I included a flash video in my captivate project. It looks fine in the preview. When I published my project the flash video does not play it just displays a blank slide. I appreciate any advice.
Hi there
Where are you playing the file from? Did you copy it to a server or are you testing on your own PC and seeing the issue?
If you copied to a server, did you remember to copy the FLV file?
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
I am testing it on my PC first, which is where I am having the
issue. Do I need to publish it to my web server in order for it to work?
Hi again
No, things should work from your own PC. Have you looked to ensure the FLV file is in the folder where you are testing from?
Cheers... Rick
The video file is located in the same folder I am testing from.
