall under the guidelines of IRS Circular 230.
The information contained in this message is privileged and confidential information intended for the use of the individual or entity named above. If the reader of this message is not the intended recipient, or the employee or agent responsible to deliver it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this message in error, please immediately notify us by telephone, and return the original message to us at the above address.
