2 Replies Latest reply on Apr 30, 2010 6:16 AM by mrinmoy1984
    How to convert textframe to button
    mrinmoy1984
      How to convert textframe to button?
        • 1. Re: How to convert textframe to button
          Marc Autret Level 5
          I didn't find a 'clean' way to do this through the DOM. As a workaround you can emulate a "Convert to button" action, provided your script is allowed to select the textframe target:
          // convertToButton for ID CS4
          function convertToButton(/*PageItem*/obj, /*str*/bName, /*str*/bDesc)
               app.selection = [obj];
               var maCreateButton = app.menuActions.item('$ID/$$$/Dialog/CmdName/CreateButton'),
                    ret;
               if( !maCreateButton.isValid ) return false;
               maCreateButton.invoke();
               ret = app.selection[0];
               ret.name = bName||ret.name;
               ret.description = bDesc||ret.description;
               return ret;
          // sample code
          var myTextFrame = app.activeDocument.textFrames[0];
          var myButton = convertToButton(myTextFrame);
          Note: this approach is used in FlyingButtons:
          http://www.indiscripts.com/post/2010/03/flyingbuttons-a-script-to-automate-pdf-portfolios
          Marc
          1 person found this helpful
          • 2. Re: How to convert textframe to button
            mrinmoy1984 Level 1
            Thanks mark,
            It's working. I've also tried to do it from DOM. But failed to find appropriate method. Thanks again!!!!
