1 2 3 4 5 Previous Next 245 Replies Latest reply on Jan 5, 2011 5:56 PM by Dov Isaacs Go to original post
      • 80. Re: Can't install CS5 Master collection engl Win 7 64- bits
        PCMILLS70 Level 1
        I'm not sure what's happening, but I just tried to open up msconfig and I can't get it to open. My system wasn't giving me any problems before all of this. Wish me luck.
        • 81. Re: Can't install CS5 Master collection engl Win 7 64- bits
          jabloomf1230 Level 1
          Matthew Laun wrote:
          @-_Simon_-,
          My guess is that if you search your log for the string "return value 3" you will get something more useful for debugging.
          In lieue of that, my guess is that your installation is failing due to some conflict with a previously installed instance of the Flash Player. In which case, this document, labeled for CS4, but as applicable for CS5, should help:
          http://go.adobe.com/kb/ts_kb403962_en-us
          Sincerely,
          Matthew
          @Matthew,
          Since I followed nitemarebr's suggestions in this thread, and was subsequently able to install CS5, I can tell you that it has to do with permissions on specific Visual C x86 V8 Windows registry keys. These keys oddly showed up on my Win 7 x64 system with "Unknown" ownership. I have only seen this issue before (not Adobe software installation though), when I've done an inplace upgrade (EEEK!) of Windows on one of our computers (XP to Vista or Vista to Win 7). My guess is that it might be a MS bug. The OS owned the keys before the upgrade and then afterward, the new OS doesn't own them, as the old OS still does.
          But some people are seeing this same error with clean installs of Windows 7 x64, so I don't know how that would be possible. My install followed removal of all CS4 software, registry cleaning and using the Adobe CS4 and CS5 clean up scripts. None of that has any effect on the error during CS5 installation. It could be Adobe Flash, as you say, but who knows? Good luck. I also submitted a support case with a log dump from the Adobe Support Advisor, but I closed the case when I made the suggested "fix" work.
          J
          • 82. Re: Can't install CS5 Master collection engl Win 7 64- bits
            MatthewLaun Adobe Employee
            Here are a few other resources that may be of help.
            First, this is a general troubleshooting document for CS5 suite/product installations:
            http://go.adobe.com/kb/ts_cpsid_82827_en-us
            Many of the exit code 6 or 7 cases that I've looked at turn out to be familiar issues we had with CS4, such as...
            Permissions issues on registry entries:
            http://go.adobe.com/kb/ts_kb404622_en-us
            or..
            Permissions, or file in use issues with color profiles:
            http://go.adobe.com/kb/ts_kb408716_en-us
            Unfortunately, the summary text in the CS5 logs are not including MSI errors, so you need to search for these in the installer log searching for the string "return value 3" as described in this doc:
            http://go.adobe.com/kb/ts_kb400593_en-us
            Good luck all, and thanks for your understanding for the complexity of what's involved here, and the aspects of the OS that we don't have control over.
            Sincerely,
            Matthew
            • 83. Re: Can't install CS5 Master collection engl Win 7 64- bits
              My MSI log entry is posted earlier in this thread. That's how we figured out what was happening. The VC80 x86_x64 libraries are okay, as are all the VC90s. It only seems to affect the Suites and the single product x64 installations (Premiere, Photoshop and After Effects). There is also a similar thread about this in the Photoshop CS5 forum.
              I have to believe that the installation problem isn't common, since it there don't seem to be that many people posting about it, either here or elsewhere on the Internet. It only seems to affect certain Win 7 x64 installations.
              • 84. Re: Can't install CS5 Master collection engl Win 7 64- bits
                AllDayDev Adobe Employee
                Paul-
                Posting to your Box account actually works better than PM, so thank you.
                FYI, to send a PM, click on the person's name/avatar, which will take you to their profile, then you'll have an option in the Actions section on the right to Send A Private Message.
                Did you get a chance to run the CS5 Clean Script, selecting CS5, and the "Clean All" option?
                If so, did you first install Windows Installer Cleanup?
                Also, did you run the CS5 Clean Script by right-clicking on it and selecting Run As Administrator?
                If you answered no to any of those questions, or you are unsure, please just double-check.
                Even if you did jump through all the necessary hoops to run CS5 Clean, please temporarily disable background services/startup items and then re-run CS5 Clean. Your install log indicates that there are some payloads (installation files) that are conflicting with each other.
                To disable the background items in the way I mean, please do the following:
                1. Quit all applications.
                2. Choose Start, type "msconfig" (without the quotation marks) into the Start Search, and then press Enter.
                3. On the Startup tab, click Disable All.
                4. On the Services tab, check the box "Hide All Microsoft Services", and then click Disable All.
                5. Click OK, and restart Windows.
                Once you have run CS5 Clean again, uninstall any CS4/CS3 applications you have, and then go ahead and delete the following folders (if they are still there):
                C:\Program Files (x86)\Common Files\Adobe\AAMUpdaterInventory
                C:\Program Files (x86)\Common Files\Adobe\Adobe Creative Suite 5 Master Collection  (This folder would have the name of your suite, if different thatn master collection.)
                C:\Program Files (x86)\Common Files\Adobe\Adobe PCD
                C:\Program Files (x86)\Common Files\Adobe\backup
                C:\Program Files (x86)\Common Files\Adobe\caps
                C:\Program Files (x86)\Common Files\Adobe\Installers
                C:\Program Files (x86)\Common Files\Adobe\OOBE
                C:\Program Files (x86)\Adobe\AdobePatchFiles
                C:\Program Files (x86)\Common Files\Adobe\Color
                C:\ProgramData\Adobe\CS5
                Also check the non-x86 Program Files folder for these folders, just to ensure we don't miss anything, and delete any folders with the same names there.
                If you don't have any Adobe software installed at this point (which, if you are willing, I would suggest that you make happen), it would make the most sense to just delete these folders instead of looking for those above so as to increase your chances of success:
                C:\Program Files\Adobe
                C:\Program Files\Common Files\Adobe
                Once you have completed the above steps (which, by the way, I appreciate your patience in doing so), then please re-extract your download to a different folder. Some of the conflicting payloads could have been caused by a problem during extraction.
                Then, go ahead and re-install by double-clicking on Set-up.exe.
                • 85. Re: Can't install CS5 Master collection engl Win 7 64- bits
                  -_Simon_- Level 1
                  Success....all applications are now installed and working.
                  I ran the CS5 CleanScript 3 times - picking off Flash Player & previously uninistalled CS3/4 suites in addition to the broken CS5 install.
                  Rebooted, then manually deleted every Adobe dir from /appdata, prog files, prog files (x86), /common files etc [some 2GB of files all told!].
                  Then for good measure after a further reboot ran CCleaner to pick off any redundant Adobe reg entries - it took 3 passes to get them all, mostly innocuous shell extensions and file associations I think, but after the first 100 or so I stopped reading and just selected everything for deletion.
                  Finally ran setup again - still got the errors at the end with regard to the absense of Flash Player impacting Flash & Catalyst installs, but both Apps actually installed OK despite this and are working...
                  • 86. Re: Can't install CS5 Master collection engl Win 7 64- bits
                    If ever you run into a situation where you are going to re-install all Adobe applications due to installation issues, I highly recommend you ensure that the following folders are removed, if they are not removed by the uninstall or clean script:
                    C:\program files\common files\adobe\adobe PCD
                    C:\program files\common files\adobe\caps
                    C:\program files\common files\adobe\backup
                    These are the database files used for storing information about installation, serialization, license agreement, activation, etc.
                    Cheers!
                    • 87. Re: Can't install CS5 Master collection engl Win 7 64- bits
                      PaulFAubin Level 1
                      HORRAY!!!!
                      OK, I followed your instructions. I uninstalled all Adobe software, ran the CS5 cleanup script a few times (using the tip from -_Simon_- above). I ran it for each option, CS4, CS5 and Flash. I deleted the Adobe folder in both Program Files and Program Files (x86). I deleted the Adobe folder in each User directory, in Local, in Roaming, in My Documents and in ProgramData. I cleaned my registry with Reg Mechanic. I rebooted, ran the CS5 script again just for good measure and logged into the Administrator's account. I turned off firewall, and virus protection. I redownloaded the entire install package, deleted the old one and unzipped it again to the local Desktop. I held my breath and double-clicked the installer. After about 30 minutes... SUCCESS!!! All products installed and working!
                      Just had to reinstall Acrobat and everything is now working. THANK YOU so much for all your help. I have been at this for days. I have an open tech support case, where I spent an hour with the first guy, another guy (he is the next teir up) called me back today, worked with me for about 30 minutes and then said he would have to call back.So I guess I'll log into my account and close the case.
                      This was a major PIA, but I am very happy to have it all solved now. Thanks again.
                      • 88. Re: Can't install CS5 Master collection engl Win 7 64- bits
                        mcf139
                        Congrats to all who in the end after many registry cleaners and maual deleting and waste of time and nerves managed to instal this CS5 Fail i tried also everything and no chance .Is simply amazing how Adobe didnt managed to make a reliable install kit,amazing....
                        • 89. Re: Can't install CS5 Master collection engl Win 7 64- bits
                          amitzi Level 1
                          Mine still not working:
                          Tried EVERYTHING!
                          Exit Code: 7
                          • 90. Re: Can't install CS5 Master collection engl Win 7 64- bits
                            mcf139-
                            Sorry to hear that it's not working on your machine.
                            Could you post (or PM) your installation log file so that we can help you a bit further?
                            You would find this file in C:\Program Files (x86)\Common Files\Adobe\Installers. It would be named the product you installed along with a time/date stamp.
                            • 91. Re: Can't install CS5 Master collection engl Win 7 64- bits
                              mcf139 Level 1
                              [     108] Thu May 06 15:08:55 2010  INFO
                              Visit http://www.adobe.com/go/loganalyzer/ for more information
                              START - Installer Session
                              RIBS version: 3.0.122.0
                              Win OS version: 6.1.0.0 64 bit Type: 1
                              ::START TIMER:: [Total Timer]
                              CHECK: Single instance running
                              CHECK : Credentials
                              Load Deployment File
                              Create Required Folders
                              Assuming install mode
                              ::START TIMER:: [Bootstrap]
                              Perform Bootstrapping ...
                              :: END TIMER :: [Bootstrap] took 36333.8 miliseconds (36.3338 seconds) DTR = 1459.47 KBPS (1.42526 MBPS)
                              Looking up install source path
                              Sync Media DB ...
                              ::START TIMER:: [Sync Media DB]
                              Pre check media db sync
                              End of Pre check media db sync. Exit code: 0
                              :: END TIMER :: [Sync Media DB] took 1984.48 miliseconds (1.98448 seconds) DTR = 37569.5 KBPS (36.6889 MBPS)
                              Ready to initialize session to start with ...
                              ::START TIMER:: [CreatePayloadSession]
                              -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                              Updated source path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5
                              Updating media info for: {01367616-4132-4311-911F-49D2EA82F7C2}
                              Ignoring original data since install source is local
                                Type: 0, Volume Order: 1, Media Name: AdobeMasterCollection5-trial-English
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeOnLocation5RoyaltyWrapperAll\Install.db
                              Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
                              Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                              Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                              Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
                              Updating media info for: {04D84E18-23ED-46EA-9B41-789433E34D03}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6-FFPlugin\Install.db
                              Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
                              Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                              Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
                              Updating media info for: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_US\Install.db
                              Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
                              Updating media info for: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
                              Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                              Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
                              Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlash11-en_USLanguagePack\Install.db
                              Updating media info for: {157D044B-C60D-1015-B0DB-A40823CC0F49}
                              [     108] Thu May 06 15:08:56 2010  INFO
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeToolhints-mul\Install.db
                              Updating media info for: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFireworks11All\Install.db
                              Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlashBuilder-mul\Install.db
                              Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
                              Updating media info for: {1A48007B-34D2-44BD-8708-B570F5339C14}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeEncore5RoyaltyWrapperAll\Install.db
                              Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
                              Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
                              Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
                              Updating media info for: {20F72893-AEC7-4954-9EAA-F07FD6184781}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyWrapperAll\Install.db
                              Updating media info for: {22F41D72-2E97-46AE-B8C4-EF66876C7838}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5ProtectedWrapperAll\Install.db
                              Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeMobileExtension_Flash11-en_US\Install.db
                              Updating media info for: {26B63C3A-0BFF-1033-B389-A7ACEC31657E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7AppLang-en_GB\Install.db
                              Updating media info for: {288DB08D-0708-4A94-B055-55B99E39EB62}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeMasterCollection5-trial-mul\Install.db
                              Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
                              Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                              Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AIR2_Flash11-mul\Install.db
                              Updating media info for: {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEPCIWrapper5All\Install.db
                              Updating media info for: {34F82E6B-8096-45CA-B604-ACACAC22E553}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5en_USLanguagePack\Install.db
                              Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
                              Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
                              Updating media info for: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFireworks11en_USLanguagePack\Install.db
                              Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                              Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                              Updating media info for: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeBuzzword-mul\Install.db
                              Updating media info for: {406D22BD-7910-479B-96AA-0DB8A36C694B}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10ProtectedWrapperAll\Install.db
                              Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
                              Updating media info for: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6en_USLanguagePack\Install.db
                              Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
                              Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
                              Updating media info for: {479C08E9-FACF-4190-A37A-81D65B4C8D4E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6-IEPlugin\Install.db
                              Updating media info for: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3ProtectedWrapperAll\Install.db
                              Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSING3-mul\Install.db
                              Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\Install.db
                              Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
                              Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
                              Updating media info for: {5658F35F-15B9-1033-8337-97B78F2D0BE0}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7IconHandler64-mul\Install.db
                              Updating media info for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
                              Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeMobileExtension_Flash11-mul\Install.db
                              Updating media info for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
                              Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\BrowserLabCSLive-mul\Install.db
                              Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
                              Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\iPhone_Flash11-mul\Install.db
                              Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                              Updating media info for: {64D991B0-4E64-47AC-8A35-291DA2E7D02F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10SupportAll\Install.db
                              Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeStoryExtension-mul\Install.db
                              Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\Install.db
                              Updating media info for: {681DE732-3F3A-42F2-91C9-84B1CC9B8535}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6en_GBLanguagePack\Install.db
                              Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMECore5All_x64\Install.db
                              Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMECore5All\Install.db
                              Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-en_US\Install.db
                              Updating media info for: {6ACDB89B-63FB-4C7D-8490-7528E248F25B}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10en_USLanguagePack\Install.db
                              Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                              Updating media info for: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5RoyaltyWrapperAll\Install.db
                              Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
                              Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
                              Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
                              Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
                              Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                              Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
                              Updating media info for: {771C9F59-3F22-4610-A23E-321A98ECA264}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeOnLocation5en_USLanguagePack\Install.db
                              Updating media info for: {7745F18B-FD8A-4011-BE16-588900C503D0}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
                              Updating media info for: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
                              Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
                              Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
                              Updating media info for: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6-OfficePlugin\Install.db
                              Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-Core\Install.db
                              Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
                              Updating media info for: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7AppLang-en_US\Install.db
                              Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
                              Updating media info for: {805ABF27-1582-1033-B4AC-82A1DE0DD827}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7CommonBase-mul\Install.db
                              Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                              Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-en_GB\Install.db
                              Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
                              Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
                              Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
                              Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                              Updating media info for: {92D4A929-78F1-4EC3-B626-08B3CF5B784F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEPCI5All\Install.db
                              Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                              Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AIR2_Flash11-en_US\Install.db
                              Updating media info for: {966B69F2-0FBD-1033-B01C-D13C02FFF33F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_GB\Install.db
                              Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
                              Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
                              Updating media info for: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeIllustrator15-mul\Install.db
                              Updating media info for: {A013B68A-B1D9-470F-BB0F-816752F096A3}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEPCIWrapper5All_x64\Install.db
                              Updating media info for: {A334FDED-DCCA-481E-B226-F902CCC419D2}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeEncore5AllTrial\Install.db
                              Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                              Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\Install.db
                              Updating media info for: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeVideoProfilesAE3-mul\Install.db
                              Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
                              Updating media info for: {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEDolbyWrapper5All\Install.db
                              Updating media info for: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeOnLocation5All\Install.db
                              Updating media info for: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyWrapperAll\Install.db
                              Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
                              Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
                              Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
                              Updating media info for: {B842A584-A0BF-4870-A850-9C0E52FD6A20}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeEncore5en_USLanguagePack\Install.db
                              Updating media info for: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
                              Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
                              Updating media info for: {BB024724-14D5-4AB6-B21C-74EDA63A0A39}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\HIL_Help_Search\Install.db
                              Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                              Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
                              Updating media info for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
                              Updating media info for: {C21384F7-1A36-4706-95AB-B09BCE3C144F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5AllTrial\Install.db
                              Updating media info for: {C79312BD-3E76-4474-A10C-1435D1856A4B}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeDreamweaver11-mul\Install.db
                              Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
                              Updating media info for: {C925A34A-01B9-42C3-BB88-C7A78835F0EC}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\ph\ph.msi
                              Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
                              Updating media info for: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3AllTrial\Install.db
                              Updating media info for: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffectsPresets10All\Install.db
                              Updating media info for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
                              Updating media info for: {CD693E49-C5EF-4FA6-9037-9B636931C02B}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAmericanEnglishSpeechAnalysisModels2All\Install.db
                              Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
                              Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlash11-mul\Install.db
                              Updating media info for: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeIllustrator15en_GBLanguagePack\Install.db
                              Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                              Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
                              Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
                              Updating media info for: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEDolby5All\Install.db
                              Updating media info for: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeIllustrator15en_USLanguagePack\Install.db
                              Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\aifsdk-win\Install.db
                              Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                              Updating media info for: {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10AllTrial\Install.db
                              Updating media info for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
                              Updating media info for: {DE60F0DE-469A-42DC-A678-978313210057}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeContribute6-mul\Install.db
                              Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
                              Updating media info for: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7AppBase2-mul\Install.db
                              Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Players_Flash11-mul\Install.db
                              Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
                              Updating media info for: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeDreamweaver11en_USLanguagePack\Install.db
                              Updating media info for: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7IconHandler-mul\Install.db
                              Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
                              Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
                              Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                              Updating media info for: {E6F68811-F702-492C-A7DA-D22CA670BC22}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3en_USLanguagePack\Install.db
                              Updating media info for: {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFlashCatalyst-mul\Install.db
                              Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
                              Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\TLF_Flash11-mul\Install.db
                              Updating media info for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
                              Updating media info for: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeMotionPicture3-mul\Install.db
                              Updating media info for: {F6CCA85F-7527-4AFF-82B6-26532A74A244}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeFireworks11en_GBLanguagePack\Install.db
                              Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                              Updating media info for: {F77882B9-A94F-44F4-A739-8370749255B6}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobePremierePro5SupportAll\Install.db
                              Updating media info for: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEDolbyWrapper5All_x64\Install.db
                              Updating media info for: {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7AppBase-mul\Install.db
                              Updating media info for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
                              Updating media info for: {FD5603A3-1375-1033-872D-8F09140FFDB2}
                                Path: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeInDesign7AppFSet-Roman\Install.db
                              --------------------  END  - Updating Media Sources -  END  --------------------
                              [     108] Thu May 06 15:08:57 2010  INFO
                              Supported RIBS version range: [0.0.66.0,3.0.122.0]
                              ----------------- CreatePayloadSession: machine is x64 ---------------
                              ______ Verify Dependency Subscribers ______
                              Setting property "INSTALLDIR" to: C:\Program Files\Adobe
                              Setting property "installLanguage" to: en_GB
                              Attempting to find the selected language in the set of available payload languages
                              Setting property "installSourcePath" to: C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5
                              Overwrite property "userASUPath" to: C:\Users\FLORIN\AppData\Local\Adobe\OOBE\PDApp\
                              Found payload actions:
                              Deciding what installer mode to use...
                              [     108] Thu May 06 15:08:58 2010  INFO
                              BEGIN Setting requested payload actions
                              Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
                              Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
                              Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
                              Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
                              Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
                              Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
                              Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
                              Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
                              Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
                              Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
                              Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
                              Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
                              Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
                              Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
                              Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false
                              Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
                              Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false
                              Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
                              Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: false
                              Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none
                              Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
                              Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
                              Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
                              Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
                              Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
                              Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
                              Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
                              Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
                              Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
                              Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
                              Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: false
                              Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
                              Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false
                              Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
                              Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false
                              Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
                              Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
                              Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
                              Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: true
                              Action string for  {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64  is none
                              Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: true
                              Action string for  {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64  is none
                              Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: true
                              Action string for  {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64  is none
                              Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
                              Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
                              Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: true
                              Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
                              Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
                              Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
                              Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false
                              Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
                              Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false
                              Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
                              Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
                              Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
                              Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
                              Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
                              Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
                              Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
                              Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
                              Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
                              Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: false
                              Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
                              Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
                              Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
                              Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
                              Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
                              Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
                              Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
                              Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
                              Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
                              Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
                              Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
                              Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
                              Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
                              Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
                              Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
                              Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: false
                              Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
                              Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: false
                              Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
                              Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: false
                              Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
                              Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: false
                              Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
                              Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: false
                              Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
                              Value returned on lookup of payload: {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is: false
                              Action string for  {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64  is none
                              Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: false
                              Action string for  {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64  is none
                              Value returned on lookup of payload: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is: false
                              Action string for  {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64  is none
                              Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: false
                              Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none
                              Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: false
                              Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
                              Value returned on lookup of payload: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is: false
                              Action string for  {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2  is none
                              Value returned on lookup of payload: {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is: false
                              Action string for  {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files  is none
                              Value returned on lookup of payload: {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is: false
                              Action string for  {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files  is none
                              Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
                              Action string for  {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64  is none
                              Value returned on lookup of payload: {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is: false
                              Action string for  {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph  is none
                              Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false
                              Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
                              Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false
                              Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
                              Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
                              Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
                              Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
                              Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
                              Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false
                              Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
                              Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
                              Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
                              Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: false
                              Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
                              Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false
                              Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
                              Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: false
                              Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
                              Value returned on lookup of payload: {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is: false
                              Action string for  {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search  is none
                              Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false
                              Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
                              Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
                              Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
                              Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: false
                              Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none
                              Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: false
                              Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none
                              Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: false
                              Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
                              Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: false
                              Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
                              Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: false
                              Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
                              Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: false
                              Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none
                              Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
                              Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
                              Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
                              Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: false
                              Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
                              Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
                              Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
                              Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: false
                              Action string for  {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64  is none
                              Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: false
                              Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
                              Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: false
                              Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none
                              Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: false
                              Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none
                              Value returned on lookup of payload: {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is: false
                              Action string for  {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels  is none
                              Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: false
                              Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
                              Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: false
                              Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
                              Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: false
                              Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
                              Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is: false
                              Action string for  {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets  is none
                              Value returned on lookup of payload: {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is: false
                              Action string for  {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support  is none
                              Value returned on lookup of payload: {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is: false
                              Action string for  {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper  is none
                              Value returned on lookup of payload: {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is: false
                              Action string for  {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper  is none
                              Value returned on lookup of payload: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is: false
                              Action string for  {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5  is none
                              Value returned on lookup of payload: {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is: false
                              Action string for  {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper  is none
                              Value returned on lookup of payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is: false
                              Action string for  {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1  is none
                              Value returned on lookup of payload: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is: false
                              Action string for  {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler  is none
                              Value returned on lookup of payload: {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is: false
                              Action string for  {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER  is donotinstall
                              Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is allowed but the user has marked it for not to install
                              Value returned on lookup of payload: {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is: false
                              Action string for  {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER  is donotinstall
                              Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is allowed but the user has marked it for not to install
                              Value returned on lookup of payload: {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is: false
                              Action string for  {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper  is none
                              Value returned on lookup of payload: {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is: false
                              Action string for  {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support  is none
                              Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is: false
                              Action string for  {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5  is none
                              Value returned on lookup of payload: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is: false
                              Action string for  {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper  is none
                              Value returned on lookup of payload: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is: false
                              Action string for  {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper  is none
                              Value returned on lookup of payload: {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is: false
                              Action string for  {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5  is none
                              Value returned on lookup of payload: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is: false
                              Action string for  {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5  is none
                              Value returned on lookup of payload: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is: false
                              Action string for  {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5  is none
                              Value returned on lookup of payload: {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is: false
                              Action string for  {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5  is none
                              Value returned on lookup of payload: {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is: false
                              Action string for  {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5  is none
                              Value returned on lookup of payload: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is: false
                              Action string for  {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5  is none
                              Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: false
                              Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
                              Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: false
                              Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
                              Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: false
                              Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
                              Value returned on lookup of payload: {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is: false
                              Action string for  {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64  is none
                              Value returned on lookup of payload: {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is: false
                              Action string for  {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper  is none
                              Value returned on lookup of payload: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is: false
                              Action string for  {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper  is none
                              Value returned on lookup of payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is: false
                              Action string for  {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content  is none
                              Value returned on lookup of payload: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is: false
                              Action string for  {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content  is none
                              Value returned on lookup of payload: {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is: false
                              Action string for  {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content  is none
                              Value returned on lookup of payload: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is: false
                              Action string for  {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby  is none
                              Value returned on lookup of payload: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is: false
                              Action string for  {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64  is none
                              Value returned on lookup of payload: {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is: false
                              Action string for  {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI  is none
                              Value returned on lookup of payload: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is: false
                              Action string for  {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64  is none
                              Value returned on lookup of payload: {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is: false
                              Action string for  {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content  is none
                              Value returned on lookup of payload: {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is: false
                              Action string for  {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content  is none
                              Value returned on lookup of payload: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is: false
                              Action string for  {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content  is none
                              Value returned on lookup of payload: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is: false
                              Action string for  {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs  is none
                              Value returned on lookup of payload: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is: false
                              Action string for  {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs  is none
                              Value returned on lookup of payload: {288DB08D-0708-4A94-B055-55B99E39EB62} Creative Suite 5 Master Collection is: false
                              Action string for  {288DB08D-0708-4A94-B055-55B99E39EB62} Creative Suite 5 Master Collection  is install
                              Value returned on lookup of payload: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is: false
                              Action string for  {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth  is install
                              Value returned on lookup of payload: {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is: false
                              Action string for  {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack  is none
                              Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is: false
                              Action string for  {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5  is install
                              Value returned on lookup of payload: {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is: false
                              Action string for  {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack  is none
                              Payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
                              Action string for  {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder  is install
                              Value returned on lookup of payload: {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is: false
                              Action string for  {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5  is install
                              Value returned on lookup of payload: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is: false
                              Action string for  {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack  is none
                              Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is: false
                              Action string for  {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5  is install
                              Value returned on lookup of payload: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is: false
                              Action string for  {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack  is none
                              Payload {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is: false
                              Action string for  {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack  is none
                              Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is: false
                              Action string for  {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5  is install
                              Value returned on lookup of payload: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is: false
                              Action string for  {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5  is install
                              Value returned on lookup of payload: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is: false
                              Action string for  {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack  is none
                              Payload {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is: false
                              Action string for  {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack  is none
                              Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {A334FDED-DCCA-481E-B226-F902CCC419D2} Adobe Encore CS5 is: false
                              Action string for  {A334FDED-DCCA-481E-B226-F902CCC419D2} Adobe Encore CS5  is install
                              Value returned on lookup of payload: {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is: false
                              Action string for  {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack  is none
                              Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is: false
                              Action string for  {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5  is install
                              Value returned on lookup of payload: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
                              Action string for  {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack  is none
                              Payload {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: false
                              Action string for  {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack  is none
                              Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: false
                              Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is install
                              Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: false
                              Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none
                              Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
                              Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none
                              Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: false
                              Action string for  {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64  is install
                              Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
                              Action string for  {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64  is none
                              Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: false
                              Action string for  {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64  is none
                              Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {DA1B174B-4297-467C-9EF8-0AB8D4D5171E} Adobe After Effects CS5 is: false
                              Action string for  {DA1B174B-4297-467C-9EF8-0AB8D4D5171E} Adobe After Effects CS5  is install
                              Value returned on lookup of payload: {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is: false
                              Action string for  {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack  is none
                              Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {C21384F7-1A36-4706-95AB-B09BCE3C144F} Adobe Premiere Pro CS5 is: false
                              Action string for  {C21384F7-1A36-4706-95AB-B09BCE3C144F} Adobe Premiere Pro CS5  is install
                              Value returned on lookup of payload: {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is: false
                              Action string for  {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack  is none
                              Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is: false
                              Action string for  {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files  is install
                              Value returned on lookup of payload: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is: false
                              Action string for  {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US  is none
                              Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is: false
                              Action string for  {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US  is none
                              Payload {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is: false
                              Action string for  {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB  is none
                              Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is: false
                              Action string for  {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB  is none
                              Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: false
                              Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is install
                              Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: false
                              Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
                              Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: false
                              Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
                              Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
                              Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: false
                              Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
                              Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
                              END Setting requested payload actions
                              [     108] Thu May 06 15:08:59 2010  INFO
                              Collected advanced path check information for INSTALLDIR
                              INSTALLDIR is a well-formed path
                              INSTALLDIR is not the root path
                              INSTALLDIR is on a local volume
                              INSTALLDIR is on a writable volume
                              INSTALLDIR is not on a case sensitive volume
                              INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
                              [     108] Thu May 06 15:09:04 2010  WARN
                              Display requirements not met for {288DB08D-0708-4A94-B055-55B99E39EB62}
                              Display requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                              Display requirements not met for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                              Display requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                              Display requirements not met for {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                              Display requirements not met for {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
                              Display requirements not met for {A334FDED-DCCA-481E-B226-F902CCC419D2}
                              Display requirements not met for {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                              Display requirements not met for {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
                              Display requirements not met for {C21384F7-1A36-4706-95AB-B09BCE3C144F}
                              Display requirements not met for {C79312BD-3E76-4474-A10C-1435D1856A4B}
                              Display requirements not met for {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
                              Display requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
                              Display requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
                              Display requirements not met for {DE60F0DE-469A-42DC-A678-978313210057}
                              Display requirements not met for {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                              Display requirements not met for {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                              [     108] Thu May 06 15:09:04 2010  INFO
                              ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
                              In InstallPreSystemCheckProc
                              Custom action return code: 0
                              :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 95.4701 miliseconds (0.0954701 seconds)
                              ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
                              :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 102.38 miliseconds (0.10238 seconds)
                              ::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
                              Font Installer: Fonts STI Custom Hook 1.6 Release
                              :: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 112.804 miliseconds (0.112804 seconds)
                              ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
                              CustomHooksTester -> In InstallPreSystemCheckProc
                              :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 106.064 miliseconds (0.106064 seconds)
                              ::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
                              [     108] Thu May 06 15:09:05 2010  INFO
                              :: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 127.391 miliseconds (0.127391 seconds)
                              ::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
                              :: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 123.597 miliseconds (0.123597 seconds)
                              ::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
                              :: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 149.722 miliseconds (0.149722 seconds)
                              ::START TIMER:: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}]
                              :: END TIMER :: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 202.609 miliseconds (0.202609 seconds)
                              ::START TIMER:: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}]
                              [     108] Thu May 06 15:09:06 2010  INFO
                              :: END TIMER :: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}] took 103.213 miliseconds (0.103213 seconds)
                              ::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
                              :: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 90.6681 miliseconds (0.0906681 seconds)
                              ::START TIMER:: [System check :{DE60F0DE-469A-42DC-A678-978313210057}]
                              :: END TIMER :: [System check :{DE60F0DE-469A-42DC-A678-978313210057}] took 106.16 miliseconds (0.10616 seconds)
                              ::START TIMER:: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
                              :: END TIMER :: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 100.802 miliseconds (0.100802 seconds)
                              ::START TIMER:: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}]
                              :: END TIMER :: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}] took 97.5985 miliseconds (0.0975985 seconds)
                              [     108] Thu May 06 15:09:28 2010  INFO
                              Payloads passed preflight validation.
                              Call PreSession Custom Hook
                              Calling the custom action code for pre-install for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
                              ::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
                              [    4384] Thu May 06 15:09:28 2010  INFO
                              Installer Operation: InstallThirdPartyPayloadOperation
                              Installing third party payload
                              Installing payload
                              Attempting to install package from:C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                              [    4384] Thu May 06 15:09:29 2010  INFO
                              Payload is already installed with MSI
                              MsiSourceListAddSource for  C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
                              MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
                              Payload source is not removable so not updating media info
                              Command line arguments:  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
                              1: 0 2: 1033 3: 1252
                              [    4384] Thu May 06 15:09:30 2010  INFO
                              === Logging started: 06.05.2010  15:09:30 ===
                              Message type: 0, Argument: 1033
                              Message type: 1, Argument: Microsoft_VC90_CRT_x86
                              Action 15:09:30: INSTALL.
                              Action start 15:09:30: INSTALL.
                              Action 15:09:30: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                              Action start 15:09:30: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                              Action ended 15:09:30: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                              Action 15:09:30: AppSearch. Searching for installed applications
                              Action start 15:09:30: AppSearch.
                              Action ended 15:09:30: AppSearch. Return value 0.
                              Action 15:09:30: FindRelatedProducts. Searching for related applications
                              Action start 15:09:30: FindRelatedProducts.
                              Action ended 15:09:30: FindRelatedProducts. Return value 0.
                              Action 15:09:30: ValidateProductID.
                              Action start 15:09:30: ValidateProductID.
                              Action ended 15:09:30: ValidateProductID. Return value 1.
                              Action 15:09:30: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                              Action start 15:09:30: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
                              Action ended 15:09:30: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
                              Action 15:09:30: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                              Action start 15:09:30: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF.
                              Action ended 15:09:30: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF. Return value 1.
                              Action 15:09:30: CostInitialize. Computing space requirements
                              Action start 15:09:30: CostInitialize.
                              Action ended 15:09:30: CostInitialize. Return value 1.
                              Action 15:09:30: FileCost. Computing space requirements
                              Action start 15:09:30: FileCost.
                              Action ended 15:09:30: FileCost. Return value 1.
                              Action 15:09:30: IsolateComponents.
                              Action start 15:09:30: IsolateComponents.
                              Action ended 15:09:30: IsolateComponents. Return value 0.
                              Action 15:09:30: CostFinalize. Computing space requirements
                              Action start 15:09:30: CostFinalize.
                              Action ended 15:09:30: CostFinalize. Return value 1.
                              Action 15:09:30: SetODBCFolders. Initializing ODBC directories
                              Action start 15:09:30: SetODBCFolders.
                              Action ended 15:09:30: SetODBCFolders. Return value 0.
                              Action 15:09:30: MigrateFeatureStates. Migrating feature states from related applications
                              Action start 15:09:30: MigrateFeatureStates.
                              Action ended 15:09:30: MigrateFeatureStates. Return value 0.
                              Action 15:09:30: InstallValidate. Validating install
                              Action start 15:09:30: InstallValidate.
                              [    4384] Thu May 06 15:09:34 2010  INFO
                              Action ended 15:09:34: InstallValidate. Return value 1.
                              Action 15:09:34: RemoveExistingProducts. Removing applications
                              Action start 15:09:34: RemoveExistingProducts.
                              Action ended 15:09:34: RemoveExistingProducts. Return value 0.
                              Action 15:09:34: InstallInitialize.
                              Action start 15:09:34: InstallInitialize.
                              Action ended 15:09:34: InstallInitialize. Return value 1.
                              Action 15:09:34: ProcessComponents. Updating component registration
                              Action start 15:09:34: ProcessComponents.
                              Action 15:09:34: GenerateScript. Generating script operations for action:
                              Action ended 15:09:34: ProcessComponents. Return value 1.
                              Action 15:09:34: UnpublishComponents. Unpublishing Qualified Components
                              Action start 15:09:34: UnpublishComponents.
                              Action ended 15:09:34: UnpublishComponents. Return value 0.
                              Action 15:09:34: MsiUnpublishAssemblies. Unpublishing assembly information
                              Action start 15:09:34: MsiUnpublishAssemblies.
                              Action ended 15:09:34: MsiUnpublishAssemblies. Return value 1.
                              Action 15:09:34: UnpublishFeatures. Unpublishing product features
                              Action start 15:09:34: UnpublishFeatures.
                              Action ended 15:09:34: UnpublishFeatures. Return value 1.
                              Action 15:09:34: StopServices. Stopping services
                              Action start 15:09:34: StopServices.
                              Action ended 15:09:34: StopServices. Return value 1.
                              Action 15:09:34: DeleteServices. Deleting services
                              Action start 15:09:34: DeleteServices.
                              Action ended 15:09:34: DeleteServices. Return value 1.
                              Action 15:09:34: UnregisterComPlus. Unregistering COM+ Applications and Components
                              Action start 15:09:34: UnregisterComPlus.
                              Action ended 15:09:34: UnregisterComPlus. Return value 0.
                              Action 15:09:34: SelfUnregModules. Unregistering modules
                              Action start 15:09:34: SelfUnregModules.
                              Action ended 15:09:34: SelfUnregModules. Return value 1.
                              Action 15:09:34: UnregisterTypeLibraries. Unregistering type libraries
                              Action start 15:09:34: UnregisterTypeLibraries.
                              Action ended 15:09:34: UnregisterTypeLibraries. Return value 0.
                              Action 15:09:34: RemoveODBC. Removing ODBC components
                              Action start 15:09:34: RemoveODBC.
                              Action ended 15:09:34: RemoveODBC. Return value 1.
                              Action 15:09:34: UnregisterFonts. Unregistering fonts
                              Action start 15:09:34: UnregisterFonts.
                              Action ended 15:09:34: UnregisterFonts. Return value 1.
                              Action 15:09:34: RemoveRegistryValues. Removing system registry values
                              Action start 15:09:34: RemoveRegistryValues.
                              Action ended 15:09:34: RemoveRegistryValues. Return value 1.
                              Action 15:09:34: UnregisterClassInfo. Unregister class servers
                              Action start 15:09:34: UnregisterClassInfo.
                              Action ended 15:09:34: UnregisterClassInfo. Return value 0.
                              Action 15:09:34: UnregisterExtensionInfo. Unregistering extension servers
                              Action start 15:09:34: UnregisterExtensionInfo.
                              Action ended 15:09:34: UnregisterExtensionInfo. Return value 0.
                              Action 15:09:34: UnregisterProgIdInfo. Unregistering program identifiers
                              Action start 15:09:34: UnregisterProgIdInfo.
                              Action ended 15:09:34: UnregisterProgIdInfo. Return value 0.
                              Action 15:09:34: UnregisterMIMEInfo. Unregistering MIME info
                              Action start 15:09:34: UnregisterMIMEInfo.
                              Action ended 15:09:34: UnregisterMIMEInfo. Return value 0.
                              Action 15:09:34: RemoveIniValues. Removing INI file entries
                              Action start 15:09:34: RemoveIniValues.
                              Action ended 15:09:34: RemoveIniValues. Return value 1.
                              Action 15:09:34: RemoveShortcuts. Removing shortcuts
                              Action start 15:09:34: RemoveShortcuts.
                              Action ended 15:09:34: RemoveShortcuts. Return value 0.
                              Action 15:09:34: RemoveEnvironmentStrings. Updating environment strings
                              Action start 15:09:34: RemoveEnvironmentStrings.
                              Action ended 15:09:34: RemoveEnvironmentStrings. Return value 1.
                              Action 15:09:34: RemoveDuplicateFiles. Removing duplicated files
                              Action start 15:09:34: RemoveDuplicateFiles.
                              Action ended 15:09:34: RemoveDuplicateFiles. Return value 1.
                              Action 15:09:34: RemoveFiles. Removing files
                              Action start 15:09:34: RemoveFiles.
                              Action ended 15:09:34: RemoveFiles. Return value 0.
                              Action 15:09:34: RemoveFolders. Removing folders
                              Action start 15:09:34: RemoveFolders.
                              Action ended 15:09:34: RemoveFolders. Return value 0.
                              Action 15:09:34: CreateFolders. Creating folders
                              Action start 15:09:34: CreateFolders.
                              Action ended 15:09:34: CreateFolders. Return value 0.
                              Action 15:09:34: MoveFiles. Moving files
                              Action start 15:09:34: MoveFiles.
                              Action ended 15:09:34: MoveFiles. Return value 1.
                              Action 15:09:34: InstallFiles. Copying new files
                              Action start 15:09:34: InstallFiles.
                              File: Copying new files,  Directory: ,  Size:
                              Action ended 15:09:34: InstallFiles. Return value 1.
                              Action 15:09:34: PatchFiles. Patching files
                              Action start 15:09:34: PatchFiles.
                              Action ended 15:09:34: PatchFiles. Return value 0.
                              Action 15:09:34: DuplicateFiles. Creating duplicate files
                              Action start 15:09:34: DuplicateFiles.
                              Action ended 15:09:34: DuplicateFiles. Return value 1.
                              Action 15:09:34: BindImage. Binding executables
                              Action start 15:09:34: BindImage.
                              Action ended 15:09:34: BindImage. Return value 1.
                              Action 15:09:34: CreateShortcuts. Creating shortcuts
                              Action start 15:09:34: CreateShortcuts.
                              Shortcut: Creating shortcuts
                              Action ended 15:09:34: CreateShortcuts. Return value 0.
                              Action 15:09:34: RegisterClassInfo. Registering class servers
                              Action start 15:09:34: RegisterClassInfo.
                              Action ended 15:09:34: RegisterClassInfo. Return value 0.
                              Action 15:09:34: RegisterExtensionInfo. Registering extension servers
                              Action start 15:09:34: RegisterExtensionInfo.
                              Action ended 15:09:34: RegisterExtensionInfo. Return value 0.
                              Action 15:09:34: RegisterProgIdInfo. Registering program identifiers
                              Action start 15:09:34: RegisterProgIdInfo.
                              Action ended 15:09:34: RegisterProgIdInfo. Return value 0.
                              Action 15:09:34: RegisterMIMEInfo. Registering MIME info
                              Action start 15:09:34: RegisterMIMEInfo.
                              Action ended 15:09:34: RegisterMIMEInfo. Return value 0.
                              Action 15:09:34: WriteRegistryValues. Writing system registry values
                              Action start 15:09:34: WriteRegistryValues.
                              Action ended 15:09:34: WriteRegistryValues. Return value 1.
                              Action 15:09:34: WriteIniValues. Writing INI file values
                              Action start 15:09:34: WriteIniValues.
                              Action ended 15:09:34: WriteIniValues. Return value 1.
                              Action 15:09:34: WriteEnvironmentStrings. Updating environment strings
                              Action start 15:09:34: WriteEnvironmentStrings.
                              Action ended 15:09:34: WriteEnvironmentStrings. Return value 1.
                              Action 15:09:34: RegisterFonts. Registering fonts
                              Action start 15:09:34: RegisterFonts.
                              Action ended 15:09:34: RegisterFonts. Return value 1.
                              Action 15:09:34: InstallODBC. Installing ODBC components
                              Action start 15:09:34: InstallODBC.
                              Action ended 15:09:34: InstallODBC. Return value 0.
                              Action 15:09:34: RegisterTypeLibraries. Registering type libraries
                              Action start 15:09:34: RegisterTypeLibraries.
                              Action ended 15:09:34: RegisterTypeLibraries. Return value 0.
                              Action 15:09:34: SelfRegModules. Registering modules
                              Action start 15:09:34: SelfRegModules.
                              Action ended 15:09:34: SelfRegModules. Return value 1.
                              Action 15:09:34: RegisterComPlus. Registering COM+ Applications and Components
                              Action start 15:09:34: RegisterComPlus.
                              Action ended 15:09:34: RegisterComPlus. Return value 0.
                              Action 15:09:34: InstallServices. Installing new services
                              Action start 15:09:34: InstallServices.
                              Action ended 15:09:34: InstallServices. Return value 1.
                              Action 15:09:34: StartServices. Starting services
                              Action start 15:09:34: StartServices.
                              Action ended 15:09:34: StartServices. Return value 1.
                              Action 15:09:34: RegisterUser. Registering user
                              Action start 15:09:34: RegisterUser.
                              Action ended 15:09:34: RegisterUser. Return value 0.
                              Action 15:09:34: RegisterProduct. Registering product
                              Action start 15:09:34: RegisterProduct.
                              Registering product
                              Action ended 15:09:34: RegisterProduct. Return value 1.
                              Action 15:09:34: PublishComponents. Publishing qualified components
                              Action start 15:09:34: PublishComponents.
                              Action ended 15:09:34: PublishComponents. Return value 0.
                              Action 15:09:34: MsiPublishAssemblies. Publishing assembly information
                              Action start 15:09:34: MsiPublishAssemblies.
                              Application Context:Publishing assembly information, Assembly Name:
                              Action ended 15:09:34: MsiPublishAssemblies. Return value 1.
                              Action 15:09:34: PublishFeatures. Publishing product features
                              Action start 15:09:34: PublishFeatures.
                              Feature: Publishing product features
                              Action ended 15:09:34: PublishFeatures. Return value 1.
                              Action 15:09:34: PublishProduct. Publishing product information
                              Action start 15:09:34: PublishProduct.
                              Action ended 15:09:34: PublishProduct. Return value 1.
                              Action 15:09:34: InstallFinalize.
                              Action start 15:09:34: InstallFinalize.
                              Shortcut: ARPPRODUCTICON.exe
                              6be56e.msi
                              Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",proces sorArchitecture="x86",type="win32"
                              Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18 e3b",processorArchitecture="x86",type="win32-policy"
                              Feature: Microsoft_VC90_CRT_x86_
                              Message type: 2, Argument: 0
                              Action 15:09:34: RollbackCleanup. Removing backup files
                              File: C:\Config.Msi\b2af89.rbf
                              File: C:\Config.Msi\b2af8a.rbf
                              Message type: 2, Argument: 1
                              Action ended 15:09:34: InstallFinalize. Return value 1.
                              Action ended 15:09:34: INSTALL. Return value 1.
                              Property(S): DiskPrompt = [1]
                              Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
                              Property(S): Installed = 2009/07/27 18:12:16
                              Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
                              Property(S): SOURCEDIR = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                              Property(S): PrimaryVolumeSpaceRemaining = 0
                              Property(S): PrimaryVolumeSpaceRequired = 0
                              Property(S): PrimaryVolumeSpaceAvailable = 0
                              Property(S): OutOfNoRbDiskSpace = 0
                              Property(S): OutOfDiskSpace = 0
                              Property(S): CostingComplete = 1
                              Property(S): ROOTDRIVE = F:\
                              Property(S): ACTION = INSTALL
                              Property(S): Preselected = 1
                              Property(S): QFEUpgrade = 1
                              Property(S): UILevel = 2
                              Property(S): OriginalDatabase = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                              Property(S): DATABASE = C:\Windows\Installer\b2af83.msi
                              Property(S): Privileged = 1
                              Property(S): MsiRunningElevated = 1
                              Property(S): RedirectedDllSupport = 2
                              Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                              Property(S): MsiNetAssemblySupport = 2.0.50727.4927
                              Property(S): Date = 06/05/2010
                              Property(S): Time = 15:09:34
                              Property(S): TTCSupport = 1
                              Property(S): ColorBits = 32
                              Property(S): TextInternalLeading = 3
                              Property(S): TextHeight = 16
                              Property(S): BorderSide = 1
                              Property(S): BorderTop = 1
                              Property(S): CaptionHeight = 22
                              Property(S): ScreenY = 768
                              Property(S): ScreenX = 1024
                              Property(S): SystemLanguageID = 1048
                              Property(S): ComputerName = FLORIN-PC
                              Property(S): UserLanguageID = 1048
                              Property(S): UserSID = S-1-5-21-3988801501-2864525910-3815404259-1000
                              Property(S): LogonUser = FLORIN
                              Property(S): MsiTrueAdminUser = 1
                              Property(S): AdminUser = 1
                              Property(S): VirtualMemory = 3775
                              Property(S): PhysicalMemory = 2812
                              Property(S): Intel = 16
                              Property(S): Msix64 = 16
                              Property(S): MsiAMD64 = 16
                              Property(S): ShellAdvtSupport = 1
                              Property(S): OLEAdvtSupport = 1
                              Property(S): GPTSupport = 1
                              Property(S): VersionNT = 601
                              Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                              Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                              Property(S): TARGETDIR = F:\
                              Property(S): ALLUSERSPROFILE = F:\
                              Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                              Property(S): AppDataFolder = C:\Users\FLORIN\AppData\Roaming\
                              Property(S): CommonAppDataFolder = C:\ProgramData\
                              Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                              Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                              Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                              Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                              Property(S): DesktopFolder = C:\Users\Public\Desktop\
                              Property(S): FavoritesFolder = C:\Users\FLORIN\Favorites\
                              Property(S): FontsFolder = C:\Windows\Fonts\
                              Property(S): GlobalAssemblyCache = F:\
                              Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                              Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                              Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                              Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                              Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                              Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                              Property(S): LocalAppDataFolder = C:\Users\FLORIN\AppData\Local\
                              Property(S): MyPicturesFolder = C:\Users\FLORIN\Pictures\
                              Property(S): PersonalFolder = C:\Users\FLORIN\Documents\
                              Property(S): PrimaryVolumePath = F:\
                              Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                              Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                              Property(S): SendToFolder = C:\Users\FLORIN\AppData\Roaming\Microsoft\Windows\SendTo\
                              Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                              Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                              Property(S): System16Folder = F:\
                              Property(S): System64Folder = C:\Windows\SysWOW64\
                              Property(S): SystemFolder = C:\Windows\SysWOW64\
                              Property(S): SourceDir = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
                              Property(S): TempFolder = C:\Users\FLORIN\AppData\Local\Temp\
                              Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                              Property(S): USERPROFILE = F:\
                              Property(S): WindowsFolder = C:\Windows\
                              Property(S): WindowsVolume = C:\
                              Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\
                              Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\SysWOW64\
                              Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\
                              Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_508fc1d4bcb b3eca\
                              Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_d494ac0e\
                              Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B 7 = C:\Windows\winsxs\Manifests\
                              Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
                              Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                              Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
                              Property(S): ALLUSERS = 1
                              Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_ 7544A81A5FCF = C:\Windows\winsxs\
                              Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A 81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ f47d3254f657e518\
                              Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7 544A81A5FCF = C:\Windows\winsxs\Policies\
                              Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A8 1A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f 75\
                              Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_75 44A81A5FCF = C:\Windows\
                              Property(S): RecentFolder = C:\Users\FLORIN\AppData\Roaming\Microsoft\Windows\Recent\
                              Property(S): PrintHoodFolder = C:\Users\FLORIN\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                              Property(S): NetHoodFolder = C:\Users\FLORIN\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                              Property(S): RemoteAdminTS = 1
                              Property(S): MsiNTProductType = 1
                              Property(S): ServicePackLevelMinor = 0
                              Property(S): ServicePackLevel = 0
                              Property(S): WindowsBuild = 7600
                              Property(S): ISCHECKFORPRODUCTUPDATES = 1
                              Property(S): ApplicationUsers = AllUsers
                              Property(S): AgreeToLicense = No
                              Property(S): _IsMaintenance = Change
                              Property(S): SetupType = Typical
                              Property(S): _IsSetupTypeMin = Typical
                              Property(S): IS_SQLSERVER_USERNAME = sa
                              Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                              Property(S): RestartManagerOption = CloseRestart
                              Property(S): Display_IsBitmapDlg = 1
                              Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                              Property(S): DefaultUIFont = Tahoma8
                              Property(S): DialogCaption = InstallShield for Windows Installer
                              Property(S): DisplayNameCustom = Custom
                              Property(S): DisplayNameMinimal = Minimal
                              Property(S): DisplayNameTypical = Typical
                              Property(S): DWUSINTERVAL = 30
                              Property(S): ErrorDialog = SetupError
                              Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                              Property(S): InstallChoice = AR
                              Property(S): INSTALLLEVEL = 100
                              Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                              Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                              Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                              Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                              Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                              Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                              Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                              Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                              Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                              Property(S): ISVROOT_PORT_NO = 0
                              Property(S): Manufacturer = Adobe
                              Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                              Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
                              Property(S): ProductID = none
                              Property(S): ProductLanguage = 1033
                              Property(S): ProductName = Microsoft_VC90_CRT_x86
                              Property(S): ProductVersion = 1.00.0000
                              Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                              Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                              Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                              Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                              Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                              Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                              Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                              Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                              Property(S): ProgressType0 = install
                              Property(S): ProgressType1 = Installing
                              Property(S): ProgressType2 = installed
                              Property(S): ProgressType3 = installs
                              Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                              Property(S): RebootYesNo = Yes
                              Property(S): ReinstallModeText = omus
                              Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                              Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                              Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                              Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                              Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                              Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                              Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                              Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                              Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                              Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                              Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD0A8FEAC
                              Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                              Property(S): SHOWLAUNCHPROGRAM = 0
                              Property(S): VersionNT64 = 601
                              [    4384] Thu May 06 15:09:35 2010  INFO
                              Property(S): REBOOT = ReallySuppress
                              Property(S): ARPSYSTEMCOMPONENT = 1
                              Property(S): VersionMsi = 5.00
                              Property(S): VersionDatabase = 200
                              Property(S): PRODUCTLANGUAGE = 1033
                              Property(S): CLIENTPROCESSID = 4920
                              Property(S): MSICLIENTUSESEXTERNALUI = 1
                              Property(S): CLIENTUILEVEL = 3
                              Property(S): CURRENTDIRECTORY = C:\Users\FLORIN\AppData\Local\Adobe\OOBE\PDApp\DWA
                              Property(S): REINSTALLMODE = pvoums
                              Property(S): REINSTALL = ALL
                              Property(S): COMPANYNAME = Hewlett-Packard
                              Property(S): ProductToBeRegistered = 1
                              Property(S): USERNAME = FLORIN
                              Property(S): ProductState = 5
                              Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
                              === Logging stopped: 06.05.2010  15:09:35 ===
                              1: 2 2: 0
                              1: 2 2: 1
                              Installation result: 0
                              Third party payload succeded.  Testing return code: 0
                              [     108] Thu May 06 15:09:36 2010  INFO
                              *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                              :: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 7024.86 miliseconds (7.02486 seconds)
                              Updating driver data - Action: Add driver entry
                              Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                              User specified overrideFile:
                              Calling the custom action code for post-install for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
                              Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                              ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
                              [    1348] Thu May 06 15:09:36 2010  INFO
                              Installing payload
                              Attempting to install package from:C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                              MsiSourceListAddSource for  C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
                              MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
                              === Logging started: 06.05.2010  15:09:36 ===
                              Message type: 1, Argument: Microsoft_VC80_CRT_x86
                              Action 15:09:36: INSTALL.
                              Action start 15:09:36: INSTALL.
                              Action 15:09:36: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                              Action start 15:09:36: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                              Action ended 15:09:36: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                              Action 15:09:36: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                              Action start 15:09:36: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                              Action ended 15:09:36: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                              Action 15:09:36: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                              Action start 15:09:36: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                              Action ended 15:09:36: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                              Action 15:09:36: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                              Action start 15:09:36: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                              Action ended 15:09:36: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                              Action 15:09:36: AppSearch. Searching for installed applications
                              Action start 15:09:36: AppSearch.
                              Action ended 15:09:36: AppSearch. Return value 0.
                              Action 15:09:36: FindRelatedProducts. Searching for related applications
                              Action start 15:09:36: FindRelatedProducts.
                              Action ended 15:09:36: FindRelatedProducts. Return value 0.
                              Action 15:09:36: ValidateProductID.
                              Action start 15:09:36: ValidateProductID.
                              Action ended 15:09:36: ValidateProductID. Return value 1.
                              Action 15:09:36: CostInitialize. Computing space requirements
                              Action start 15:09:36: CostInitialize.
                              Action ended 15:09:36: CostInitialize. Return value 1.
                              Action 15:09:36: FileCost. Computing space requirements
                              Action start 15:09:36: FileCost.
                              Action ended 15:09:36: FileCost. Return value 1.
                              Action 15:09:36: IsolateComponents.
                              Action start 15:09:36: IsolateComponents.
                              Action ended 15:09:36: IsolateComponents. Return value 0.
                              Action 15:09:36: CostFinalize. Computing space requirements
                              Action start 15:09:36: CostFinalize.
                              Action ended 15:09:36: CostFinalize. Return value 1.
                              Action 15:09:36: SetODBCFolders. Initializing ODBC directories
                              Action start 15:09:36: SetODBCFolders.
                              Action ended 15:09:36: SetODBCFolders. Return value 0.
                              Action 15:09:36: MigrateFeatureStates. Migrating feature states from related applications
                              Action start 15:09:36: MigrateFeatureStates.
                              Action ended 15:09:36: MigrateFeatureStates. Return value 0.
                              Action 15:09:36: InstallValidate. Validating install
                              Action start 15:09:36: InstallValidate.
                              [    1348] Thu May 06 15:09:37 2010  INFO
                              Action ended 15:09:37: InstallValidate. Return value 1.
                              Action 15:09:37: RemoveExistingProducts. Removing applications
                              Action start 15:09:37: RemoveExistingProducts.
                              Action ended 15:09:37: RemoveExistingProducts. Return value 0.
                              Action 15:09:37: InstallInitialize.
                              Action start 15:09:37: InstallInitialize.
                              Action ended 15:09:37: InstallInitialize. Return value 1.
                              Action 15:09:37: SxsInstallCA.
                              Action start 15:09:37: SxsInstallCA.
                              1: sxsdelca 2: traceop 3: 1256 4: 0
                              1: sxsdelca 2: traceop 3: 1257 4: 0
                              1: sxsdelca 2: traceop 3: 1258 4: 0
                              1: sxsdelca 2: traceop 3: 1284 4: 0
                              1: sxsdelca 2: traceop 3: 1288 4: 0
                              1: sxsdelca 2: traceop 3: 1289 4: 0
                              1: sxsdelca 2: traceop 3: 1290 4: 0
                              1: sxsdelca 2: traceop 3: 1292 4: 0
                              1: sxsdelca 2: traceop 3: 1318 4: 0
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              [    1348] Thu May 06 15:09:38 2010  INFO
                              1: sxsdelca: Skipping component  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                              1: sxsdelca 2: traceop 3: 1284 4: 259
                              1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                              Action ended 15:09:38: SxsInstallCA. Return value 1.
                              Action 15:09:38: ProcessComponents. Updating component registration
                              Action start 15:09:38: ProcessComponents.
                              Action 15:09:38: GenerateScript. Generating script operations for action:
                              Action ended 15:09:38: ProcessComponents. Return value 1.
                              Action 15:09:38: UnpublishComponents. Unpublishing Qualified Components
                              Action start 15:09:38: UnpublishComponents.
                              Action ended 15:09:38: UnpublishComponents. Return value 0.
                              Action 15:09:38: MsiUnpublishAssemblies. Unpublishing assembly information
                              Action start 15:09:38: MsiUnpublishAssemblies.
                              Action ended 15:09:38: MsiUnpublishAssemblies. Return value 1.
                              Action 15:09:38: UnpublishFeatures. Unpublishing product features
                              Action start 15:09:38: UnpublishFeatures.
                              Action ended 15:09:38: UnpublishFeatures. Return value 1.
                              Action 15:09:38: StopServices. Stopping services
                              Action start 15:09:38: StopServices.
                              Action ended 15:09:38: StopServices. Return value 1.
                              Action 15:09:38: DeleteServices. Deleting services
                              Action start 15:09:38: DeleteServices.
                              Action ended 15:09:38: DeleteServices. Return value 1.
                              Action 15:09:38: UnregisterComPlus. Unregistering COM+ Applications and Components
                              Action start 15:09:38: UnregisterComPlus.
                              Action ended 15:09:38: UnregisterComPlus. Return value 0.
                              Action 15:09:38: SelfUnregModules. Unregistering modules
                              Action start 15:09:38: SelfUnregModules.
                              Action ended 15:09:38: SelfUnregModules. Return value 1.
                              Action 15:09:38: UnregisterTypeLibraries. Unregistering type libraries
                              Action start 15:09:38: UnregisterTypeLibraries.
                              Action ended 15:09:38: UnregisterTypeLibraries. Return value 0.
                              Action 15:09:38: RemoveODBC. Removing ODBC components
                              Action start 15:09:38: RemoveODBC.
                              Action ended 15:09:38: RemoveODBC. Return value 1.
                              Action 15:09:38: UnregisterFonts. Unregistering fonts
                              Action start 15:09:38: UnregisterFonts.
                              Action ended 15:09:38: UnregisterFonts. Return value 1.
                              Action 15:09:38: RemoveRegistryValues. Removing system registry values
                              Action start 15:09:38: RemoveRegistryValues.
                              Action ended 15:09:38: RemoveRegistryValues. Return value 1.
                              Action 15:09:38: UnregisterClassInfo. Unregister class servers
                              Action start 15:09:38: UnregisterClassInfo.
                              Action ended 15:09:38: UnregisterClassInfo. Return value 0.
                              Action 15:09:38: UnregisterExtensionInfo. Unregistering extension servers
                              Action start 15:09:38: UnregisterExtensionInfo.
                              Action ended 15:09:38: UnregisterExtensionInfo. Return value 0.
                              Action 15:09:38: UnregisterProgIdInfo. Unregistering program identifiers
                              Action start 15:09:38: UnregisterProgIdInfo.
                              Action ended 15:09:38: UnregisterProgIdInfo. Return value 0.
                              Action 15:09:38: UnregisterMIMEInfo. Unregistering MIME info
                              Action start 15:09:38: UnregisterMIMEInfo.
                              Action ended 15:09:38: UnregisterMIMEInfo. Return value 0.
                              Action 15:09:38: RemoveIniValues. Removing INI file entries
                              Action start 15:09:38: RemoveIniValues.
                              Action ended 15:09:38: RemoveIniValues. Return value 1.
                              Action 15:09:38: RemoveShortcuts. Removing shortcuts
                              Action start 15:09:38: RemoveShortcuts.
                              Action ended 15:09:38: RemoveShortcuts. Return value 0.
                              Action 15:09:38: RemoveEnvironmentStrings. Updating environment strings
                              Action start 15:09:38: RemoveEnvironmentStrings.
                              Action ended 15:09:38: RemoveEnvironmentStrings. Return value 1.
                              Action 15:09:38: RemoveDuplicateFiles. Removing duplicated files
                              Action start 15:09:38: RemoveDuplicateFiles.
                              Action ended 15:09:38: RemoveDuplicateFiles. Return value 1.
                              Action 15:09:38: RemoveFiles. Removing files
                              Action start 15:09:38: RemoveFiles.
                              Action ended 15:09:38: RemoveFiles. Return value 0.
                              Action 15:09:38: RemoveFolders. Removing folders
                              Action start 15:09:38: RemoveFolders.
                              Action ended 15:09:38: RemoveFolders. Return value 0.
                              Action 15:09:38: CreateFolders. Creating folders
                              Action start 15:09:38: CreateFolders.
                              Action ended 15:09:38: CreateFolders. Return value 0.
                              Action 15:09:38: MoveFiles. Moving files
                              Action start 15:09:38: MoveFiles.
                              Action ended 15:09:38: MoveFiles. Return value 1.
                              Action 15:09:38: InstallFiles. Copying new files
                              Action start 15:09:38: InstallFiles.
                              [    1348] Thu May 06 15:09:39 2010  INFO
                              Action ended 15:09:39: InstallFiles. Return value 1.
                              Action 15:09:39: PatchFiles. Patching files
                              Action start 15:09:39: PatchFiles.
                              Action ended 15:09:39: PatchFiles. Return value 0.
                              Action 15:09:39: DuplicateFiles. Creating duplicate files
                              Action start 15:09:39: DuplicateFiles.
                              Action ended 15:09:39: DuplicateFiles. Return value 1.
                              Action 15:09:39: BindImage. Binding executables
                              Action start 15:09:39: BindImage.
                              Action ended 15:09:39: BindImage. Return value 1.
                              Action 15:09:39: CreateShortcuts. Creating shortcuts
                              Action start 15:09:39: CreateShortcuts.
                              Action ended 15:09:39: CreateShortcuts. Return value 0.
                              Action 15:09:39: RegisterClassInfo. Registering class servers
                              Action start 15:09:39: RegisterClassInfo.
                              Action ended 15:09:39: RegisterClassInfo. Return value 0.
                              Action 15:09:39: RegisterExtensionInfo. Registering extension servers
                              Action start 15:09:39: RegisterExtensionInfo.
                              Action ended 15:09:39: RegisterExtensionInfo. Return value 0.
                              Action 15:09:39: RegisterProgIdInfo. Registering program identifiers
                              Action start 15:09:39: RegisterProgIdInfo.
                              Action ended 15:09:39: RegisterProgIdInfo. Return value 0.
                              Action 15:09:39: RegisterMIMEInfo. Registering MIME info
                              Action start 15:09:39: RegisterMIMEInfo.
                              Action ended 15:09:39: RegisterMIMEInfo. Return value 0.
                              Action 15:09:39: WriteRegistryValues. Writing system registry values
                              Action start 15:09:39: WriteRegistryValues.
                              Action ended 15:09:39: WriteRegistryValues. Return value 1.
                              Action 15:09:39: WriteIniValues. Writing INI file values
                              Action start 15:09:39: WriteIniValues.
                              Action ended 15:09:39: WriteIniValues. Return value 1.
                              Action 15:09:39: WriteEnvironmentStrings. Updating environment strings
                              Action start 15:09:39: WriteEnvironmentStrings.
                              Action ended 15:09:39: WriteEnvironmentStrings. Return value 1.
                              Action 15:09:39: RegisterFonts. Registering fonts
                              Action start 15:09:39: RegisterFonts.
                              Action ended 15:09:39: RegisterFonts. Return value 1.
                              Action 15:09:39: InstallODBC. Installing ODBC components
                              Action start 15:09:39: InstallODBC.
                              Action ended 15:09:39: InstallODBC. Return value 0.
                              Action 15:09:39: RegisterTypeLibraries. Registering type libraries
                              Action start 15:09:39: RegisterTypeLibraries.
                              Action ended 15:09:39: RegisterTypeLibraries. Return value 0.
                              Action 15:09:39: SelfRegModules. Registering modules
                              Action start 15:09:39: SelfRegModules.
                              Action ended 15:09:39: SelfRegModules. Return value 1.
                              Action 15:09:39: RegisterComPlus. Registering COM+ Applications and Components
                              Action start 15:09:39: RegisterComPlus.
                              Action ended 15:09:39: RegisterComPlus. Return value 0.
                              Action 15:09:39: InstallServices. Installing new services
                              Action start 15:09:39: InstallServices.
                              Action ended 15:09:39: InstallServices. Return value 1.
                              Action 15:09:39: StartServices. Starting services
                              Action start 15:09:39: StartServices.
                              Action ended 15:09:39: StartServices. Return value 1.
                              Action 15:09:39: RegisterUser. Registering user
                              Action start 15:09:39: RegisterUser.
                              Action ended 15:09:39: RegisterUser. Return value 0.
                              Action 15:09:39: RegisterProduct. Registering product
                              Action start 15:09:39: RegisterProduct.
                              Registering product
                              Action ended 15:09:39: RegisterProduct. Return value 1.
                              Action 15:09:39: PublishComponents. Publishing qualified components
                              Action start 15:09:39: PublishComponents.
                              Action ended 15:09:39: PublishComponents. Return value 0.
                              Action 15:09:39: MsiPublishAssemblies. Publishing assembly information
                              Action start 15:09:39: MsiPublishAssemblies.
                              Action ended 15:09:39: MsiPublishAssemblies. Return value 1.
                              Action 15:09:39: PublishFeatures. Publishing product features
                              Action start 15:09:39: PublishFeatures.
                              Action ended 15:09:39: PublishFeatures. Return value 1.
                              Action 15:09:39: PublishProduct. Publishing product information
                              Action start 15:09:39: PublishProduct.
                              Action ended 15:09:39: PublishProduct. Return value 1.
                              Action 15:09:39: InstallFinalize.
                              Action start 15:09:39: InstallFinalize.
                              [    1348] Thu May 06 15:09:40 2010  INFO
                              Action 15:09:40: ProcessComponents. Updating component registration
                              Action 15:09:40: RemoveODBC. Removing ODBC components
                              Action 15:09:40: InstallFiles. Copying new files
                              Error 1402.Could not open key: UNKNOWN\Components\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\7E577B2224C65CF4E801A9E52375DB49.   Verify that you have sufficient access to that key, or contact your support personnel.
                              Action ended 15:09:40: InstallFinalize. Return value 3.
                              Action 15:09:40: Rollback. Rolling back action:
                              Copying new files
                              Action ended 15:09:40: INSTALL. Return value 3.
                              Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                              Property(S): SOURCEDIR = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                              Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
                              Property(S): Installed = 2009/11/13 11:21:16
                              Property(S): OriginalDatabase = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                              Property(S): DATABASE = C:\Windows\Installer\b2af8c.msi
                              Property(S): Time = 15:09:40
                              Property(S): VirtualMemory = 3763
                              Property(S): SourceDir = C:\Users\FLORIN\Desktop\Adobe CS5 Master Collection\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                              Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                              Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
                              Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
                              Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
                              Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                              Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                              Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                              Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                              Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
                              Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
                              Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
                              Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
                              Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
                              Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
                              Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
                              Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
                              Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
                              Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
                              Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
                              Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
                              Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
                              Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
                              Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
                              Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
                              Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
                              Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
                              Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
                              Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                              Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
                              Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
                              Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
                              Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
                              Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                              Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                              Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
                              Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                              Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
                              Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                              Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                              Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
                              Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                              Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
                              Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
                              Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
                              Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
                              Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
                              Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
                              Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
                              Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
                              Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
                              Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
                              Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
                              Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
                              Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
                              Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                              Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
                              Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
                              Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
                              Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
                              Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
                              Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
                              Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
                              Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
                              Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
                              Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
                              Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                              Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                              Property(S): ProductName = Microsoft_VC80_CRT_x86
                              Property(S): ProductVersion = 8.0.50727.4053
                              Property(S): RebootYesNo = No
                              Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
                              Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
                              === Logging stopped: 06.05.2010  15:09:40 ===
                              1: 2 2: 0
                              1: 2 2: 1
                              Installation result: 1603
                              Third party payload succeded.  Testing return code: 1603
                              [     108] Thu May 06 15:09:41 2010  INFO
                              *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
                              :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 5003 miliseconds (5.003 seconds) DTR = 23.9856 KBPS (0.0234234 MBPS)
                              Calling the ROLLBACK custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
                              [     108] Thu May 06 15:09:41 2010  WARN
                              Payload cannot be installed due to dependent operation failure
                              Skipping payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 as payload is not cached
                              Skipping payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 as payload is not cached
                              Skipping payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding as payload is not cached
                              Skipping payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 as payload is not cached
                              Skipping payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 as payload is not cached
                              Skipping payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE as payload is not cached
                              Skipping payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer as payload is not cached
                              Skipping payload {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 as payload is not cached
                              Skipping payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 as payload is not cached
                              Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
                              Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
                              Skipping payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 as payload is not cached
                              Skipping payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 as payload is not cached
                              Skipping payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport as payload is not cached
                              Skipping payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule as payload is not cached
                              Skipping payload {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 as payload is not cached
                              Skipping payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 as payload is not cached
                              Skipping payload {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 as payload is not cached
                              Skipping payload {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 as payload is not cached
                              Skipping payload {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 as payload is not cached
                              Skipping payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 as payload is not cached
                              Skipping payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 as payload is not cached
                              Skipping payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp as payload is not cached
                              Skipping payload {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 as payload is not cached
                              Skipping payload {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 as payload is not cached
                              Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
                              Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
                              Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
                              Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
                              Skipping payload {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 as payload is not cached
                              Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
                              Skipping payload {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 as payload is not cached
                              Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
                              Skipping payload {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 as payload is not cached
                              Skipping payload {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 as payload is not cached
                              Skipping payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 as payload is not cached
                              Skipping payload {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 as payload is not cached
                              Skipping payload {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 as payload is not cached
                              Skipping payload {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 as payload is not cached
                              Skipping payload {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 as payload is not cached
                              Skipping payload {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 as payload is not cached
                              Skipping payload {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 as payload is not cached
                              Skipping payload {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support as payload is not cached
                              Skipping payload {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit as payload is not cached
                              Skipping payload {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 as payload is not cached
                              Skipping payload {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files as payload is not cached
                              Skipping payload {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files as payload is not cached
                              Skipping payload {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 as payload is not cached
                              Skipping payload {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph as payload is not cached
                              Skipping payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR as payload is not cached
                              Skipping payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player as payload is not cached
                              Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
                              Payload {1D830E80-28A4-11DF-A025-0024E8692489} can not be installed due to dependent operation failure.
                              Skipping payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB as payload is not cached
                              Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
                              Skipping payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 as payload is not cached
                              Skipping payload {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 as payload is not cached
                              Skipping payload {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension as payload is not cached
                              Skipping payload {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search as payload is not cached
                              Skipping payload {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 as payload is not cached
                              Skipping payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation as payload is not cached
                              Skipping payload {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation as payload is not cached
                              Skipping payload {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages as payload is not cached
                              Skipping payload {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live as payload is not cached
                              Skipping payload {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) as payload is not cached
                              Skipping payload {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 as payload is not cached
                              Skipping payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX as payload is not cached
                              Skipping payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin as payload is not cached
                              Skipping payload {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 as payload is not cached
                              Skipping payload {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 as payload is not cached
                              Skipping payload {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 as payload is not cached
                              Skipping payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 as payload is not cached
                              Skipping payload {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels as payload is not cached
                              Skipping payload {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 as payload is not cached
                              Skipping payload {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro as payload is not cached
                              Payload {955EB78F-C938-4EA8-8470-C6EA71685834} can not be installed due to dependent operation failure.
                              Skipping payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US as payload is not cached
                              Skipping payload {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets as payload is not cached
                              Skipping payload {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support as payload is not cached
                              Skipping payload {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper as payload is not cached
                              Skipping payload {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper as payload is not cached
                              Skipping payload {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 as payload is not cached
                              Skipping payload {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper as payload is not cached
                              Skipping payload {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 as payload is not cached
                              Skipping payload {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler as payload is not cached
                              Skipping payload {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper as payload is not cached
                              Skipping payload {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support as payload is not cached
                              Skipping payload {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 as payload is not cached
                              Skipping payload {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper as payload is not cached
                              Skipping payload {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper as payload is not cached
                              Skipping payload {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 as payload is not cached
                              Skipping payload {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 as payload is not cached
                              Skipping payload {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 as payload is not cached
                              Skipping payload {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 as payload is not cached
                              Skipping payload {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 as payload is not cached
                              Skipping payload {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 as payload is not cached
                              Skipping payload {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro as payload is not cached
                              Skipping payload {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro as payload is not cached
                              Skipping payload {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing as payload is not cached
                              Skipping payload {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 as payload is not cached
                              Skipping payload {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper as payload is not cached
                              Skipping payload {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper as payload is not cached
                              Skipping payload {288DB08D-0708-4A94-B055-55B99E39EB62} Creative Suite 5 Master Collection as payload is not cached
                              Skipping payload {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth as payload is not cached
                              Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} can not be installed due to dependent operation failure.
                              Skipping payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack as payload is not cached
                              Skipping payload {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 as payload is not cached
                              Payload {771C9F59-3F22-4610-A23E-321A98ECA264} can not be installed due to dependent operation failure.
                              Skipping payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack as payload is not cached
                              Skipping payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder as payload is not cached
                              Skipping payload {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 as payload is not cached
                              Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} can not be installed due to dependent operation failure.
                              Skipping payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack as payload is not cached
                              Skipping payload {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 as payload is not cached
                              Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} can not be installed due to dependent operation failure.
                              Skipping payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack as payload is not cached
                              Skipping payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 as payload is not cached
                              Skipping payload {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 as payload is not cached
                              Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} can not be installed due to dependent operation failure.
                              Skipping payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack as payload is not cached
                              Skipping payload {A334FDED-DCCA-481E-B226-F902CCC419D2} Adobe Encore CS5 as payload is not cached
                              Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} can not be installed due to dependent operation failure.
                              Skipping payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack as payload is not cached
                              Skipping payload {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 as payload is not cached
                              Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} can not be installed due to dependent operation failure.
                              Skipping payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack as payload is not cached
                              Skipping payload {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core as payload is not cached
                              Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} can not be installed due to dependent operation failure.
                              Skipping payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB as payload is not cached
                              Skipping payload {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 as payload is not cached
                              Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} can not be installed due to dependent operation failure.
                              Skipping payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 as payload is not cached
                              Skipping payload {DA1B174B-4297-467C-9EF8-0AB8D4D5171E} Adobe After Effects CS5 as payload is not cached
                              Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} can not be installed due to dependent operation failure.
                              Skipping payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack as payload is not cached
                              Skipping payload {C21384F7-1A36-4706-95AB-B09BCE3C144F} Adobe Premiere Pro CS5 as payload is not cached
                              Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} can not be installed due to dependent operation failure.
                              Skipping payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack as payload is not cached
                              Skipping payload {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files as payload is not cached
                              Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} can not be installed due to dependent operation failure.
                              Skipping payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB as payload is not cached
                              Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} can not be installed due to dependent operation failure.
                              Skipping payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US as payload is not cached
                              Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} can not be installed due to dependent operation failure.
                              Skipping payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB as payload is not cached
                              Skipping payload {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 as payload is not cached
                              Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} can not be installed due to dependent operation failure.
                              Skipping payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US as payload is not cached
                              Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} can not be installed due to dependent operation failure.
                              Skipping payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul as payload is not cached
                              Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} can not be installed due to dependent operation failure.
                              Skipping payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack as payload is not cached
                              No operation.  We're done:
                              Updating driver data - Action: Remove driver entry
                              [     108] Thu May 06 15:09:44 2010  INFO
                              Successfully installed 1 component:
                              - Microsoft_VC90_CRT_x86
                              Total components repaired: 0
                              Total components removed: 0
                              [     108] Thu May 06 15:09:44 2010 ERROR
                              The following payload errors were found during install:
                              - Adobe OnLocation CS5 Royalty Content Wrapper: Install failed
                              - Adobe CSXS Infrastructure CS5: Install failed
                              - Microsoft_VC90_ATL_x86: Install failed
                              - Adobe Media Player: Install failed
                              - SiteCatalyst NetAverages: Install failed
                              - Firefox Plugin CS5: Install failed
                              - Adobe Linguistics CS5 x64: Install failed
                              - Adobe Photoshop CS5 Support: Install failed
                              - Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US: Install failed
                              - Adobe Bridge CS5: Install failed
                              - Microsoft_VC80_ATL_x86: Install failed
                              - Recommended Common Fonts Installation x64: Install failed
                              - Adobe Flash CS5_AdobeFlash11-en_USLanguagePack: Install failed
                              - Adobe Toolhints CS5: Install failed
                              - Adobe Fireworks CS5: Failed due to Language Pack installation failure
                              - Adobe Flash Builder: Install failed
                              - AdobePDFL x64 CS5: Install failed
                              - Adobe Encore CS5 Royalty Codecs Installer Wrapper: Install failed
                              - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
                              - Microsoft_VC80_MFCLOC_x86_x64: Install failed
                              - Adobe After Effects CS5 Third Party RoyaltyContent Wrapper: Install failed
                              - Adobe Premiere Pro CS5 Third Party Content Wrapper: Install failed
                              - Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US: Install failed
                              - Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB: Install failed
                              - Creative Suite 5 Master Collection: Install failed
                              - Adobe XMP Panels CS5: Install failed
                              - Adobe Player for Embedding: Install failed
                              - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
                              - Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack: Install failed
                              - Photoshop Camera Raw: Install failed
                              - AdobeColorCommonSetCMYK: Install failed
                              - AdobeHelp: Install failed
                              - Camera Profiles Installer: Install failed
                              - Adobe Buzzword CS5: Install failed
                              - Adobe After Effects CS5 Third Party Content Wrapper: Install failed
                              - Adobe Flash Player 10 Plugin: Install failed
                              - Adobe Mini Bridge CS5: Install failed
                              - Microsoft_VC80_CRT_x86_x64: Install failed
                              - IE Plugin CS5: Install failed
                              - Adobe Soundbooth CS5 Codecs Wrapper: Install failed
                              - Adobe SING CS5: Install failed
                              - AdobeColorJA CS5: Install failed
                              - Adobe ReviewPanel CS5: Install failed
                              - Adobe InDesign CS5 Icon Handler x64: Install failed
                              - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
                              - Adobe BrowserLab CS Live: Install failed
                              - Photoshop Camera Raw (64 bit): Install failed
                              - iPhone Publishing: Install failed
                              - Microsoft_VC90_MFC_x86: Install failed
                              - Adobe After Effects CS5 Support: Install failed
                              - CSXS Story Extension: Install failed
                              - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
                              - Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack: Install failed
                              - Adobe Media Encoder CS5 X64: Install failed
                              - Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack: Install failed
                              - Suite Shared Configuration CS5: Install failed
                              - Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper: Install failed
                              - Adobe Linguistics CS5: Install failed
                              - PDF Settings CS5: Install failed
                              - DeviceCentral: Failed due to Language Pack installation failure
                              - AdobeTypeSupport CS5: Install failed
                              - AdobeColorVideoProfilesCS CS5: Install failed
                              - Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack: Install failed
                              - Adobe Flash Fonts1: Install failed
                              - AdobeColorCommonSetRGB: Install failed
                              - Adobe Player for Embedding x64: Install failed
                              - Office Plugin CS5: Install failed
                              - Adobe Photoshop CS5 Core: Failed due to Language Pack installation failure
                              - Adobe Flash Player 10 ActiveX: Install failed
                              - Required Common Fonts Installation x64: Install failed
                              - Adobe InDesign CS5 Common Base Files: Install failed
                              - Microsoft_VC90_ATL_x86_x64: Install failed
                              - Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
                              - Adobe CSXS Extensions CS5: Install failed
                              - Microsoft_VC80_ATL_x86_x64: Install failed
                              - AdobeOutputModule: Install failed
                              - Microsoft_VC90_CRT_x86_x64: Install failed
                              - Microsoft_VC80_CRT_x86: Install failed
                              - AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US: Install failed
                              - Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB: Install failed
                              - AdobeCMaps x64 CS5: Install failed
                              - AdobeTypeSupport x64 CS5: Install failed
                              - Adobe Illustrator CS5: Failed due to Language Pack installation failure
                              - Adobe Media Encoder CS5 PCI WRAPPER X64: Install failed
                              - Adobe Encore CS5: Failed due to Language Pack installation failure
                              - Microsoft_VC90_MFC_x86_x64: Install failed
                              - Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
                              - AdobeColorVideoProfilesAE CS5: Install failed
                              - DynamiclinkSupport: Install failed
                              - Adobe OnLocation CS5: Failed due to Language Pack installation failure
                              - Adobe Soundbooth CS5 Royalty Codecs Wrapper: Install failed
                              - Adobe WinSoft Linguistics Plugin CS5: Install failed
                              - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
                              - AdobeColorEU CS5: Install failed
                              - Adobe Encore CS5_AdobeEncore5en_USLanguagePack: Install failed
                              - AdobePDFL CS5: Install failed
                              - HIL Help Search: Install failed
                              - AdobeCMaps CS5: Install failed
                              - AdobeColorNA CS5: Install failed
                              - Adobe Premiere Pro CS5: Failed due to Language Pack installation failure
                              - Adobe Dreamweaver CS5: Failed due to Language Pack installation failure
                              - Microsoft_VC80_MFC_x86_x64: Install failed
                              - ph: Install failed
                              - Required Common Fonts Installation: Install failed
                              - Adobe Soundbooth: Failed due to Language Pack installation failure
                              - Adobe After Effects CS5 Presets: Install failed
                              - AmericanEnglishSpeechAnalysisModels: Install failed
                              - Adobe SwitchBoard 2.0: Install failed
                              - Adobe Flash CS5: Failed due to Language Pack installation failure
                              - Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack: Install failed
                              - Microsoft_VC80_MFC_x86: Install failed
                              - AdobeColorPhotoshop CS5: Install failed
                              - Pixel Bender Toolkit: Install failed
                              - Microsoft_VC80_MFCLOC_x86: Install failed
                              - Adobe After Effects CS5: Failed due to Language Pack installation failure
                              - Adobe Contribute CS5: Failed due to Language Pack installation failure
                              - Adobe InDesign CS5 Application Base Files2: Install failed
                              - Players For Adobe Flash Pro: Install failed
                              - Recommended Common Fonts Installation: Install failed
                              - Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack: Install failed
                              - Adobe InDesign CS5 Icon Handler: Install failed
                              - Adobe Extension Manager CS5: Install failed
                              - AdobeJRE: Install failed
                              - Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack: Install failed
                              - Adobe Flash Catalyst CS5: Install failed
                              - Adobe ExtendScript Toolkit CS5: Install failed
                              - TLF For Adobe Flash Pro: Install failed
                              - AdobeMotionPicture CS5: Install failed
                              - Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack: Install failed
                              - Adobe AIR: Install failed
                              - Adobe Premiere Pro CS5 Support: Install failed
                              - Adobe Media Encoder CS5 Dolby WRAPPER X64: Install failed
                              - Adobe InDesign CS5 Application Base Files: Failed due to Language Pack installation failure
                              - Adobe InDesign CS5 Application Feature Set Files: Install failed
                              Call PostSession Custom Hook
                              :: END TIMER :: [Total Timer] took 95523.1 miliseconds (95.5231 seconds) DTR = 1351.05 KBPS (1.31938 MBPS)
                              -------------------------------------- Summary --------------------------------------
                              - 0 fatal error(s), 135 error(s), 150 warning(s)
                              WARNING: Display requirements not met for {288DB08D-0708-4A94-B055-55B99E39EB62}
                              WARNING: Display requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                              WARNING: Display requirements not met for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                              WARNING: Display requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                              WARNING: Display requirements not met for {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                              WARNING: Display requirements not met for {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
                              WARNING: Display requirements not met for {A334FDED-DCCA-481E-B226-F902CCC419D2}
                              WARNING: Display requirements not met for {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                              WARNING: Display requirements not met for {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
                              WARNING: Display requirements not met for {C21384F7-1A36-4706-95AB-B09BCE3C144F}
                              WARNING: Display requirements not met for {C79312BD-3E76-4474-A10C-1435D1856A4B}
                              WARNING: Display requirements not met for {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
                              WARNING: Display requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
                              WARNING: Display requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
                              WARNING: Display requirements not met for {DE60F0DE-469A-42DC-A678-978313210057}
                              WARNING: Display requirements not met for {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
                              WARNING: Display requirements not met for {F9766AC1-1461-1033-B862-DF8FE1C033BE}
                              WARNING: Payload cannot be installed due to dependent operation failure
                              ERROR: The following payload errors were found during install:
                              ERROR:  - Adobe OnLocation CS5 Royalty Content Wrapper: Install failed
                              ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
                              ERROR:  - Microsoft_VC90_ATL_x86: Install failed
                              ERROR:  - Adobe Media Player: Install failed
                              ERROR:  - SiteCatalyst NetAverages: Install failed
                              ERROR:  - Firefox Plugin CS5: Install failed
                              ERROR:  - Adobe Linguistics CS5 x64: Install failed
                              ERROR:  - Adobe Photoshop CS5 Support: Install failed
                              ERROR:  - Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US: Install failed
                              ERROR:  - Adobe Bridge CS5: Install failed
                              ERROR:  - Microsoft_VC80_ATL_x86: Install failed
                              ERROR:  - Recommended Common Fonts Installation x64: Install failed
                              ERROR:  - Adobe Flash CS5_AdobeFlash11-en_USLanguagePack: Install failed
                              ERROR:  - Adobe Toolhints CS5: Install failed
                              ERROR:  - Adobe Fireworks CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Flash Builder: Install failed
                              ERROR:  - AdobePDFL x64 CS5: Install failed
                              ERROR:  - Adobe Encore CS5 Royalty Codecs Installer Wrapper: Install failed
                              ERROR:  - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
                              ERROR:  - Microsoft_VC80_MFCLOC_x86_x64: Install failed
                              ERROR:  - Adobe After Effects CS5 Third Party RoyaltyContent Wrapper: Install failed
                              ERROR:  - Adobe Premiere Pro CS5 Third Party Content Wrapper: Install failed
                              ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US: Install failed
                              ERROR:  - Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB: Install failed
                              ERROR:  - Creative Suite 5 Master Collection: Install failed
                              ERROR:  - Adobe XMP Panels CS5: Install failed
                              ERROR:  - Adobe Player for Embedding: Install failed
                              ERROR:  - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack: Install failed
                              ERROR:  - Photoshop Camera Raw: Install failed
                              ERROR:  - AdobeColorCommonSetCMYK: Install failed
                              ERROR:  - AdobeHelp: Install failed
                              ERROR:  - Camera Profiles Installer: Install failed
                              ERROR:  - Adobe Buzzword CS5: Install failed
                              ERROR:  - Adobe After Effects CS5 Third Party Content Wrapper: Install failed
                              ERROR:  - Adobe Flash Player 10 Plugin: Install failed
                              ERROR:  - Adobe Mini Bridge CS5: Install failed
                              ERROR:  - Microsoft_VC80_CRT_x86_x64: Install failed
                              ERROR:  - IE Plugin CS5: Install failed
                              ERROR:  - Adobe Soundbooth CS5 Codecs Wrapper: Install failed
                              ERROR:  - Adobe SING CS5: Install failed
                              ERROR:  - AdobeColorJA CS5: Install failed
                              ERROR:  - Adobe ReviewPanel CS5: Install failed
                              ERROR:  - Adobe InDesign CS5 Icon Handler x64: Install failed
                              ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
                              ERROR:  - Adobe BrowserLab CS Live: Install failed
                              ERROR:  - Photoshop Camera Raw (64 bit): Install failed
                              ERROR:  - iPhone Publishing: Install failed
                              ERROR:  - Microsoft_VC90_MFC_x86: Install failed
                              ERROR:  - Adobe After Effects CS5 Support: Install failed
                              ERROR:  - CSXS Story Extension: Install failed
                              ERROR:  - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack: Install failed
                              ERROR:  - Adobe Media Encoder CS5 X64: Install failed
                              ERROR:  - Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack: Install failed
                              ERROR:  - Suite Shared Configuration CS5: Install failed
                              ERROR:  - Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper: Install failed
                              ERROR:  - Adobe Linguistics CS5: Install failed
                              ERROR:  - PDF Settings CS5: Install failed
                              ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
                              ERROR:  - AdobeTypeSupport CS5: Install failed
                              ERROR:  - AdobeColorVideoProfilesCS CS5: Install failed
                              ERROR:  - Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack: Install failed
                              ERROR:  - Adobe Flash Fonts1: Install failed
                              ERROR:  - AdobeColorCommonSetRGB: Install failed
                              ERROR:  - Adobe Player for Embedding x64: Install failed
                              ERROR:  - Office Plugin CS5: Install failed
                              ERROR:  - Adobe Photoshop CS5 Core: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
                              ERROR:  - Required Common Fonts Installation x64: Install failed
                              ERROR:  - Adobe InDesign CS5 Common Base Files: Install failed
                              ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
                              ERROR:  - Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
                              ERROR:  - Adobe CSXS Extensions CS5: Install failed
                              ERROR:  - Microsoft_VC80_ATL_x86_x64: Install failed
                              ERROR:  - AdobeOutputModule: Install failed
                              ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
                              ERROR:  - Microsoft_VC80_CRT_x86: Install failed
                              ERROR:  - AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US: Install failed
                              ERROR:  - Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB: Install failed
                              ERROR:  - AdobeCMaps x64 CS5: Install failed
                              ERROR:  - AdobeTypeSupport x64 CS5: Install failed
                              ERROR:  - Adobe Illustrator CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Media Encoder CS5 PCI WRAPPER X64: Install failed
                              ERROR:  - Adobe Encore CS5: Failed due to Language Pack installation failure
                              ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
                              ERROR:  - Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
                              ERROR:  - AdobeColorVideoProfilesAE CS5: Install failed
                              ERROR:  - DynamiclinkSupport: Install failed
                              ERROR:  - Adobe OnLocation CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Soundbooth CS5 Royalty Codecs Wrapper: Install failed
                              ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
                              ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
                              ERROR:  - AdobeColorEU CS5: Install failed
                              ERROR:  - Adobe Encore CS5_AdobeEncore5en_USLanguagePack: Install failed
                              ERROR:  - AdobePDFL CS5: Install failed
                              ERROR:  - HIL Help Search: Install failed
                              ERROR:  - AdobeCMaps CS5: Install failed
                              ERROR:  - AdobeColorNA CS5: Install failed
                              ERROR:  - Adobe Premiere Pro CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Dreamweaver CS5: Failed due to Language Pack installation failure
                              ERROR:  - Microsoft_VC80_MFC_x86_x64: Install failed
                              ERROR:  - ph: Install failed
                              ERROR:  - Required Common Fonts Installation: Install failed
                              ERROR:  - Adobe Soundbooth: Failed due to Language Pack installation failure
                              ERROR:  - Adobe After Effects CS5 Presets: Install failed
                              ERROR:  - AmericanEnglishSpeechAnalysisModels: Install failed
                              ERROR:  - Adobe SwitchBoard 2.0: Install failed
                              ERROR:  - Adobe Flash CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack: Install failed
                              ERROR:  - Microsoft_VC80_MFC_x86: Install failed
                              ERROR:  - AdobeColorPhotoshop CS5: Install failed
                              ERROR:  - Pixel Bender Toolkit: Install failed
                              ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
                              ERROR:  - Adobe After Effects CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe Contribute CS5: Failed due to Language Pack installation failure
                              ERROR:  - Adobe InDesign CS5 Application Base Files2: Install failed
                              ERROR:  - Players For Adobe Flash Pro: Install failed
                              ERROR:  - Recommended Common Fonts Installation: Install failed
                              ERROR:  - Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack: Install failed
                              ERROR:  - Adobe InDesign CS5 Icon Handler: Install failed
                              ERROR:  - Adobe Extension Manager CS5: Install failed
                              ERROR:  - AdobeJRE: Install failed
                              ERROR:  - Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack: Install failed
                              ERROR:  - Adobe Flash Catalyst CS5: Install failed
                              ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
                              ERROR:  - TLF For Adobe Flash Pro: Install failed
                              ERROR:  - AdobeMotionPicture CS5: Install failed
                              ERROR:  - Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack: Install failed
                              ERROR:  - Adobe AIR: Install failed
                              ERROR:  - Adobe Premiere Pro CS5 Support: Install failed
                              ERROR:  - Adobe Media Encoder CS5 Dolby WRAPPER X64: Install failed
                              ERROR:  - Adobe InDesign CS5 Application Base Files: Failed due to Language Pack installation failure
                              ERROR:  - Adobe InDesign CS5 Application Feature Set Files: Install failed
                              Search the same string above to find when the error occured.
                              Exit Code: 7 - Unable to complete Silent workflow
                              END - Installer Session
                              • 92. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                ciperka
                                This problem for me solved :-)  (Vista,64-bit)
                                I copied the downloaded files Adobe CS5 directly to the C:\Program Files (x86), and only here I'm triggered installation...
                                (three days at the PC - "thank you" ADOBE)
                                sorry for my English
                                • 93. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                  Winston_Sa
                                  Success! Got it working on Windows 7 x64
                                  If you get exit code 7 at the very beginning of the installation, go check the MSI*.log on C:\Users\username\AppData\Local\Temp  for errors. For example, mine says at the first lines:
                                  Error 1406.Could not write value PatchGUID to key Components\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\91785D291CBB3CC40AB8659C8E48CCC2.  System error 31.  Verify that you have sufficient access to that key, or contact your support personnel.
                                  Ok, then find the problem key at the registry (in this case, it is the DA42BC89BF25F5BD0AF18C3B9B1A1EE8) under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData \S-1-5-18\Components
                                  Now, follow the nightmarebr post (1st page) on how to change the permissions for that key,
                                  then delete all the values, except the (Default)
                                  Now install the cs5. If you get exit code 7 again, redo all the steps (probably the MSI log will display a different error).
                                  • 94. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                    MatthewLaun Adobe Employee
                                    To avoid having to repeat the steps of changing the permissions, change the permissions on the "components" object and ask that the change be applied to all child objects. This is described in the KB doc I referneced earlier:
                                    "Error 1401, 1402, 1404 or 1406 during installation of Adobe CS4 or  CS5 products on Windows"
                                    http://go.adobe.com/kb/ts_kb404622_en-us
                                    • 95. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                      Winston_Sa Level 1
                                      Thanks Matthew, I wasn´t aware of that KB doc. That is a better way of doing that.
                                      • 96. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                        AllDayDev Adobe Employee
                                        mcf139-
                                        You, like others, have encountered a permissions restriction in the registry, which has caused the install to fail:
                                        When it says UNKNOWN like it does here, this should mean that it refers to:
                                        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\7E577B2224C65CF4E801A9E52375DB49
                                        To resolve this issue, refer to the doc that Matthew posted above.
                                        Let us know if you face further installation problems.
                                        • 97. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                          amitzi Level 1
                                          I've just reinstalled my Windows 7 64-bit. NOTHING is installed but drivers.
                                          And yet, I get the same error.
                                          GRRRRRRRRHHH
                                          • 98. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                            mcf139 Level 1
                                            So i went to
                                            HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\  S-1-5-18\Components
                                            Right click on the Components folder then followed the direction from the link in Matthew's post........guess what It worked....jeez....finally.
                                            Thank you guys i was felling , helpless and nervous,i was so so disappointed that i couldnt enjoy the new cs5.
                                            Once again thank you ADOBE !
                                            • 99. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                              amitzi Level 1
                                              which one is the log file?
                                              • 100. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                The log file with have a name like:
                                                "Adobe Master Collection CS5 [date stamp].log.gz"
                                                You will find this in:
                                                C:\Program Files (x86)\Common Files\Adobe\Installers\
                                                The actual log file, which is just plain text, is compressed within this gzip file.
                                                • 101. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                  Winston_Sa Level 1
                                                  It is the newer msi<something>.log... e.g. in here it is MSI766ff.LOG
                                                  • 102. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                    acpeed
                                                    After I changed the permissons in the registry from System to Administrator, I finally got past the Install Initializing screen and got the actual Install screen.  I put in the information it requested on each screen.  It then started calculating for the install.  The install now fails with the "Inconsistency in the installer database.  Please restart your computer and install again'  This is one messed up installer.  I have no idea where to go from here.
                                                    • 103. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                      Winston_Sa Level 1
                                                      RacerX reported here the same problem as you, and got it working
                                                      I think I figured it out myself.
                                                      I had to delete the Media.DB file  under the commons/adobe/cabs  folder.
                                                      It is installing now.
                                                      good luck
                                                      • 104. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                        acpeed Level 1
                                                        That's if your installing from a download version.  I'm installing from DVD.
                                                        • 105. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                          acpeed -
                                                          The Media_db.db file that they are referring to is an Adobe installer database file put on the hard drive, regardless of the installation source.
                                                          You will find it in:
                                                          C:\Program Files (x86)\Common Files\Adobe\caps
                                                          Based on the error you are getting, removing (or renaming) this file may help you; however, I would recommend removing the entire "caps" folder as well as the "Adobe PCD" folder in the same location.
                                                          If that does not help you, then please attach (or PM) your installer log so we can assist further.
                                                          • 106. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                            acpeed Level 1
                                                            Aw, c**p.  Now the initializing installer goes away and the installer window doesn't come up.  I'm going backwards here.
                                                            Where is the Adobe log file and what name is it?  Win7 x64 apps seem to live to spew logs files all over the place.
                                                            This is the most tormented install experience of my life. <sigh>
                                                            • 107. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                              Winston_Sa Level 1
                                                              • 108. Re: Can't install CS5 Master collection engl Win 7 64- bits
        acpeed Level 1
        Okay, some new fun.  I took out the following folders;
        C:\Program Files\Adobe
        C:\Program Files\Common Files\Adobe
        C:\Program  Files (x86)\Adobe
        C:\ProgramData\Adobe
        I rebooted then started the install by running setup.exe as Administrator.  It initialized, and about five minutes later the Install screen appeared.  I filled in the info it wanted.   Next the "Total Time Remaining: calculating screen came up.  I then had to leave for an hour.  Much to my surprise the install was running.  The screen says there is 1955 minutes left for the install.  Whoa!  That's 32 hours plus!!!!!
        Like I said, this is a really messed up installer.  Whooop! Now the installer says 2328 minutes.  Scary.
        • 109. Re: Can't install CS5 Master collection engl Win 7 64- bits
        saratogacoach Level 1
        I am having similar difficulties and error log messages trying to install an upgrade for CS5 Design Premium on Windows 7 x 64.
        I probably should have posted my install log and other information here. But, here's the forum link:
        http://forums.adobe.com/message/2794309#2794309
        I would appreciate any help. I think I've narrowed the problem down to a faulty msi installer in the payload package, atleast for my failure to successfully install. I'm just not sure what to do next.
        Thanks.
        Kind Regards,
        saratogacoach
        • 110. Re: Can't install CS5 Master collection engl Win 7 64- bits
        saratogacoach -
        Windows installer error 1935 can, unfortunately, mean a few different things. I have encountered it before because of an incomplete install of the software I was trying to install already existing on the system. Basically, the installer was trying to updated that software, found that it was there, but because it wasn't properly installed it failed with that error code.
        Look for any items in the Programs And Features on your system that says "Microsoft Visual C++" and uninstall them. (If you get errors uninstalling, just note which item gave you the error, what the error was, and then continue uninstalling any other C++ runtimes.
        Once you have any MS C++ runtimes removed, download and install the Windows Installer Cleanup Utility:
        http://support.microsoft.com/kb/290301
        (When you install this utility on Vista or Windows 7, you have to run the MSICUU2.exe file As Administrator by right-clicking on it and choosing Run As Administrator.)
        Open the utility (shortcut should be in Start Menu) and look for any lines that for MS C++ runtimes. If you find one, or more, click on one at a time and pick Remove.
        Then reboot the PC and try re-installing CS5.
        • 111. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Hi Carey,
        Thanks for your reply. It looks like I have about 15 MS Visual C++ redistributables on my machine, probably related to my having an Express version of SQL server, maybe other programs that depend on these? Not sure, but reluctant to start uninstalling them, since this may stop these programs from running.
        Not sure what to do. Would very much like to get CS5 Design Premium upgrade installed, but not at the expense of losing other functionality.
        I've been trying for the better part of 2 days to get CS5 installed without success. Tried about everything I could find or recommended by Adobe tech support.
        CS4 Design Premium has installed flawlessly.
        Hoping to hear back from Adobe support where my case was escalated. When I spoke with Adobe support a short time ago, the tech person said they will contact me when a possible solution is found.
        Don't know what to do.
        Kind Regards,
        saratogacoach
        • 112. Re: Can't install CS5 Master collection engl Win 7 64- bits
        I can understand your reluctance in wanting to remove those runtime libraries.
        All of these libraries can be re-installed either by downloading them from the Microsoft website, or by re-installing the SQL server software that you mentioned. You would just not be able to use SQL server, assuming that it depends on those, while you get the problems with the installation of these runtimes sorted.
        Also, to help you narrow down to the relevant ones, CS5 only installs version 8 and 9 of the VC runtimes, so those are the only ones that would be causing the 1935 error.
        Basically, if the 1935 error means what I suspect it to mean, then one or more of these isn't installed correctly right now, which is why CS5 is failing to install.
        • 113. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Carey,
        Definitely worth a try. Yes, I can reinstall later if needed. Maybe the x86 2010 and the x64 2010 will be backwards compatible, so I will only need to re-install these 2 later (using SQL Server 2008 Express edition).
        Thanks for your help.
        Kind Regards,
        saratogacoach
        • 114. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Hi Carey,
        Did everything suggested, but unfortunately, this did not result in a successful install of CS5. Same errors, same install log.
        Kind Regards,
        saratogacoach
        • 115. Re: Can't install CS5 Master collection engl Win 7 64- bits
        amitzi Level 1
        Did you download the installation from the web?
        • 116. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Hi Amitzi,
        I have the upgrade DVD's for CS5 Design Premium, which is what I tried after following these suggestions, using CS5 Clean Script, running as admin. This did not work. I then tried the downloaded trial version for CS5. Same result. Neither installed. Same error messages. (after these 2 attempts to install, restored system to pre-removal of VC runtimes)
        Kind Regards,
        saratogacoach
        • 117. Re: Can't install CS5 Master collection engl Win 7 64- bits
        amitzi Level 1
        There should be new Clean Scripts available soon. What error messages are
        you getting?
        • 118. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Here's the link to my error log in this forum:
        http://forums.adobe.com/thread/633671?tstart=0
        saratogacoach
        • 119. Re: Can't install CS5 Master collection engl Win 7 64- bits
        amitzi Level 1
        Sometimes a reinstall of the OS is the best option. I'd go with Windows 7
        64-bit
        1 2 3 4 5 Previous Next
