Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Import comments (XFDF) to a PDF document
Avatar
Level 2
Hi all,
I have a LiveCycle ES2 process where I would like to import comments (available as an XFDF String/Document) to an existing PDF File (flat).
I have already tried the FormDataIntegration.importData service, but without success. The comments do not appear on the PDF file.
Could anybody advise how this is possible?
Thanks in advance!
Paul
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Comments are not considered data so importData is not what you want. In the Assembler service you can invoke a DDX set of instructions that will allow the impoort of comments.
Paul
Avatar
Correct answer by
Paul
Avatar
Level 2
Yes right this should do it.
Thanks for the response!
Paul
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
