SOLVED
Unable to use Workspace from MACBOOK ???
Avatar
Level 10
I am able to connect to the ES2 workspace but unable to open the forms.
When I click on the process card, it show that "the adobe reader is not installed. would you like to install"??
I am sure that the MAC has Reader 9.3
Can someone suggest what could be the reason of not detecting the installed reader?
I tried to connect from several MACs but no luck. Please help.
Nith
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Hi Nith,
Try doing a "Get Info" on Safari and selecting "Open in 32-bit mode".
Avatar
Correct answer by
Hi Nith,
Avatar
Level 10
Thanks Dude,
It worked after changing it to 32 bit mode.
Nith
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
