There are a number of unanswered Flex questions on this forum. Please post your questions to the Flex forum here: http://forums.adobe.com/community/flex/flex_general_discussion.
There has been a little confusion since the introduction of the new Flash Builder forums. Here's some tips for choosing the right one:
- Use the Flex forum if...
- you have a question about a new Flex-based project before you get started
- you have a question about code you've already written
- you have a question about behavior of your code at runtime
- you have compiler errors
- you have questions about writing FlexUnit tests
- you have questions about using states
- Use the Flash Builder forum if...
- you're using Design view
- you have problems using code-related tools (code hints, refactoring, import/export)
- you have problems using the editors (slow typing, bad generated code, runtime errors from Flash Builder)
- you have problems with installation and licensing
- you have questions about connecting to Data services
- you have problems running, debugging or profiling
- you have issues with the Adobe Community Help Client
- you have issues with project settings (SDK version, player version, HTML wrapper)
- you have Eclipse questions
- you're using Snow Leopard http://blogs.adobe.com/jasonsj/2010/03/flash_builder_4_snow_leopard_and_the_64-bit_problem.html
These are just general guidelines to help you get the answers you need from the people that have the answers. A little bit of help in organizing questions saves us some time as well. Thanks!
Jason San Jose
Software Engineer, Flash Builder
