My spanking new After Effects CS5 won't launch due to "Unable to create font" error.
I'm running OS X 10.6.3 on a 17" with specs listed below.
After Effects CS3 is running fine. What's the solution?
Model Name: MacBook Pro
Model Identifier: MacBookPro5,2
Processor Name: Intel Core 2 Duo
Processor Speed: 3.06 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 8 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP52.008E.B05
SMC Version (system): 1.42f4
Serial Number (system): W89400R18YB
Hardware UUID: E2300327-D5D3-5DC2-85CF-9FFA9CEAD9ED
Sudden Motion Sensor:
State: Enabled
This bug is fixed in the After Effects CC (12.1) update:
http://adobe.ly/AE_CC_12dot1_details
Let us know how this works for when you've tried with the new update.
Start with the solutions listed here:
http://aeerrors.myleniumstuff.de/?p=482
Same for me, I'm trying a lot of things but nothing work – I keep checking and let you know If I've got a solution
There are 3 possible issues on the system. A corrupt font, a corrupt Adobe font list and/or a corrupt system font database.
Try the following:
1) On the Mac, delete all copies of the AdobeFnt.lst on the system. They will have a name like AdobeFnt10.lst, AdobeFnt11.lst, etc.. On the Mac this will be found in the /Library/Application Support/Adobe/PDFL/9.0/Fonts folder.
2) Then restart the system holding down the S key while the system is starting up for Safe Mode. That will reset the system database.
On Windows,
1) search and delete the AdobeFnt.lst files found in C:\Program Files\Common Files\Adobe\PDFL\...,
2) restart the system.
Hi Will,
I did all that but nothing fixed the problems. Finally, I'm suspecting a corrupted drive. When I fix the drive with fsck command it gets corrupted after each system launch. I plan to clone my system on another drive, boot from the new one, check if everything is ok. I let you know.
Bummer. Sorry to hear that. Let us know how this works out.
Hi Will
I posted a solution that works for me.
I tried this soln ..and it's worked finally
The After Effects CS5 (10.0.1) update should fix this problem.
For me the Adobe update *DID NOT* fix this but copying over and activating the Veranda family of fonts from my MBP that had Office on it, did - kind of a sorry situation if this is what's actually needed to fix it but at least there is a way.
And a March 2011 download of the Master Collection & update to 10.0.1 (everything that updates) reveals that the same issue still exists. Installing Verdana "fixes" it. <font family="Verdana">Idiots.</font>
I updated to the current after effects and I am still getting this problem. I have homework to finish today. Please help! 🙂
I went into type book and activated verdana in computer and inactivated verdana in user. It worked.
Finally I found the solution, I don't know if it's gonna work for you, but you should give it a try. After hours of troubleshooting, I found that a missing Verdana Fonts (version 1.0 from Microsoft) is causing the problem. Just put Verdana in YourHardDrive/Library/Fonts and AfterEffects CS5 should start normally. It would be cool to have a better dialog box like "Unable to create font - please locate and Install Verdana".
For your convenience, you can download Verdana here : [removed by moderator, since Verdana is not a freely distributable font]
Enjoy
After Effects Warning Unable To Create Font
Thanks that works perfect.
Verdana, Typeface and data © 1996 Microsoft Corporation. All Rights Reserved Version 2.45 - Thursday, 8 April 2004 08:00
your link to the font is gone. (sigh).
could you reupload, please?
Hi Karolus,
The link is now working, enjoy...
[removed by moderator]
Worked the first time! Thanks for the link too!
Thank you!!! This totally worked for me!!
Just want to add that this worked for me. But it didn't at first. I moved Verdana to the right place but it did not work. The problem was that you need all the files. I had them all but not "Verdana Italic.ttf" for som reason. I had to get that from a disc and then it worked. So make sure you get them all to /Library/Fonts/.
Verdana Bold Italic.ttf
Verdana Bold.ttf
Verdana Italic.ttf
Verdana.ttf
And now for something completely different:
I was having this problem and I went to the Fonts folder and saw that Verdana was there! Just for giggles, I went ahead and dragged the font out of the folder and, yes, After Effects worked just fine for me afterwards!
I'm running a 2.66 GHz Intel Core 2 Duo iMac on 10.6.8, but this problem also reared its ugly head when I was running 10.5.
You can buy Verdana font from Microsoft site for 30$ (aamof from Ascender Corporation). It's not legal to download it from above links (unless this guy have license for sharing this font, and I doubt about that). It is laughing because after you spend 999$ for a software, you have to pay 30$ more for the fonts. Did Adobe have no money for licensing this font?
Oooops, I was sure Verdana was free. Sorry folks, you'll have to buy that font or find it in another way (try installing Office 2008 trial...). We live in a strange world full of contradictions.
I had the same problem. Also after updating AE. But this worked for me:
Activate the verdana font in your system Fontbook (dutch: Lettertypecatalogus).
(Suitcase Fusion 3 turned it off)
Grtz,
Code d'Azur
The Verdana trick worked for me too. AE’s type engine fails if there isn’t a font at /Library/Fonts/Verdana.ttf —common, simple programming problem. Mahalo for posting all this, guys!
