Hello!
I just install CFBuilder and get an a error 147:20. Next I had been done all steps in this KB, but get the same error.
What I'm doing wrong?
P.S.: And after this KB I have same error.
Can you please let me know your system language?Is it a non-english or non-japanese language?
And can you also please tell us your OS?
Do you have "FLEXnet Licensing Service" created under services?
If not please create manually as follows:
>sc create "FLEXnet Licensing Service" binPath= "C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe"
Then try launching CF Builder.
If you still get the license error,
download the license recovery tool at: http://www.adobe.com/support/contact/licensing.html
Run the LicenseRecover.exe from the command and follow the on-screen instructions.
Once this is done launch CF Builder.
Hope this resolves your issue.
Krishna
Hello, Krishna!
I did all the steps and still, I have error when start CFBuilder - now error 147:21.
My system - Windows 7 Ultimate, system language - russian.
Are you able to start the Flexnet License service from the services manually?
If you have run the LicenseRecover tool, can you please give the result that appeared on the screen?
Though Russian OS is not officially supported, still hoping to help you to make it work for you.
Krishna
When I run the utility, choose the language and agree to the terms, the program almost immediately closes and I do not have time to see that show.
Close the CF Builder.
And then while running the utility, the sequence of inputs from you are:
1. e
2. n
3. then press enter key
You will see the result on the command prompt window ...
Krishna
Thank you, Krishna!
Now works fine.
