Dealing with UTF-16 form input with CF5
Guest
Jan 20, 2009 Jan 20, 2009
Hello, this question is for veteran 😉
Sometimes accented characters entered in a textarea field are replaced with strange characters when recorded in my MS Access memo field, For exemple "©" instead of “é”.
For debugging purpose, I used CFFile to record the same field value in a .txt file. When open with notepad, the accented characters are displayed correctly, but the HEX values contained in the file seem to indicate UTF-16 Little Indian. The file start with "FF FE" and the other characters have the form "XX 00".
Considering I’m with CF5 and it can’t be upgraded, my question is:
Is there a way (with CF5) that I can prevent the field to contain anything else that ISO-8859-1?
By parsing the characters? Using Access? Any other ideas?
I have this tag to set the encoding of the form page:
<cfcontent type="text/html; charset=ISO-8859-1" reset="yes">
Advanced techniques
505
> instead of ?�?.
cf5 doesn't know charsets from a hole in the ground so there's not much you can do.
if you don't care at all about those chars, just strip out any chars w/code
point values > 256. otherwise something like this:
http://www.cflib.org/index.cfm?event=page.udfbyid&udfid=725
Guest
Jan 21, 2009 Jan 21, 2009
Hello,
Thanks for your reply. I tried Demorozine, on reading file, database field or before saving the field but without result.
You’re suggesting to “just strip out any chars w/code point values > 256”.
How would you do that?
what does that mean?
can we see the data? is there a public site i can look at?
Guest
Jan 22, 2009 Jan 22, 2009
Thanks guys, I partially found the source of the problem: It's because i'm using javascript (jQuery) to post the form (AJAX). Using LiveHTTPheaders, I noticed that the post actually occurs in UTF-8 instead of ISO-8859-1, despite that the page is explicitly set in ISO-8859-1.
Anybody found a way to deal with this problem?
According to a friend, it's unavoidable. He suggest to encode the string in HEX with a function, and then decode back on the server side.
I'm just thinking that I can't be the only one to have that problem! ;-)
Check out this link; note that I think it was written for CF8 so you may have to do some downgrading in the script (I didn't review the whole thing myself)
http://www.bennadel.com/blog/1155-Cleaning-High-Ascii-Values-For-Web-Safeness-In-ColdFusion.htm
Documentation
