Hi all,
I've installed Coldfusion Builder over a FlashBuilder Eclipse instance, but i've code highlight issue..
Sometimes the code is correctly highlighted, sometimes not..and i don't know what's happen.
Is it a known issue ? Is there anybody here that get the same ?
Thanks a lot guys !
Francois
I have the same problem.
If a tag have a #variable# or a <cfif> embedded at the end of the taf, the highlight is not performed for the end of the file.
Examples :
<cfset disabled = 'disabled'>
<input type="text" name="foo" #disabled#> <!--- bad --->
<input #disabled# type="text" name="foo"> <!--- good --->
<input type="text" name="foo" > <!--- bad --->
<input <cfif ...>disabled</cfif> type="text" name="foo"> <!--- good --->
Hope this help !
Nops, i don't use any # # statements cause i'm developping CFC for AMF Communication with flex...
So your example don't work in my case.
When i said previously that the highlights worked fine sometimes and sometimes not, it's not inside the same script.. but from script to script..
I've noticed that when i have some cfc documents openned , close Flash Builder and re open it, the hightlights work , but when i try to open other cfc documents.. no highlights ! It is weird ..
I've installed Coldfusion Builder Update 1 without any changes..
Any solutionwould be great !
François
Hi back,
still have the same issue related to coldfusion syntax highlight ?
Any help would be nice !
thanks
Francois
Issue Fixed !
I had to execute Flash Builder as "Administrator" and all Coldfusion Builder features are now successfully functional...
Help the will help some guys here
EDIT : I had to create a super admin in order to not have to execute "as" admin ... and it works fine now !
Francois,
Was this on Windows or on another OS? My boss is having the same problem on a Windows 7 64-bit machine - Helios Install of Eclipse - The CF Builder plugin will only colour the code correctly when a file is left open from a previous session
Regards
Joanne
Joanne,
I've have the same problem with the same setup. Were you able to find a resolution?
Ted
FYI, I found that my problem was related to trying to run builder in 64 bit eclipse:
