Show 4 replies
1. Re: How to export the Word import preset to work in other systems?
P Spier May 3, 2010 5:25 AM (in response to Praveen10)Inthe import options dialog there is a save preset button. This will write a .smp file into your user profile in a "Word Import Presets" subfolder. The location of this file will vary silghtly with OS, but it should be a subfolder in the same path as the InDesign Defaults file, and you'll find a list of the locations where that's located in this topic: Replace Your Preferences
2. Re: How to export the Word import preset to work in other systems?
Praveen10 May 3, 2010 5:50 AM (in response to P Spier)Thanks Peter, it's working fine. So I need to copy this SMP file and place this file in the same like location in other systems to use the same settings, isn't it?
Praveen
3. Re: How to export the Word import preset to work in other systems?
P Spier May 3, 2010 5:55 AM (in response to Praveen10)I've not done so, but I presume this would work.
4. Re: How to export the Word import preset to work in other systems?
Praveen10 May 3, 2010 6:10 AM (in response to P Spier)I checked and found working fine.
Thanks again.
Praveen
