Show 5 replies
1. Re: HQ Audio in Flash
Rothrock May 6, 2010 2:23 PM (in response to d0brin)Have you checked your export settings in the Flash Publish preferences? What is the stream setting set to?
3. Re: HQ Audio in Flash
Rothrock May 7, 2010 7:12 AM (in response to d0brin)That is the library setting for that specific sound. If you go to the file menu and select publish preferences (or something like that) you can go to the Flash tab and there are two settings. One for how streams are output and another for events.
4. Re: HQ Audio in Flash
d0brin May 7, 2010 10:41 AM (in response to Rothrock)thanks for the help i always wondered how to get my sounds in Stream ot HQ and it was so simple
5. Re: HQ Audio in Flash
Rothrock May 7, 2010 10:44 AM (in response to d0brin)Glad that worked out for you. I wasn't sure that was it and I didn't know what to suggest after that.
BTW, if you can mark my suggestion as the correct answer. I get points. They aren't good for anything, but I want them never-the-less.
