1 2 3 4 5 6 7 Previous Next 245 Replies Latest reply on Jan 5, 2011 5:56 PM by Dov Isaacs Go to original post
      • 120. Re: Can't install CS5 Master collection engl Win 7 64- bits
        acpeed
        Well, after eight hours the install failed.  It only installed On
        Location and SoundBooth.  I'll look at the log tomorrow.
        I'm about ready to demand my money back.  This is looking to be a massively defective product.
        • 121. Re: Can't install CS5 Master collection engl Win 7 64- bits
          MatthewLaun Adobe Employee
          Here are some general suggestions:
          First, most of these MSI related errors are going to happen even if you try to install just one product from your CS5 suite. So, while troubleshooting, just choose one application to install. If that fails, it will fail much more quickly than if you choose to try to install all of the applications. If you started with a failure, then make some changes and can get one app to install, you've probably found the right solution, and can then go back and install the remaining applications.
          Second, make use of the following KB docs:
          Troubleshooting installation - Adobe Creative Suite 5 products
          http://go.adobe.com/kb/ts_cpsid_82827_en-us
          This is a high level document, but contains links to two very useful documents:
          General installation troubleshooting — Adobe Creative Suite 5  products
          http://go.adobe.com/kb/ts_cpsid_82942_en-us
          This contains some best practices like how to startup Vista/7 in a "clean boot" mode (MS KB http://support.microsoft.com/kb/929135), check for admin priviledges, test the installation media, etc.
          Troubleshoot install errors using Creative Suite install logs
          http://go.adobe.com/kb/ts_kb400593_en-us
          This contains information that helps to identify errors related to MSI components, which seem to be the root of all the failures reported on this thread.
          If your log isn't helping you to identify a specific error which is documented in the Adobe support site, http://www.adobe.com/support , try searching the Microsoft support site for related issues, http://support.microsoft.com/
          Many of the errors that are being reported, 1402, 1935, etc, are issues that affect installations from other software vendors, even Microsoft, so if you find a documented solution used for another software application, it may be valid for Adobe CS5 applications as well.
          Matthew
          • 122. Re: Can't install CS5 Master collection engl Win 7 64- bits
            @amitzi,
            The CS5 clean script is indeed available. Here's a link to the KB doc on it's usage, which includes a link to the page for downloading it:
            Run — Adobe CS5 Cleaner Tool
            http://go.adobe.com/kb/ts_cpsid_82947_en-us
            Caveat, this tool is really designed to remove data and files from prelease versions of CS5 applications, or failed installations of CS5 applications. I don't expect it will be commonly relevant in the cases where the installations are failing due to MSI errors as most of the users here are experiencing.
            • 123. Re: Can't install CS5 Master collection engl Win 7 64- bits
              For those finding Error 1935, or "An error occurred during the installation of assembly  component" in your log files, see my response to the log posted by saratogacoach here:
              http://forums.adobe.com/message/2797473#2797473
              • 124. Re: Can't install CS5 Master collection engl Win 7 64- bits
                saratogacoach Level 1
                Thanks to all for their kind help. Having found some other OS errors on my computer, and inability to repair (long story related to replacing a hard drive that failed, difficulty with re-installing a "clean" Win 7 upgrade, instead having to upgrade in place from recovery disk restored Vista 64 first), I decided to buy a new Win 7 x 64 computer today. I'm in the process of setting it up and plan to try installing CS5 as one of the first software's I put on the machine to avoid any conflicts or problems. I think this should work. Will update.
                Kind Regards,
                saratogacoach
                • 125. Re: Can't install CS5 Master collection engl Win 7 64- bits
                  jmarcuselias
                  Seems weird but only After Effects from the CS5 master collection would not install on my machine.
                  Any reason for this?
                  Exit Code: 6
                  -------------------------------------- Summary --------------------------------------
                  - 1 fatal error(s), 3 error(s), 16 warning(s)
                  WARNING: OS requirements not met for {288DB08D-0708-4A94-B055-55B99E39EB62}
                  WARNING: OS requirements not met for {33A3F995-8333-4676-8D6F-AB7674BB52EA}
                  WARNING: OS requirements not met for {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
                  WARNING: OS requirements not met for {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
                  WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
                  WARNING: OS requirements not met for {7816FDDE-40D4-482D-AD7D-97858985DB3E}
                  WARNING: OS requirements not met for {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
                  WARNING: OS requirements not met for {B8D286BC-A68D-4E74-9F68-8756A49896D8}
                  WARNING: OS requirements not met for {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
                  WARNING: OS requirements not met for {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
                  WARNING: OS requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
                  WARNING: OS requirements not met for {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
                  WARNING: OS requirements not met for {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
                  WARNING: OS requirements not met for {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
                  WARNING: CreateAlias:Icon file does not exist at C:\Program Files (x86)\Adobe\Adobe Utilities - CS5\Pixel Bender Toolkit 2\windows\pb_app.icofile:\\\C:\PIXELB~1\source\winwood\Staging    0X1.CEA50BP-1022rea\windows\pb_app.ico42178f80493091e8e552c84a2897e9da68fce32_32_f8049309 1e8e552c84a2897e9da68fce for icon C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Master Collection CS5\Adobe Pixel Bender Toolkit 2.lnk with target C:\Program Files (x86)\Adobe\Adobe Utilities - CS5\Pixel Bender Toolkit 2\Pixel Bender Toolkit.exe
                  WARNING: Payload cannot be installed due to dependent operation failure
                  ERROR: The following payload errors were found during install:
                  ERROR:  - Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack: Install failed
                  ERROR:  - Adobe After Effects CS5: Failed due to Language Pack installation failure
                  FATAL ERROR: Cannot create extract assets at 'C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{DA1B174B-4297-467C-9EF8-0AB8D4D5171E}' from zip file 'C:\Users\Public\Downloads\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10AllTrial\Assets1_1.zip'. Error 0
                  • 126. Re: Can't install CS5 Master collection engl Win 7 64- bits
                    While I had some difficulties with installation, I finally figured out that for me it was a corrupt OS. Once I used a different computer with a good OS, it installed OK. I hope that other forum users can offer some solutions.
                    Sorry I can't be of more help.
                    Kind Regards,
                    saratogacoach
                    • 127. Re: Can't install CS5 Master collection engl Win 7 64- bits
                      AllDayDev Adobe Employee
                      jmarcuselias -
                      From the error, the installer could not extract the contens of the Assets1_1.zip file.
                      Go to C:\Users\Public\Downloads\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10AllTrial\
                      Then open open up that ZIP file. I'm guessing you'll get an error, which would indicate that the file is corrupted.
                      If you do get an error, then do this:
                      1. Find the .7Z file (one of the two you downloaded for the trial).
                      2. Open it in 7-Zip, WinRAR, or another archive utility that support the 7-zip format.
                      3. Look in /Adobe After Effects CS5/payloads/AdobeAfterEffects10AllTrial/ for the same file.
                      4. Extract this one file (Assets1_1.zip) to C:\Users\Public\Downloads\Adobe CS5 Master Collection\Adobe CS5\payloads\AdobeAfterEffects10AllTrial\, overwriting the corrupted one.(If for some reason you get an error when you try to extract this file  from the .7Z file, then that would mean that your download did not  complete correctly, and you'd need to re-download it.)
                      5. Install After Effects again.
                      Hope this helps!
                      • 128. Re: Can't install CS5 Master collection engl Win 7 64- bits
                        acpeed Level 1
                        I wiped my workstation and reinstalled Win7 Pro x64, then just ran Windows Update until it was done, then ran the CS5 setup.exe as Administrator.  After the Installer Intializing screen goes away - NOTHING.  A clean install doesn't fix the problem.  The problem is on Adobe's end, not the user end.
                        I did finally a notice something.  The DVDs are DUAL LAYER.  That was a massively stupid idea on Adobe's part.  In my day job doing IT, we've found we can't trust drives to read or write dual-layer reliably.  No wonder the only install I got to run ran eight hours before it failed.
                        I'm going to try and copy the disks to my D: and try to run them from there.  We'll see what happens.
                        • 129. Re: Can't install CS5 Master collection engl Win 7 64- bits
                          acpeed Level 1
                          Joy!  I got my CS5 Master Collection installed!!!!!
                          This is what worked for my setup.
                          It looks to be a combination of bad ideas from Adobe.  They wrote a very sloppy installer.  They may have used a version of Visual C++ that has issues with any older installed versions and didn't write a proper routine to upgrade any previously installed versions.  They also used double-layered DVD disks, and either the disks are of marginal quality and/or they didn't test them on enough drives.
                          I reasoned that maybe if I copied the files to a hard drive and ran the install from there, it might work.    I had to try three systems before I found one that had a DVD drive that could read the disks without having read errors.  I then copied off the two disks to individual folders on a portable drive.  I then connected the portable drive to my workstation and copied the folders to the D: drive on that PC.  After a few false starts, I found that I had to copy the files from the Disk 2 Payload folder and paste them into the Disk 1 Payload folder since their installer doesn't let you browse for the disk when it asks for Disk 2 (Another dumb idea, people.).  There were about 129 files it said were duplicates, so I told Win7 copy to skip them.  They were mostly .xml files and it turns out they didn't matter.   I then ran setup.exe as Administrator and it installed in less than an hour!  Mind, you this was on a new, clean install on Win7 Pro x64.
                          Now I have to reinstall all my other apps.  @#$%^&*!!!!!!  At least the frustration is over for me......
                          • 130. Re: Can't install CS5 Master collection engl Win 7 64- bits
                            amitzi
                            Just know for next time that Macs usually read DVDs where PCs fail due to
                            their superior engineering.
                            • 131. Re: Can't install CS5 Master collection engl Win 7 64- bits
                              Dov Isaacs Adobe Employee
                              Sorry, but that is a load of total BS!
                              Apple sources their DVD drives from the same places that PC manufacturers source theirs. There is absolutely no difference in the drives and no so-called "superior engineering" involved. The last I checked, Apple uses the same off-the-shelf Matsushita (Panasonic) drives as are used by PC manufacturers. If you like you Mac, fine. But please don't troll with "fan boy" tactics.
                                           - Dov
                              • 132. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                acpeed Level 1
                                LOL!  It was my MacBook Pro that I read the disks on!
                                I have ProductionStudio CS4 on my Mac, but I could only afford to buy one upgrade right now, and I needed CS5 for work I'm doing on my Dual-Xeon, 8GB workstation.
                                • 133. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                  amitzi Level 1
                                  Actually, I never owned a Mac and i hate the MacOS UI. I am also a Microsoft
                                  specialist (or at least were) so you could say I was a Windows fan. But it
                                  has been known to read DVDs an CDs that PCs couldn't.
                                  • 134. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                    Films4U
                                    After several hours talking to level 1 Adobe "Support", opening a ticket (no response so far after 2 days), and after trying everything in this thread, I still cannot install CS5 Production Premium.  I have 2 quad core processors on Win 7 64bit and 20 GB RAM.  I have tried installing logged in as Administrator and Run as Administrator.  My anti-virus was disabled during the install attempts.  This is the CS fourth version I've purchased, and the only one with install problems.  I've been a loyal Adobe customer.  This time, I think Adobe released this software before it was thoroughly tested.  I paid a lot of money for something that is utterly useless.  It does Adobe no favor to have such a grand Launch when the product has so many installation issues.
                                    • 135. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                      Please attach your installation log file, or use this document to identify the root cause by analysing your log file:
                                      http://kb2.adobe.com/cps/400/kb400593.html
                                      • 136. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                        Films4U Level 1
                                        The latest log file is attached.
                                        • 137. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                          si conehead Level 2
                                          Matthew:
                                          Apparently attachments have been disabled. What is the alternative?
                                          • 138. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                            The alternative is to paste into the post here the summary from the end. Also, search the log for "return value 3" and if you find any instances, copy it and the 4 or 5 lines of text above it, and include those also.
                                            Matt
                                            • 139. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                              Films4U Level 1
                                              Here is what I found:
                                              Message type: 0, Argument: 1033
                                              Message type: 1, Argument: Microsoft_VC80_ATL_x86
                                              Action 13:13:07: ProcessComponents. Updating component registration
                                              Action 13:13:07: RemoveODBC. Removing ODBC components
                                              Action 13:13:07: InstallFiles. Copying new files
                                              Error 1402.Could not open key: UNKNOWN\Components\1FA18F7974E099CD0AF18C3B9B1A1EE8\A752DC3423F4EDB4B9D3416E1EC03870.   Verify that you have sufficient access to that key, or contact your support personnel.
                                              Action ended 13:13:07: InstallFinalize. Return value 3.
                                              It looks like I do not have the ability to access the registry key, but I have Full Control as an Administrator and I ran the install as an Administrator.  I knew there was a problem with the Microsoft_VC80_ATL_x86 since in the many times I've tried the install, it always gets stuck there.  I've tried the install so many times, I can almost input the serial number from memory.
                                              • 140. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                Films4U,
                                                Just because you are an administrator on the machine, don't assume the permissions are set correctly to allow the installer to modify the registry keys in question. If assumptions like that were reliable, there wouldn't be much need for technical support ;-)
                                                You can solve this using the method outlined in this document:
                                                http://go.adobe.com/kb/ts_kb404622_en-us
                                                Search your registry for "1FA18F7974E099CD0AF18C3B9B1A1EE8", and then perform the steps on it's parent "Components". Note the little warnings about sometimes having to do the steps twice if you get an error the first time.
                                                Good luck!
                                                Matthew
                                                • 141. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                  Having spent a lot of time trying to install and encountering similar error logs, as mentioned above, I finally used a new computer with Win 7 x 64 factory installed. The install of CS5 Design Premium upgrade went quickly and smoothly.
                                                  The numerous previous failed installs were on a computer running Win 7 x 64 that had been "upgraded in place" from Vista x 64. Eventually, in analyzing the install difficulties I came to the conclusion that this computer's OS was probably corrupted, though unsure what caused the corruption.
                                                  I wonder if the install problem is common to computers that used an upgrade in place, on top of their previous Vista system, instead of a "clean" (custom) upgrade. However, this hypothesis will not work if these install difficulties are occuring on computers with factory installed (OEM) Win 7 x 64 or have been upgraded using a clean (custom) route.
                                                  Just a thought about what could be contributing to the install difficulty...
                                                  Kind Regards,
                                                  saratogacoach
                                                  • 142. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                    Films4U Level 1
                                                    Matthew:  Did I mention that I went through every suggestion in the thread?  Also, I've already used the link you provided in a previous reply, but I did it all over again and checked all permissions all the way up the registry tree.  I tried the reinstall but alas, no successful install.
                                                    Saratogacoach: When I installed Win 7, it was on a newly formatted partition, not a Win XP or Vista upgrade.
                                                    The only thing left to do is to re-format my partition and re-install Win 7.  Others in the thread have tried this before an install without success, although it worked for at least one person.
                                                    I know that Win 7 64 bit is a new OS for Adobe, but I still say that more testing should have been done so that we would have a robust install package.  Out of the 4 Adobe editing software packages I've used, the ball was dropped this time.  I just hope that once I get it installed, the software works bug free.
                                                    Thanks for the suggestions,
                                                    Films4U (once the software installs)
                                                    • 143. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                      Films4U -
                                                      Sorry about your troubles here.
                                                      A couple questions/suggestions:
                                                      - When you corrected permissions in the registry (for both Administrators group and SYSTEM), which is what the fix is for the 1402 error that you received, did you do so for the following key (and propagate to all sub-keys)?:
                                                      HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\C omponents
                                                      If not, that's the one you should be looking at.
                                                      Also, after doing so, did you try renaming the 1FA18F7974E099CD0AF18C3B9B1A1EE8 key before re-installing? (You might add a dash to the beginning of the name, for example.)
                                                      - Are you logged into your computer with a user that is part of a domain? If so, then it is possible that some restriction put in place by your network administrator (e.g. a group policy).
                                                      Verify that you are logging into a local administrator account. Create one if necessary.
                                                      • 144. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                        Films4U Level 1
                                                        Carey,
                                                        I did use the registry tree you suggested and have Full Control.  However, I could not rename the offending key.  I could rename the key item that was causing the problem but that did not allow the install.
                                                        Films4U
                                                        • 145. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                          Films4U Level 1
                                                          I ended up doing another clean install of Win 7 and then installing CS5, even before activating the Win 7.  CS5 installed.
                                                          Thanks to all who gave suggestions.  BTW, after a ticket 4 days ago, I never did hear from the Adobe Support Portal people.
                                                          Films4U
                                                          • 146. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                            souzou
                                                            I had exactly the same problem with my install of CS5 Master Collection (DVD), from error log:
                                                            Error 1402.Could not open key: UNKNOWN\Components\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\68AB67CA7DA73301B7449A0200000010.   Verify that you have sufficient access to that key, or contact your support personnel.
                                                            Here's how I got it working:
                                                            1) Via Control Panel, turned User Account Control (UAC) down to Never notify (temporarily)
                                                            2) Opened up the Registry Editor and located the key DA42BC89BF25F5BD0AF18C3B9B1A1EE8
                                                            Note: I had three of these keys and I amended all of them, but one in particular contained about 20 other keys (including 8AB67CA7DA73301B7449A0200000010) so this is the one I focused on.
                                                            3) Changed the permissions as in nightmarebr's post (so that Administrator has Full Control), but also ticked Replace all child object permissions with inheritable permissions from this object
                                                            4) This led to an error message, saying that not all the child keys could be updated.
                                                            5) Checking through these child keys I found that I did not have permission to change the permissions, as the Administrator was not the owner. So I changed the owner of the keys to Administrator (by editing permissions, clicking on Owner tab, and adding the Administrator as the owner). There is a good guide to this process here:
                                                            http://www.mydigitallife.info/2009/09/02/grant-read-write-full-control-permissions-on-regi stry-keys-fix-cannot-import-and-access-denied-error-in-regedit/
                                                            6) I did this for all the child keys and then was able to change permissions for all of them so that Administrator had Full Control.
                                                            7) I ran the installer (as Administrator) and installed into the Program Files (x86) folder (the Program Files folder did not work).
                                                            8) After installation was successful (FINALLY!) I changed my settings on the UAC back to normal.
                                                            Hope that helps someone!
                                                            Cheers,
                                                            Matt
                                                            • 147. Re: Can't install CS5 Master collection engl Win 7 64- bits
                                                              Films4U Level 1
                                                              Thanks so much, Matt.  If I have to reinstall in the future, I'll sure try your method.  I'm having fun today reinstalling all of my other programs.
                                                              Best,
                                                              Films4U
                                                              • 148. Re: Can't install CS5 Master collection engl Win 7 64- bits
        darkhelmet1234 Level 1
        Please attach your installation log file.
        Rename this file.
        Restart your computer.
        So this and reinstalling the O/S is what customers have to look forward to? There are 6 Windows 7 64 machines in our studio and it took almost 7 hours to get this crap (CS5 MS) installed on just 2! And as system admin I am NOT reinstalling any O/S only to realize like Films4U it solved absolutely nothing.
        In fact I did install this on a brand new Win 7 64 machine and guess what?
        1st issue right out of the gate:  "Installer has detected that a machine restart may be pending." ARE YOU KIDDING ME? Skipped right by that stupidity.
        2nd issue: Got a Kboelsen type error and thought, "Okay I'll play the reboot game this one time because it just might work." Restarted the machine, which really did not need a reboot. Reboot solved nothing, of course.
        3rd issue: Seconds later the same stupid ""Installer has detected that a machine restart may be pending." Skipped that and continued with the installation. Installed DW and FW before taking a dump. Immediately restarted the installation, same routine, and 45 minutes later it finally installed the rest. A 3 hour joke.
        Second machine was a lot more frustrating and more time consuming but similar issues. Needless to say these two installs consumed almost an entire working day.
        Can't believe you folks did not even test your installer on the most up and coming O/S, especially when many of the articles I've been reading since last year were all about CS5 and it's native 64bit support. This was on Windows XP 64 right, not Windows 7? Maybe a typo on Adobe's part or I read through the articles too fast.
        Fix these issues fast or I guarantee we will gladly save ourselves a couple thousand in upgrade cost by staying with a much more reliable CS4 for the long term.
        Oh yeah, what the heck is this statement supposed to do for us? "Good luck all, and thanks for your understanding for the complexity of what's involved here, and the aspects of the OS that we don't have control over." Many of us have problems with fresh installs of Win 7 64 bit - did no one at Adobe think to go out and buy a copy to test CS5 on? So the customer has to be your guinea pig?
        • 149. Re: Can't install CS5 Master collection engl Win 7 64- bits
        JaysonM-Y Level 3
        Internet Hugs nightmarebr.... good work. Coupled with 'COMPLETE' uninstall of CS4 and a run through of the cs5 clean script, you may just have saved a friend the trauma of lodging his CS5 disks into a part of his body that shall remain unmentioned.
        • 150. Re: Can't install CS5 Master collection engl Win 7 64- bits
        PaulFAubin
        Well I thought I was done with this, but last night I tried to learn a little about Encore and the video I was watching said that I should have all this cool stuff in my library, but all I have is General. Soooooo, out came the install disks again. Unfortunately, Encore CS5 now refuses to install any of the library components.
        Recap on my setup: I purchases Production Premium. I have Windows 7 Pro on two different machines. I originally installed from the download tryout since my DVDs had not yet arrived. I had to jump through all sorts of hoops to get it installed originally, but finally had success (so I thought). This was using the downloaded tryout. So it seems that the tryout does not install the Encore library? And from what I understand some of the Premeire and After Effects stuff does not get installed either. So, when the disks arrived, I popped them in, input my serial number and ran the install again. After a few failed attempts, and logging in as Administrator, truning off virus and firewall, going to limited startup in MSConfig, etc, I got everything to install EXCEPT Encore now. For some reason, it continues to say:
        ERROR: Verifying payload integerity : Failed with code 1
        ERROR: MsiConfigureProductEx failed with error: 1612
        ERROR:  - Adobe Media Player: Install failed
        ERROR:  - Adobe Bridge CS5: Install failed
        ERROR:  - Adobe Encore CS5 Royalty Codecs Installer Wrapper: Install failed
        ERROR:  - Adobe Mini Bridge CS5: Install failed
        ERROR:  - Adobe Encore CS5 Library: Install failed
        ERROR:  - Adobe Encore CS5_AdobeEncore5en_USLanguagePack: Install failed
        ERROR:  - ph: Install failed
        ERROR:  - Required Common Fonts Installation: Install failed
        ERROR:  - Adobe Encore CS5: Failed due to Language Pack installation failure
        ERROR:  - Recommended Common Fonts Installation: Install failed
        ERROR:  - Adobe AIR: Install failed
        Here is a link to my latest log.
        Following the links in this thread, I looked up error 1612, but it says to run the RoboPDF cleanup. ???? What is RoboPDF? I don't recall ever owning anything like that. Oh well, I ran this thing and I am about to reboot and try again, but I thought I woudl post all of this first.
        We have been working on a Premiere project that has to go to DVD soon, so I really want to get this resolved and I am SOOO tired of rebooting and running installers....
        Thanks in advance.
        • 151. Re: Can't install CS5 Master collection engl Win 7 64- bits
        awson
        Hi there,
        Having similar problems to the one above, trying to install CS5 Master trial version W7 x64 log error 1402, system error 5 etc. etc.   Have been through nightmarebr's fixes for registry permissions etc. and have checked permissions for the MSI files but think I've found something that I've not seen anyone else mention yet.
        In regards to the VC90_CRT_x86_x64.msi file in install folder\payloads - if I double click the file I get "The installation source for this product is not available.  Verify that the source exists and that you can access it."
        So it appears (using my very limited knowledge) that the msi file included in the download  is incomplete.  I can't seem to find an alternative source for this file - I've tried Microsoft.com but don't know or understand enough about the visual C++ deployment and set up that MS refers to when I search for this file.
        Is this specific to the adobe setup? Has anyone else had this problem? Would anyone know where I could download this file?
        • 152. Re: Can't install CS5 Master collection engl Win 7 64- bits
        PaulFAubin Level 1
        Just searched for that file on my end and double-clicked it. It offered me to Modify, Repair or uninstall. I tried repair and it installed fine with no errors. Maybe yours downloaded badly. I posted my version of that file here. Ofcourse, I have VERY limited knowledge of MSI files, so please use at your own risk. I am not sure if there is any bad side effects to using the one I posted.
        I was never able to find anything in the registry. I am not completely clear on what I am supposed to search for. If I search the long GUID in my error message from the installer, RegEdit finds nothing.
        I was able to get everything installed before by uninstalling EVERYTHING and running the CS5 clean script. I just didn't want to have to do that again this time since all still need is the Encore libraries... Frustrating.
        • 153. Re: Can't install CS5 Master collection engl Win 7 64- bits
        sourceman
        For those having issues with Installing CS 5 Master collection.  I was getting code 7 errors.
        After three days of pulling my hair out, I finally figured out what was going on.
        My install would crap out as soon as it got to the  Microsoft_VC80 install. I would try and repair the installation and would get the 1402 error code.
        I went into the registry and found that somehow I had multiple Keys. I deleted the duplicate keys and off the installation went.
        • 154. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Anshum Arora
        1402 error also means that you do not permissions to write in a particular key which is inside Components in registry , giving permissions to that also solves the installation problem.
        • 155. Re: Can't install CS5 Master collection engl Win 7 64- bits
        si conehead Level 2
        Sourceman,
        How did you find the multiple keys and what were they?
        Steve
        • 156. Re: Can't install CS5 Master collection engl Win 7 64- bits
        awson Level 1
        Paul - thanks for the file - much appreciated!  I repaired the one you sent like you mentioned, but it wouldn't install.  Turns out it was the registry key after all - someone who actually knows what they're doing stepped in and had a look - it seems that the CS5 install corrupted the registry (1st install actually worked, but killed Flash player, had no Encore or Bridge, and I got lots of errors, but I did actually manage to install it).
        I'd changed the MSI key permissions but there were about 135 other sub-keys that also needed the permissions changed.  I'd missed these and missed the part in the thread where it said to catch all of these.
        So... I managed to install it - yay! But, it's now not recognising that my OS is 64bit so I only have x86 Photoshop - no After-effects, Encore or Premiere and lots and lots of different errors that vary each time.
        I think I'll have a couple more goes but I'm rapidly approaching the point where I'll wipe the OS and reinstall CS4.  I only wanted to see what the new features on CS5 were before upgrading but I've been successfully persuaded that paying a huge amount of money to upgrade will only result in several days worth of lost work and frustration, culminating in a broken PC and window.
        Once again - thanks for all your help.  I'm going to investigate the "incorrect OS" errors now - fingers crossed everyone else manages to get this sorted out.
        Out of interest, how common do we think these problems are now? Is it likely to be a priority for Adobe to sort this out?  CS4 installed like a dream on 64bit W7, it's a shame that this is so complex and awkward.
        • 157. Re: Can't install CS5 Master collection engl Win 7 64- bits
        Anshum Arora Level 1
        awson wrote:
        Hi Paul,
        Thanks for the file - much appreciated!  I repaired the one you sent like you mentioned, but it wouldn't install.  Turns out it was the registry key after all - someone who actually knows what they're doing stepped in and had a look - it appears that the CS5 install corrupted the registry (1st install actually worked, but killed Flash and I got lots of errors, but I did actually manage to install it).
        @awson: Its not that CS5 install is corrupting the registry , many users have been able to successfully install and use their CS5. Please send in your email id so that someone from Adobe can look into your system and assist you in resolving this issue for you.
        • 158. Re: Can't install CS5 Master collection engl Win 7 64- bits
        awson Level 1
        Hi Anshum,
        Thanks for getting back to me.  I'm sure many people have installed CS5 correctly, but from the looks of these threads and googling it, it appears that many people have also not been able to.
        You're right - there's no specific evidence that the CS5 install corrupted the registry and I apologise for implying that it did.
        However, the order of things were:-
        • PC working perfectly.
        • Install CS5, results in some errors and flash player won't work at all.
        • Unistall CS5,
        • CS5 won't reinstall.
        • After multiple clean-ups, Windows Clean installer and CS5 Cleanscript and multiple attempts at reinstalling, nothing works.
        • I follow nightmarebr's excellent instructions about setting the permissions but still didn't work.
        • When I asked an expert to look at the registry he said that the registry permissions seemed corrupt and were behaving oddly.
        • Once this had been fixed, CS5 then installed, but now with an "incorrect OS" error, no Photoshop, no Encore, no After-effects and no Premiere.
        • Nothing else was done in the meantime and I'm going on information offered to me by someone who has extensive knowledge of this type of thing.
        I appreciate your offered assistance but I do feel a little slighted by your assumption that I'm incapable of installing a program that "many users have been able to successfully install and use" and that the install is faultless.
        Do you represent Adobe in an official capacity? Where would you want me to send my email id to?  My last experience of adobe technical support consisted of them telling me to re-install my OS after multiple re-boots, but it appears that people have had problems with clean installs too so I'd rather investigate myself before going through the pain of reinstalling Windows.
        • 159. Re: Can't install CS5 Master collection engl Win 7 64- bits
        awson wrote:
        Hi Anshum,
        • Unistall CS5,
        Its not that your are incapable of installing program , its just that i am as concerned as you are on this issue. I am curious to find out the reason of this failure.Chances are i may also be not able to resolve but we can definitely try once. Please mail at anshum@adobe.com so that i can send you further details.
        My point of telling that it runs successfully for some other users meant that , its not only the installer which is failing but a combination of "Installer + machine + Permission" configuration combined which makes the installer fails on certain systems.So its worth giving a try again.It will also give me immense happiness if the issue is resolved for you.
        You can also enter bug report at :https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform if you think this is Installer issue.
