<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
<fx:Script><![CDATA[
private function init():void {
button3.addEventListener(MouseEvent.CLICK, handleClick);
private function handleClick(event:MouseEvent):void {
if (event.target == button3) {
label.text += 'Buton 3 Clicked\n';}
]]></fx:Script>
<s:VGroup width="100%"><s:Button id="button3" label="Button 3"/>
<s:Label id="label"/>
</s:VGroup>
</s:Application>
The above code does not seem to work.
you have a couple of problems with your code... you dont call the init function anywhere, so the addeventlistener never gets initialized...
so you can either add init to the creation complete or initialize in the application tag
and also, when you do event.target, you have to do event.target.id == "button3"
id is a string...
the modifications are as follows...
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="init();">
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
if (event.target.id == "button3") {
]]></fx:Script>
</s:VGroup>
</s:Application>
The
is what I needed.
But I did not need:
My code now works fine, thank you.
