cannot install adobe after effects cs5 {64 bit problem}(on vista)
May 03, 2010 May 03, 2010
hi i have a problem with installing adobe after effects it says somthing about 64 bit but i have a vista laptop {windows vista home premium acer laptop}
plz help me!!!
54.9K
Are you running a 32-bit or 64-bit version of Windows?
http://support.microsoft.com/kb/827218
After Effects CS5 can't be installed or used on a 32-bit operating system.
aa crap sorry for my language but i have 32 bit cant i have adobe after effects annymore ?
plz do you have a solution
> i have 32 bit cant i have adobe after effects annymore ?plz do you have a solution
Upgrade to a 64-bit operating system. Trust me: it's worth it.
You can still use After Effects CS4 in the meantime.
well i dont know mutch of techno things but how can i upgrade to 64 bit and
how must i download cs4
That's a question for Microsoft, the folks who will sell you a new 64-bit operating system. You'll want to make sure that your computer hardware is 64-bit, too.
how do i know if i can take it
On a Windows system, go to http://www.cpuid.com/cpuz.php. Download the latest version of the CPU-Z program setup listed on the upper left of the webpage. The current version is cpuz_154_setup.exe.
Install the CPU-Z utility, then run it. It will bring up a dialog listing the system specifics. The default tab is CPU. Look under Processor for the Instructions section. For the system to be 64-bit capable, it needs to list EM64T in this section.
May 04, 2010 May 04, 2010
wel i have downloaded the newest and i go to the tab Caches
and it says
L1 D-Cache
size                          32KBytes                             x2
discriptor                   8-way set associative , 64 bite line size
L1 I-Cache
size                          32KBytes                             x2
L2 Cache
size                          1024 KBytes
discriptor                   4-way set associative , 64 bite line size
What does it say in the Processor, Instructions section?
"The default tab is CPU. Look under Processor for the Instructions  section. For the system to be 64-bit capable, it needs to list EM64T in  this section."
Guest
Jul 15, 2010 Jul 15, 2010
You buy Windows Vista/ Windows 7 64bit and install it, assuming your processor ios able to run it.
Mylenium
how do i know if it can take it
Guest
May 22, 2010 May 22, 2010
Where can I get a copy of this from? I too have a 32 bit OS, and need a copy of after effects.
See this thread:
http://forums.adobe.com/thread/639263
Apr 05, 2011 Apr 05, 2011
I got AE CS4 when I bought Production suite CS5 (on an extra DVD) Don't know why it's in the package, but if you bought AECS5 maybe you already have AECS4 as well?
Jun 08, 2010 Jun 08, 2010
why can't AE and Premier Pro CS5 be used on 32bit Win7?? I really need this!!
You can't install on 32bit systems because AE CS5 and Premiere CS5 are 64 bit application only. You should definitly move on a 64bit version of Windows 7 (If you bought a retail box, both 32 and 64 installs are available) and not only for AE, but for your computer performance in general.
Sorry, but there is no workaround or solution to make them both work on 32 bit systems.
Hope that helps,
Seb
Ok, I guess i'm just unlucky, but anyway thanks for the help, or merci pour l'aide.
James
De rien James
All of the CS5 are for 64-bit operating systems ONLY!  Make sure your laptop can run a 64-bit Operating System and then upgrade to either the 64-bit version of Vista or Windows 7.
Just to clear some stuff up, not all application are 64bit only. Photoshop is still 32/64bit, Encore is 32bit, and some other programs too.  But if you want specifically to use AE & Premiere Pro, they are 64b only, so you'll need a 64bit OS. I recommand Windows 7.
May 21, 2010 May 21, 2010
you can install windows vista or seven 64-bit on virtual machine and install adobe after effects cs5 on the virtual machine
