I m designing a process which has two web services (adobe livecycle workbench) I can get respond from each of them but that means I have two xmls.
The problem starts from here .I need one document put into pdf however I have two Documents, one from each web service
ı just need to equal two xml to one xml that case I can have one document to put into renderPDFfrom process
what should I do ?
should I put another process to combine xml or is there any methods to combine xml
I m waiting for your answers
thanks for helping
Total Likes
You can use xpath to set xml nodes. For example if you have the following structures:
<RootA>
<Parent1>
<Child1/>
<Child2/>
<Child3/>
</Parent1>
</RootA>
<RootB>
<Parent1>
<Child1/>
<Child2/>
<Child3/>
</Parent1>
</RootB>
<Main>
<Node1/>
<Child1/>
<Child2/>
<Node1/>
</Main
You could store them in xmlvar1,xmlvar2 and mainxml, then you could combine them into one using xPath with something similar to
/process_data/mainxml/Main/Node1/Child1 = /process_data/xmlvar1/RootA
/process_data/mainxml/Main/Node1/Child2 = /process_data/xmlvar1/RootB
Jasmin
thank you very much Jasmin your answer is brilliant but in my case When I put "Main" between Node1 and mainxml (not really "Main" in my case form1) it doesnt work correctly /process_data/mainxml/Main/Node1/Child
this is my code and also another problem
/process_data/wstranslatesum/Page1/tablo1 = /process_data/wsresponse2/Envelope/Body/HelloWorldResponse/HelloWorldResult/diffgram/NewDataSet
/process_data/wstranslatesum/Page2/Sonuc = /process_data/wsresponse/Envelope/Body/getMaxWaitingProcessStepsResponse/getMaxWaitingProcessStepsResult/diffgram/NewDataSet
when I use above example only
above part works they are on the other page
when I use the below
/process_data/wstranslatesum/Page2/tablo1 = /process_data/wsresponse2/Envelope/Body/HelloWorldResponse/HelloWorldResult/diffgram/NewDataSet
it works perfectly (did you notice that they are on the same page)
so what is the problem I know you are Expert
can youy recommend any resource which has real case example
thank you so much
Sincerely ,
Joseph
Total Likes
I solved the problem. the problem is I missed the hierarchy . the second table was not under the second subform that s why it didn t work
anyway thanks a lot
Total Likes
