Show 1 reply
1. Re: Export to Blu-ray? 25 fps must be interlaced?
Mylenium May 4, 2010 11:19 PM (in response to Brandalarm)So, is there one dimension that can be changed without changing the content of the video, and if yes which one (either the interlacing or the fps).
You could just slow it down to 24p (23.97 fps). Everything else is unrealistic. For compatibility reasons, the specs are set in stone with no room for creative variations and on the other hand, extrapolating footage to increase frame rates never looked good, not even when going from SD PAL to NTSC.
Mylenium
