Greeting
I have download the trial version of CF Builder and have CF 9 Dev Edition on my XP SP3. I also have Dreamweaver CS4 installed. Dreamweaver can talk to CF through RDS however, CF Builder does not. I get a 503 error. Yes, the service is running. Any thoughts?
More info:
I set CF Builder to auto start and auto stop CF 9. Here is want appears in the Console window during start up:
[localhost]:Starting Macromedia JRun 4.0 (Build 108795), coldfusion server
[localhost]:These changes should get picked up!
[localhost]:22/04 10:54:31 warning Unable to open C:\ColdFusion9\runtime/lib/license.properties
[localhost]:22/04 10:54:32 info JRun Naming Service listening on *:2932
[localhost]:22/04 10:54:34 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
[localhost]:22/04 10:54:34 info JRun Web Server listening on *:8500
[localhost]:22/04 10:54:34 info Deploying enterprise application "Adobe_ColdFusion_9" from: file:/C:/ColdFusion9/
[localhost]:22/04 10:54:35 info Deploying web application "Adobe ColdFusion 9" from: file:/C:/ColdFusion9/
[localhost]:22/04 10:54:38 INFO License Service: Flex 1.5 CF Edition enabled
[localhost]:22/04 10:54:38 INFO Starting Flex 1.5 CF Edition
[localhost]:22/04 10:54:38 user JSPServlet: init
[localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: init
[localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: ColdFusion: Starting application services
[localhost]:22/04 10:54:39 user ColdFusionStartUpServlet: ColdFusion: VM version = 14.0-b16
[localhost]:04/22 10:54:39 Information [main] - Starting logging...
[localhost]:04/22 10:54:39 Information [main] - Starting license...
[localhost]:04/22 10:54:43 Information [main] - Invalid ColdFusion 9 license.
[localhost]:04/22 10:54:43 Information [main] - Developer Edition enabled
[localhost]:04/22 10:54:43 Information [main] - Starting crypto...
[localhost]:04/22 10:54:43 Information [main] - Installed JSafe JCE provider: Version 3.6 RSA Security Inc. Crypto-J JCE Security Provider (implements RSA, DSA, Diffie-Hellman, AES, DES, Triple DES, DESX, RC2, RC4, RC5, PBE, MD2, MD5, RIPEMD160, SHA1, SHA224, SHA256, SHA384, SHA512, HMAC-MD5, HMAC-RIPEMD160, HMAC-SHA1, HMAC-SHA224, HMAC-SHA256, HMAC-SHA384, HMAC-SHA512)
[localhost]:04/22 10:54:43 Information [main] - Starting security...
[localhost]:04/22 10:54:44 Information [main] - Starting scheduler...
[localhost]:04/22 10:54:44 Information [main] - Starting WatchService...
[localhost]:04/22 10:54:44 Information [main] - Starting debugging...
[localhost]:04/22 10:54:44 Information [main] - Starting sql...
[localhost]:04/22 10:54:44 Information [main] - Pool Manager Started
[localhost]:04/22 10:54:44 Information [main] - Starting mail...
[localhost]:04/22 10:54:44 Information [main] - Starting runtime...
[localhost]:04/22 10:54:44 [main] INFO Using "C:\DOCUME~1\rbakker\LOCALS~1\Temp\vfs_cache" as temporary files store.
[localhost]:04/22 10:54:44 Information [main] - CORBA Configuration not enabled
[localhost]:04/22 10:54:44 Information [main] - Starting cron...
[localhost]:04/22 10:54:44 Information [main] - Starting registry...
[localhost]:04/22 10:54:45 Information [main] - Starting client...
[localhost]:04/22 10:54:46 Information [main] - Starting xmlrpc...
[localhost]:04/22 10:54:47 Information [main] - Starting graphing...
[localhost]:04/22 10:54:47 Information [main] - Starting verity...
[localhost]:04/22 10:54:47 Information [main] - Starting solr...
[localhost]:04/22 10:54:47 Information [main] - Starting archive...
[localhost]:04/22 10:54:47 Information [main] - Starting document...
[localhost]:04/22 10:54:47 Information [main] - Starting eventgateway...
[localhost]:04/22 10:54:47 Information [main] - Starting Event Backend Handlers.
[localhost]:04/22 10:54:47 Information [main] - Initialized EventRequestDispatcher with a Thread Pool size of 1.
[localhost]:04/22 10:54:47 Information [main] - Initializing EventRequestHandler
[localhost]:04/22 10:54:47 Information [main] - Starting Event Gateways.
[localhost]:04/22 10:54:47 Information [main] - Starting FlexAssembler...
[localhost]:04/22 10:54:47 Information [main] - Starting .NET...
[localhost]:04/22 10:54:47 Information [main] - Starting Monitoring...
[localhost]:04/22 10:54:47 Information [main] - ColdFusion started
[localhost]:22/04 10:54:47 user ColdFusionStartUpServlet: ColdFusion: application services are now available
[localhost]:22/04 10:54:47 user CFMxmlServlet: init
[localhost]:22/04 10:54:47 INFO Macromedia Flex Build: 87315.134646
[localhost]:22/04 10:54:47 user CFMxmlServlet: Macromedia Flex Build: 87315.134646
[localhost]:22/04 10:54:50 user CFSwfServlet: init
[localhost]:22/04 10:54:50 user CFCServlet: init
[localhost]:22/04 10:54:51 user FlashGateway: init
[localhost]:22/04 10:54:51 user MessageBrokerServlet: init
[localhost]:22/04 10:54:52 user CFFormGateway: init
[localhost]:22/04 10:54:52 user CFInternalServlet: init
[localhost]:22/04 10:54:53 user WSRPProducer: init
[localhost]:22/04 10:54:53 user ServerCFCServlet: init
[localhost]:Server coldfusion ready (startup time: 26 seconds)
[localhost]:Error(04/22 at 10:57:24) Unable to start server. Server startup timed out.
[localhost]:Error(04/22 at 10:57:29) Operation is canceled.
It seems to fail when it is trying initialize the RDSServlet. Any thoughts? Wrong version of Java?
I am having the same issue on Windows 7. Dreamweaver connects to RDS without error but CFB doesn't.
I brought my laptop home and found I was able to connect to my localhost via RDS. I turned off my proxy/network filter server and it worked perfectly. Are you woking on a standalone pc/laptop or one that is on a network?
Hope that helps.
Hi Ray,
Thanks for the reply!
I am on a standalone pc, so i don't know how a proxy/network filter would come into play.
Where do I find those settings?
Thanks again!
Thin White Duke
Sorry, I suspect that our Group Policy had something to do with restricting the start up of the RDS Servlet. Maybe something in your firewall/router software? I have not had a chance to talk to our network people yet.
In IE - tools > internet options > Connections (tab) > LAN settings (button) > Proxy server ( uncheck)
I hope that helps.
