9 Replies Latest reply on May 6, 2010 2:27 AM by 羊怪
    We need utf-8 BOM in *.cf* Files
    neti_netwalker Level 1
      In the Coldfusion8 Doc you can read:
      Adobe recommends that you use BOM characters in your files.
      (http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=i18n_10.html)
      How can we change the encoding from utf-8 without BOM to utf-8 with BOM? I think it is an internal eclipse problem.
      Does anyone know a goog solution for this problem?
        • 1. Re: We need utf-8 BOM in *.cf* Files
          I try the new Beta2 and we have the same problem!
          Does anyone know a good solution for this problem?
          • 2. Re: We need utf-8 BOM in *.cf* Files
            Adam Cameron. Level 5
            The docs are talking nonsense: there's not need to specify a BOM.  Just set your default encoding to UTF-8.
            If your CF templates have any non-ASCII characters in them, then tell the compiler to expect UTF-8 data using the <cfprocessingdirective> tag.
            Adam
            1 person found this helpful
            • 3. Re: We need utf-8 BOM in *.cf* Files
              Hello Adam
              I think this is not a good solution. All of our current files uses UTF-8 BOM we don't want do change every file.
              How can we change the default compiler behavor to recognize all files as UTF-8?
              How can we change the default processingdirective?
              Every good texteditor can add BOM to UTF-8 Files.
              • 5. Re: We need utf-8 BOM in *.cf* Files
                I don't see what your problem is here.
                If you tell CFB to create new files as UTF-8, it will.  It does not put a BOM in the file, but the BOM is not necessary for the file to be recognised as UTF-8.  Equally, there is no problem if your files do have a BOM.
                What actual problem are you having here?  Actual problem, not theoretical problem.  Why do you need there to be a BOM in the file?
                Adam
                • 6. Re: We need utf-8 BOM in *.cf* Files
                  Also, have you raised an enhancement request for this (but you better provide a thorough rationale for it!):http://cfbugs.adobe.com/bugreport/flexbugui/cfbugtracker/main.html
                  Adam
                  • 7. Re: We need utf-8 BOM in *.cf* Files
                    羊怪 Level 1
                    I have the same problem !!!
                    In my case, we need to output chinese/japanese pages.
                    The CFB (ColdFusion Builder) do not write BOM to .cfm files, so it will display random code when we save>close>reopen it.
                    and also, CF server 8 do not display correct characters in web page.
                    But, if we reopen it and save it to UTF8 by notepad. (or by Dreamweaver with BOM checked)
                    it will display chinese/japanese normally.....
                    we don't want to re-save all files by notepad or other applications.
                    and for edit these files by CFB, I think the BOM function is necessary.
                    actually, the problem CFB create files as UTF-8 without BOM is we have no idea to edit a cfml include other language like chinese or japanese !!
                    how can we slove this problem?
                    (I know the BOM is not necessary for UTF-8. but if I want to edit a cfm with chinese characters inside, it seems to be necessary.)
                    (Sorry if I misspelled something, my native language is chinese.)
                    • 8. Re: We need utf-8 BOM in *.cf* Files
                      tooMuchTrouble Level 3
                      the unicode spec says the BOM is optional for UTF-8 (which if you think about
                      it's not needed, there's only the 1 byte order for UTF-8). eclipse, which cf
                      builder (CFB), cfeclipse (CFE), et al is based on, doesn't write out a BOM.
                      i use thai, japanese, arabic, etc. in cf files edited w/CFB, CFE & even with
                      notepad (don't ask). all work fine.
                      are you sure your files are utf-8 encoded in the 1st place? can you zip up &
                      attach a simple example of one that's causing you problems?
                      • 9. Re: We need utf-8 BOM in *.cf* Files
                        羊怪 Level 1
                        Thanks Paul,
                        it so strange...
                        since you made a response to me, I tried to install CFB on my home pc.
                        and it's just incredible work fine..    =  ="
                        I think the problem is on my work pc...........
                        I will try it tomorrow,
                        and thanks for your enthusiastic help.
