I'm trying to compare two tables in a database. I need to output a few fields from one table, compare one field between the two tables. Users are selecting the tables. I have written an SQL query which does what I need:
<cfquery name="getitems" datasource="snapshot">
select #endtable#.field9, #endtable#.field12, #endtable#.field4, #endtable#.field13, #endtable#.field2, #endtable#.field3, #starttable#.field3
from #endtable#, #starttable#
where #endtable#.field5='#form.field5#'
and #starttable#.field2=#endtable#.field2
</cfquery>
Problem is on output. You can see I am selecting field3 from two tables. I also want to output both field3 values.
<cfoutput query="getitems">
#field3#
</cfoutput>
This gives me the value which was selected as #endtable#.field3.
How can I output the other -- #starttable#.field3?
As noted, the table names are variables being passed into the query... Thanks!
Peter
Use an alias to give the fields different names ie table.column AS SomeName. Otherwise, cfquery may not know which field you mean when you say "field3".
Be careful using this type of sql. Depending on the source of your variables, this can pose a sql injection risk.
Thank you, that worked beautifully! Another trick learned..
Also, thanks for the sql injection warning -- I am cleaning the input before passing it into the query. Much appreciated!
Peter
Regarding:
Even this one?
'#form.field5#'
The #form.field5# comes via a select list....no user input of data.
I suppose it is still possible to be compromised. I'll fix that. Thanks!
of data....
Someone could easily construct a fake http post, with malicious sql in the "form" fields, and submit it to your action page. That is why it is vulnerable.
