1 2 3 Previous Next 84 Replies Latest reply on Jun 27, 2017 4:25 PM by Bill Gehrke
    enable CUDA ?
    edelf63 Level 1
      found this on cinema5d.com forum:
      How to make Premiere CS5 work with GTX 295
      Postby marvguitar on 01 May 2010 22:38
      I figured out how to activate CUDA acceleration without a GTX 285 or Quadro... I'm pretty sure it should work with other 200 GPUs. Note that i'm using 2 monitors and there's a extra tweak to play with CUDA seamlessly with 2 monitors.
      Here are the steps:
      Step 1. Go to the Premiere CS5 installation folder.
      Step 2. Find the file "GPUSniffer.exe" and run it in a command prompt (cmd.exe). You should see something like that:
      Device: 00000000001D4208 has video RAM(MB): 896
      Vendor string: NVIDIA Corporation
      Renderer string: GeForce GTX 295/PCI/SSE2
      Version string: 3.0.0
      OpenGL version as determined by Extensionator...
      OpenGL Version 2.0
      Supports shaders!
      Supports BGRA -> BGRA Shader
      Supports VUYA Shader -> BGRA
      Supports UYVY/YUYV ->BGRA Shader
      Supports YUV 4:2:0 -> BGRA Shader
      Testing for CUDA support...
      Found 2 devices supporting CUDA.
      CUDA Device # 0 properties -
      CUDA device details:
      Name: GeForce GTX 295 Compute capability: 1.3
      Total Video Memory: 877MB
      CUDA Device # 1 properties -
      CUDA Device # 0 not choosen because it did not match the named list of cards
      Completed shader test!
      Internal return value: 7
      If you look at the last line it says the CUDA device is not chosen because it's not in the named list of card. That's fine. Let's add it.
      Step 3. Find the file: "cuda_supported_cards.txt" and edit it and add your card (take the name from the line: CUDA device details: Name: GeForce GTX 295 Compute capability: 1.3
      So in my case the name to add is: GeForce GTX 295
      Step 4. Save that file and we're almost ready.
      Step 5. Go to your Nvidia Drivercontrol panel (im using the latest 197.45) under "Manage 3D Settings", Click "Add" and browse to your Premiere CS5 install directory and select the executable file: "Adobe Premiere Pro.exe"
      Step 6. In the field "multi-display/mixed-GPU acceleration" switch from "multiple display performance mode" to "compatibilty performance mode"
      Step 7. That's it. Boot Premiere and go to your project setting / general and activate CUDA
      Hope this helps
        • 1. Re: enable CUDA ?
          TradeWind Level 3
          Well, that didn't take long.
          • 2. Re: enable CUDA ?
            PBodytko Level 1
            OK -- now when GTX 295 works -- can you make GTX285 do real time on more then 3 layers?
            • 3. Re: enable CUDA ?
              sync2rhythm Level 1
              Wow! Talking about Cracking the Code.
              Many people will be arriving on your doorstep to hug & kiss you for  this. (what's your address?)
              - Is there a special way to write the name of the Card when you do this? (ie: GTX-295 vs GTX295 vs GTX 295... my cards are Quadro FX1800)
              - Have you noticed any performance boost in doing this with a non-supported card?
              • 4. Re: enable CUDA ?
                jabloomf1230 Level 1
                Whatever name that GPUSniffer.exe shows for the card, you must include that name exactly.
                I have a GTX275 and when I monitor CPU and GPU use with an independent RT program (Everest), with CUDA enabled, the CPU usage goes down during previewing. Keep in mind also that the MPE does very little to nothing to improve decoding and encoding speeds, just rendering. The specific codecs that are accessed, control those critical factors.
                On my quad core, RAID 0 setup, having CUDA enabled, usually makes a difference between stuttering and RT playback, but not for every timeline. Whether I want to risk doing so on an important project, though, is another issue.
                • 5. Re: enable CUDA ?
                  Bill Gehrke Adobe Community Professional & MVP
                  When someone tries this successfully on the Fermi cards please post here!  As the GTX 285 and the 295 are now obsolete I hate buying even a used card and I will not ever buy another Quadro card.
                  • 6. Re: enable CUDA ?
                    cts51911 Level 1
                    I posted yesterday that GTX 470 seems to work.  Jury is still out on the stability and functionality though.  Take a look at my other posts for details.
                    UPDATE:  There are rendering errors with the Fermi / GTX 400 series from what I understand.  Sorry guys...Not ready for prime time yet.  Not production ready yet.
                    • 7. Re: enable CUDA ?
                      Cineurosis Level 1
                      Note that this will only work with cards that have 765MB or more of RAM.
                      • 8. Re: enable CUDA ?
                        chupacabracobra Level 1
                        function(){return A.apply(null,[this].concat($A(arguments)))}
                        Even if so, keep it on for editing and turn it off for final rendering then, no? So it might still be a huge help even as is.
                        Maybe it is just a bug in the current nvidia fermi driver and will fixed the next driver release?
                        Yeah it does seem fairly disappointing that the HW still seems to be untouched for codec decoding, using video card decoding assistance makes a ridiculous impact (although it might make it harder to also use CUDA then, but I almost bet, for h.264 video, if most likely not for any other sort, that shifting that to decoded accel and doing the CUDA stuff back on CPU would be faster on average, i also wonder if it might not be possible to use both at once, at the very least with some buffering tricks, anyway i'm getting into wild speculation now). Straight h.264 still drives the CPUs like wild. At least the Mercurcy engine is now just barely fast enough in software to handle it on a reasonable fast machine though, so whatever the actual story it certainly is quite a step up from CS4 for sure and one a reasonably fast machine it will do pretty well unless you go crazy with it.
                        • 9. Re: enable CUDA ?
                          edelf63 Level 1
                          Can you explain more about the rendering errors ?    Was it related to hangups/crash or image quality problems ?
                          Did you experience these yourself ?
                          • 10. Re: enable CUDA ?
                            cts51911 Level 1
                            My experience, so far, with the GPU Hack + GTX 470.....
                            First, I have to say up front that nothing I say here is neither scientific or accurate.  I've had random moments throughout the last few days when I time to get on the computer and see if something works.
                            I've been doing random tests to see if I'm seeing any benefit at all...That has been my main focus.  In other words, does it even work?  As of right now, I'm sure I'm seeing GPU acceleration.  There is a distinct difference between MPE software only and gpu modes.
                            Regarding the errors, I have seen some strange pixelization and image shift in the preview window with basic 3d plugin.  I have not done enough to draw any conclusions.  I can't even speak to the final rendering quality since I have not done much.
                            Bottomline: Fermi requires updates to work properly (point releases).  It is a totally difference GPU than the 200 series.  Expect some strange stuff if you dare to use the hack.  I seriously doubt that I'm seeing the full potential of Fermi with the hack in terms of the computational power or the quality that is possible.  Still, what I am seeing so far is pretty amazing (accelerated effects, smooth preview playback)
                            Seeing the instablity helps me understand why Adobe chose just a few cards.  The last thing you would want to use is an uncertified card if you are doing production.  This is a strong argument for their selecting a few cards versus "all cuda cards".  Imagine it "kind of working"?  People would be pissed.  This is new territory for Adobe.  It was smart to error on the side of being caution.
                            I'll go out on a limb here and say that the GPUs that are "very" similar to the GTX 285 will work much better than Fermi (using the hack) because the GPUs are the same design.  My understanding, and I could be wrong, but the GTX 260/275 is the same GPU as the GTX 285 sans stream processors, ROPS and a narrower memory bus.  So, if the GTX 285 is limited to 3 streams, than what are these cards capable of?  Are you just going to bottleneck the system?  This leads to why they chose the GTX 285 as the mainstream option...It just has just enough power and models below lack the power to see a clear benefit.
                            3 more hard drives and another 6gb of memory is arriving today to relieve the i/o bottlneck I have.  I hope to have more details at a later date.
                            • 11. Re: enable CUDA ?
                              Chuck A. McIntyre Level 3
                              So far so good with the Boss's new Sager Notebook.  He ordered it with CS5 and MPE in mind.  The notebook version of the Nvidia GTX 285 is the GTX 285M.  Just did the dance outlined above.  We'll see how it goes.  For our other two i7 920 editing systems, we just ordered a pair of Nvidia 285 GTX's.  We are currently working on a project that has a dimension of 2560 X 540.
                              In CS4, without MPE (waiting for the 2 cards from Newegg.com) playback from the timeline of the 2560 x 540 sequence was choppy.  The same sequence in CS5 plays back smooth at full resolution without rendering and without GPU acceleration!  Can't wait to install the GTX 285 MPE cards on our two best systems.
                              The Adobe CS5 team should be proud.
                              • 12. Re: enable CUDA ?
                                cts51911 Level 1
                                Just noticed that the 3 line limit includes my GTX 470.
                                Someone here mentioned it is tied to the Geforce card drivers.
                                Funny thing is that the limit involves the timeline being Red and doesn't have to do with preview quality...The previews still seem to be smooth.
                                Sadly, I'm realizing that the last bottleneck I have is the i7 CPU 930 I have.
                                • 13. Re: enable CUDA ?
                                  Simply overclock!
                                  • 14. Re: enable CUDA ?
                                    cts51911 Level 1
                                    Hi Bill,
                                    Looking forward to your PPBM5.
                                    Yes...I see on your site you are at 4.2ghz
                                    • 15. Re: enable CUDA ?
                                      Shahzad Rafique Level 1
                                      Can anyone help me to enable CUDA support for Quadro 4600.  I run the GPUSniffer.exe the results are:
                                      Device : 00000000002C4168 has video RAM(MB) : 768
                                      Vendor string :     NVIDIA Corporation
                                      Renderer string :  Quadro FX 4600/PCI/SSE2
                                      OpenGL Version 3.0
                                      Supports shaders!
                                           Found 1 devices supporting CUDA.
                                           CUDA Device details:
                                                Name: Quadro FX 4600          Computer capability: 1.0
                                                Total Video Memory: 739MB
                                           CUDA driver version: 3000
                                      CUDA Device # 0 not choosen because CUDA version 1.0 is not supported.
                                      • 16. Re: enable CUDA ?
                                        xpimpyo Level 1
                                        It's saying that the GPU was not chosen because CUDA is not supported, not because it isnt on the list.
                                        Do you have the latest drivers?
                                        Does that card support CUDA?
                                        • 17. Re: enable CUDA ?
                                          cts51911 Level 1
                                          I think you need to install Cuda Ver.  3.0
                                          Your posts says you have 1.0 installed.
                                          Caution:  This is just a guess since I don't have a Quardro card.  Proceed at your own peril
                                          • 18. Re: enable CUDA ?
                                            cts51911 Level 1
                                            The lastest driver at Nvidia.com has Cuda 3.0 built in from what I understand
                                            197.59 Driver is the lastest
                                            • 19. Re: enable CUDA ?
                                              Thanks for quick reply...
                                              i have the latest diver "197.59_Quadro_win7_winvista_64bit_english_whql" with CUDA 3.0 support but its not working for Premiere Pro
                                              • 20. Re: enable CUDA ?
                                                i think driver for CUDA and CUDA compute compatibility are different things
                                                • 21. Re: enable CUDA ?
                                                  cts51911 Level 1
                                                  I think your video MEMORY is too low  739mb available is not enough?
                                                  • 22. Re: enable CUDA ?
                                                    may be...
                                                    • 23. Re: enable CUDA ?
                                                      Wil Renczes Adobe Employee
                                                      Yep - 768 megs of card memory is the minimum.
                                                      • 24. Re: enable CUDA ?
                                                        one more thing if you can help me out
                                                        For Premiere is there any performace difference between Quadro and Geforce? because they both are identical in hardware just driver difference for professional applications which i found over net.
                                                        • 25. Re: enable CUDA ?
                                                          Yes, I have sucessfully pushed it to 4.2 GHz but I am not going to run normally at the clock rate.with my $1000 CPU.  Since it still is an experimental bench top system I am able to make very quick changes.
                                                          • 26. Re: enable CUDA ?
                                                            skater1121995 Level 1
                                                            Works with the nvidia/asus GeForce 9400 gt 1gb
                                                            • 27. Re: enable CUDA ?
                                                              remainz Level 1
                                                              HI What should it say in the project setting / general ?
                                                              I only have
                                                              "Mercury Engine Playback GPU Acceleration"
                                                              and
                                                              "Mercury Engine Playback Software Only"
                                                              No mention of Cuda. Im assuming the first one is correct?
                                                              I have GeForce GTX 260 i7 930 12gbram
                                                              • 28. Re: enable CUDA ?
        Jeff Bellune Adobe Community Professional
        Yes.
        -Jeff
        • 29. Re: enable CUDA ?
        jamescook48@yahoo.com Level 1
        This sounds like a great work around. Do you know if a similiar procedure works with After Effects CS5?
        • 30. Re: enable CUDA ?
        Possibly, I'll try it and report back.
        Edit: After effects has the gpu sniffer file, but cuda acceleration available, possibly in the future?
        • 31. Re: enable CUDA ?
        After Effects uses OpenGL to utilize built-in functions on the video card to draw frames to the preview window, etc., as opposed to using Microsoft's graphics framework DirectX (or more specifically the subset, Direct3D).The more drawing that is done by the GPU, the less the CPU has to do. CUDA, on the other hand, was designed from scratch, for general  purpose  computation using the GPU. It can do more than just graphics.
        AE needs GPUSniffer.exe to figure out whether the graphics card is compatible with various versions of OpenGL.
        • 32. Re: enable CUDA ?
        So does this mean that After Effects CS5 does not take advanage of the Mercury Engine? Is the Cuda/Mercury Engine only for
        Premiere Pro CS5?
        • 33. Re: enable CUDA ?
        Todd_Kopriva Level 8
        Yes, the CUDA acceleration is only for Premiere Pro.
        • 34. Re: enable CUDA ?
        See #33 dated 7-14-2010 for an easy hack http://forums.adobe.com/thread/672876?tstart=0
        • 35. Re: enable CUDA ?
        Harm Millaard Level 7
        In that case replace 470 with 260 if you followed John's link.
        • 36. Re: enable CUDA ?
        Amr Toukhy Level 1
        i think this link could be useful to the 300 series people !!
        http://punkbuddhaz.wordpress.com/2010/06/09/nvidia-300-series-gpu-cuda-mercury-playback-en gine-hack/
        thanks to both the Hacker and the Testers
        • 37. Re: enable CUDA ?
        bdsch2010 Level 1
        I enablet my Geforce GT 240 to Premiere CS 5. It works fine. Encoding over Encore dosn't work. What ist to do.
        Sorry, my english ....
        • 38. Re: enable CUDA ?
        bdsch2010 Level 1
        what is about encore ?
        • 39. Re: enable CUDA ?
        Cine Real Level 1
        Chuck A. McIntyre wrote:
        ................................ The notebook version of the Nvidia GTX 285 is the GTX 285M.  Just did the dance outlined above.  We'll see how it goes.
        Hello Chuck, how did your setup 'dance', for the GTX285M work out?
        I am picking up an MSI GT660R laptop which uses the Nvidia GTX285M, and I was wondering whether or not it would accelerate the Mercury Playback Engine. Has your fix worked effectively?
        I am not certain that the CS5 team should be proud. Perhaps if they got off their backsides and qualified a few laptop Nvidia 'M' cards, I would be more appreciative of their efforts. After  3 months of begging and pleading with them to help, I finally bit the bullet with the MSI GT660R and now have to hope that the fix works.
        After putting in my purchase order for the MSI GT660R, Dell finally came around with the XPS 17 which has a NVIDIA GeForce GT 445M 3GB graphics with  Optimus. Impressive stats on the system and they indicate that it is Adobe Certified? If so, then it is a first for laptop video-card certifications. Cannot find the certification on the Adobe site or the Nvidia site. I will have to ask them where it is stated that it is certified.
        .................. Sigh!
        1 2 3 Previous Next
