Hello,
After upgrading to RH8 my custom bullet styles have broken. As you can see in the screenshot, they render correctly in the RH designer, but in IE8, the first level bullet loses the space between the bullet and the text, and the second level bullet does not use the correct image.
Here is the relevant CSS:
UL {
margin-top: 0pt;
margin-bottom: 0pt;
P.Bullets {
font-family: Verdana;
font-size: 8.0pt;
margin-left: -8pt;
list-style: url("smallorange.jpg");
LI.P-Bullets {
font-size: 8.0pt;
P.Bullet2 {
font-size: 8.0pt;
margin-left: 8pt;
list-style: url("Bullet2.jpg");
LI.P-Bullet2 {
font-size: 8.0pt;
And here is some sample html:
<ul>
<li class="p-Bullets"><p class="Bullets">Level
1 bullet .</p></li>
<li class="p-Bullet2"><p class="Bullet2">Level
2 bullet.</p></li>
<li class="p-Bullet2"><p class="Bullet2">Another
level 2 bullet.</p></li>
</ul>
Here's a screenshot of how it looks in IE8:
I created new li styles and dumped the paragraph, and that works fine for new content, but I have a lot of existing content with the paragraph inside the list item and so I would like to find a way to make it render corretly with the existing tags.
If anyone knows how I might be able to fix this, please let me know.
M.S
A clean up may not be necessary. Remove the margin-left from the paragraph style (P.Bullet and P.Bullet2) to the list item style (Li.P-Bullet and Li.P-Bullet2). As long as all your lists use the list item styles, the indent should be fixed.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
As you have found, the problem is related to stricter adherence to standards. If you haven't already seen them, these two links will tell you more.
http://www.wvanweelden.eu/robohelp/lists/lists.php
http://www.grainge.org/pages/authoring/rh_tour/index.htm (Look under New > Lists).
You also seem to be using images and that is not currently supported in the list editor. There is however a solution at
http://www.grainge.org/pages/authoring/rh8/rh8_lists.htm
I hate to say it but unless Willam has any alternative suggestions, it looks like that clean-up that you understandably want to avoid is going to be the only option. I wonder if a multifile find and replace tool would help? Make sure you back up before you start though.
Greet,
Willam
