5 Replies Latest reply on Sep 10, 2010 3:07 AM by kwadwoadu
    Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
    spudnut
      I had been using Flash CS5 as a trial for the past 6 days without issues. Yesterday, I made a change to a file, and went to preview it, as I had several times before. This time, when I slected preview movie, Flash crashed umexpectedly. When I launched it again, it came up looking very corrupted - window as messed up, and any an all attempts to load any of the workspaces resulted in Flash crashes. I had to completely uninstall it including all prefs to get it to work again. Anyone having similar issues? I am hesitant to try a preview movie again.
        • 1. Re: Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
          nrajbhan Level 3
          Can you post your crash log?  You can find it in /Users/<user>/Library/Logs/CrashReporter folder.
          Nivesh
          • 2. Re: Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
            spudnut Level 1
            I have multiple crash logs - here is one of the first:
            Process:         Adobe Flash CS5 [817]
            Path:            /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
            Identifier:      com.adobe.flash
            Version:         11.0.0.485 (11.0.0)
            Code Type:       X86 (Native)
            Parent Process:  launchd [666]
            Date/Time:       2010-05-08 21:24:44.426 -0500
            OS Version:      Mac OS X 10.6.3 (10D573)
            Report Version:  6
            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
            Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000000c
            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
            Application Specific Information:
            Java information:
            Exception type: Bus Error (0xa) at pc=0x0dac0d8a
            Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode macosx-x86)
            Current thread (0x3f000c00):  JavaThread "main" [_thread_in_native, id=193696992, stack(0xbf800000,0xc0000000)]
            Stack: [0xbf800000,0xc0000000]
            Java Threads: ( => current thread )
              0x57001c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1264455680, stack(0xb491f000,0xb4a1f000)]
              0x57001000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1265512448, stack(0xb481d000,0xb491d000)]
              0x57000000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1266569216, stack(0xb471b000,0xb481b000)]
              0x3f20d400 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1267625984, stack(0xb4619000,0xb4719000)]
              0x3f201c00 JavaThread "Finalizer" daemon [_thread_blocked, id=-1268682752, stack(0xb4517000,0xb4617000)]
              0x3f201000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1269739520, stack(0xb4415000,0xb4515000)]
            =>0x3f000c00 JavaThread "main" [_thread_in_native, id=193696992, stack(0xbf800000,0xc0000000)]
            Other Threads:
              0x3f1fd000 VMThread [stack: 0xb4313000,0xb4413000] [id=-1270796288]
              0x57002c00 WatcherThread [stack: 0xb4a21000,0xb4b21000] [id=-1263398912]
            VM state:not at safepoint (normal execution)
            VM Mutex/Monitor currently owned by a thread: None
            Heap
            par new generation   total 14336K, used 7398K [0x4a810000, 0x4b810000, 0x4b810000)
              eden space 12288K,  55% used [0x4a810000, 0x4aeaa2b0, 0x4b410000)
              from space 2048K,  31% used [0x4b610000, 0x4b6af738, 0x4b810000)
              to   space 2048K,   0% used [0x4b410000, 0x4b410000, 0x4b610000)
            concurrent mark-sweep generation total 49152K, used 0K [0x4b810000, 0x4e810000, 0x52810000)
            concurrent-mark-sweep perm gen total 12288K, used 6792K [0x52810000, 0x53410000, 0x56810000)
            Virtual Machine Arguments:
            JVM Args: -Djava.awt.headless=true -Xmx128m
            Java Command: <unknown>
            Launcher Type: generic
            Physical Memory: Page Size = 4k, Total = 16384M, Free = 1941M
            Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
            0   libicucore.A.dylib                0x0dac0d8a icu::DecimalFormatSymbols::~DecimalFormatSymbols() + 76
            1   libicucore.A.dylib                0x0dac0cd6 icu::DecimalFormat::~DecimalFormat() + 136
            2   libicucore.A.dylib                0x0dac59ca icu::DateFormat::~DateFormat() + 62
            3   libicucore.A.dylib                0x0dac5372 icu::SimpleDateFormat::~SimpleDateFormat() + 134
            4   com.apple.CoreFoundation          0x03dd34b9 __CFDateFormatterDeallocate + 25
            5   com.apple.CoreFoundation          0x03d3cea1 _CFRelease + 353
            6   libSystem.B.dylib                 0x0b7213bf __cxa_finalize + 208
            7   libSystem.B.dylib                 0x0b7212d4 exit + 33
            8   com.adobe.flash                   0x0000403f 0x1000 + 12351
            Thread 1:  Dispatch queue: com.apple.libdispatch-manager
            0   libSystem.B.dylib                 0x0b728b42 kevent + 10
            1   libSystem.B.dylib                 0x0b72925c _dispatch_mgr_invoke + 215
            2   libSystem.B.dylib                 0x0b728719 _dispatch_queue_invoke + 163
            3   libSystem.B.dylib                 0x0b7284be _dispatch_worker_thread2 + 240
            4   libSystem.B.dylib                 0x0b727f41 _pthread_wqthread + 390
            5   libSystem.B.dylib                 0x0b727d86 start_wqthread + 30
            Thread 2:
            0   libSystem.B.dylib                 0x0b702342 semaphore_wait_signal_trap + 10
            1   libSystem.B.dylib                 0x0b72feb8 _pthread_cond_wait + 1089
            2   libSystem.B.dylib                 0x0b77842f pthread_cond_wait + 48
            3   com.adobe.amt.services            0x11f01126 AMTConditionLock::LockWhenCondition(int) + 46
            4   com.adobe.amt.services            0x11ef9db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
            5   com.adobe.amt.services            0x11f0118c AMTThread::Worker(void*) + 24
            6   libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            7   libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 3:  Java: Exception Handler Thread
            0   libSystem.B.dylib                 0x0b7022fa mach_msg_trap + 10
            1   libSystem.B.dylib                 0x0b702a67 mach_msg + 68
            2   libSystem.B.dylib                 0x0b76e048 mach_msg_server + 520
            3   libclient.dylib                   0x359bbe25 JNI_CreateJavaVM_Impl + 61045
            4   libclient.dylib                   0x359bbdca JNI_CreateJavaVM_Impl + 60954
            5   libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            Thread 4:  Java: Gang worker#0 (Parallel GC Threads)
            2   libclient.dylib                   0x359baf23 JNI_CreateJavaVM_Impl + 57203
            3   libclient.dylib                   0x359badab JNI_CreateJavaVM_Impl + 56827
            4   libclient.dylib                   0x359ba928 JNI_CreateJavaVM_Impl + 55672
            5   libclient.dylib                   0x359ba588 JNI_CreateJavaVM_Impl + 54744
            6   libclient.dylib                   0x359d0931 jio_vsnprintf + 321
            7   libclient.dylib                   0x359d086a jio_vsnprintf + 122
            8   libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            9   libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            10  libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 5:  Java: Gang worker#1 (Parallel GC Threads)
            Thread 6:  Java: Gang worker#2 (Parallel GC Threads)
            Thread 7:  Java: Gang worker#3 (Parallel GC Threads)
            Thread 8:  Java: Gang worker#4 (Parallel GC Threads)
            Thread 9:  Java: Gang worker#5 (Parallel GC Threads)
            Thread 10:  Java: Gang worker#6 (Parallel GC Threads)
            Thread 11:  Java: Gang worker#7 (Parallel GC Threads)
            Thread 12:  Java: Gang worker#0 (Parallel CMS Threads)
            6   libclient.dylib                   0x35d45eb7 JVM_RaiseSignal + 800087
            Thread 13:  Java: Gang worker#1 (Parallel CMS Threads)
            Thread 14:  Java: Concurrent Mark-Sweep GC Thread
            2   libclient.dylib                   0x359bb037 JNI_CreateJavaVM_Impl + 57479
            3   libclient.dylib                   0x359d7bb0 jio_vsnprintf + 29632
            4   libclient.dylib                   0x359ba9b7 JNI_CreateJavaVM_Impl + 55815
            6   libclient.dylib                   0x35a94b8c JVM_Available + 29852
            7   libclient.dylib                   0x359d7992 jio_vsnprintf + 29090
            Thread 15:  Java: VM Thread
            6   libclient.dylib                   0x35a4ff5b JVM_Lseek + 142763
            7   libclient.dylib                   0x35a4fc8a JVM_Lseek + 142042
            Thread 16:  Java: Reference Handler
            4   libclient.dylib                   0x35a64c95 JVM_MonitorWait + 5461
            5   libclient.dylib                   0x35a63bfe JVM_MonitorWait + 1214
            6   libclient.dylib                   0x35a6387a JVM_MonitorWait + 314
            7   ???                               0x4880b839 0 + 1216395321
            8   ???                               0x48803db1 0 + 1216363953
            9   ???                               0x48803db1 0 + 1216363953
            10  ???                               0x488012d3 0 + 1216352979
            11  libclient.dylib                   0x35a517d0 JVM_Lseek + 149024
            12  libclient.dylib                   0x35a51576 JVM_Lseek + 148422
            13  libclient.dylib                   0x35a6311b JVM_InternString + 2123
            14  libclient.dylib                   0x35a62f8a JVM_InternString + 1722
            15  libclient.dylib                   0x35a62d74 JVM_InternString + 1188
            16  libclient.dylib                   0x35a6280f JVM_StartThread + 2175
            17  libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            18  libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            19  libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 17:  Java: Finalizer
            9   ???                               0x48803f17 0 + 1216364311
            10  ???                               0x48803f17 0 + 1216364311
            11  ???                               0x488012d3 0 + 1216352979
            12  libclient.dylib                   0x35a517d0 JVM_Lseek + 149024
            13  libclient.dylib                   0x35a51576 JVM_Lseek + 148422
            14  libclient.dylib                   0x35a6311b JVM_InternString + 2123
            15  libclient.dylib                   0x35a62f8a JVM_InternString + 1722
            16  libclient.dylib                   0x35a62d74 JVM_InternString + 1188
            17  libclient.dylib                   0x35a6280f JVM_StartThread + 2175
            18  libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            19  libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            20  libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 18:  Java: Surrogate Locker Thread (CMS)
            5   libclient.dylib                   0x359ba4a9 JNI_CreateJavaVM_Impl + 54521
            6   libclient.dylib                   0x35a7a097 JVM_IsPrimitiveClass + 7639
            7   libclient.dylib                   0x35a79c11 JVM_IsPrimitiveClass + 6481
            8   libclient.dylib                   0x35a62d74 JVM_InternString + 1188
            9   libclient.dylib                   0x35a6280f JVM_StartThread + 2175
            10  libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            11  libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            12  libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 19:  Java: Signal Dispatcher
            0   libSystem.B.dylib                 0x0b702336 semaphore_wait_trap + 10
            1   libclient.dylib                   0x35a7ab5e JVM_IsPrimitiveClass + 10398
            2   libclient.dylib                   0x35a7a92e JVM_IsPrimitiveClass + 9838
            3   libclient.dylib                   0x35a62d74 JVM_InternString + 1188
            4   libclient.dylib                   0x35a6280f JVM_StartThread + 2175
            Thread 20:  Java: CompilerThread0
            6   libclient.dylib                   0x35a7bec2 JVM_IsPrimitiveClass + 15362
            7   libclient.dylib                   0x35a7bc9b JVM_IsPrimitiveClass + 14811
            Thread 21:  Java: Low Memory Detector
            6   libclient.dylib                   0x35a7fe32 JVM_IsPrimitiveClass + 31602
            7   libclient.dylib                   0x35a62d74 JVM_InternString + 1188
            8   libclient.dylib                   0x35a6280f JVM_StartThread + 2175
            9   libclient.dylib                   0x359ba33b JNI_CreateJavaVM_Impl + 54155
            10  libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            11  libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 22:  Java: VM Periodic Task Thread
            3   libclient.dylib                   0x35a8110d JVM_IsPrimitiveClass + 36429
            4   libclient.dylib                   0x35a80cb3 JVM_IsPrimitiveClass + 35315
            Thread 23:
            0   libSystem.B.dylib                 0x0b721286 select$DARWIN_EXTSN + 10
            1   com.apple.CoreFoundation          0x03dac82d __CFSocketManager + 1085
            2   libSystem.B.dylib                 0x0b72fa19 _pthread_start + 345
            3   libSystem.B.dylib                 0x0b72f89e thread_start + 34
            Thread 24:
            2   com.apple.CoreFoundation          0x03d6d00f __CFRunLoopRun + 2079
            3   com.apple.CoreFoundation          0x03d6c0f4 CFRunLoopRunSpecific + 452
            4   com.apple.CoreFoundation          0x03d6bf21 CFRunLoopRunInMode + 97
            5   com.apple.Foundation              0x0ba3e434 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
            6   com.apple.Foundation              0x0ba058dc -[NSThread main] + 45
            7   com.apple.Foundation              0x0ba0588c __NSThread__main__ + 1499
            Thread 25:
            0   libSystem.B.dylib                 0x0b727bd2 __workq_kernreturn + 10
            1   libSystem.B.dylib                 0x0b728168 _pthread_wqthread + 941
            2   libSystem.B.dylib                 0x0b727d86 start_wqthread + 30
            Thread 26:
            Thread 0 crashed with X86 Thread State (32-bit):
              eax: 0x0000000c  ebx: 0x18b19c04  ecx: 0x0dab0fea  edx: 0x18b19c28
              edi: 0x18b19c00  esi: 0x18b19c04  ebp: 0xbffff978  esp: 0xbffff950
               ss: 0x0000001f  efl: 0x00010293  eip: 0x0dac0d8a   cs: 0x00000017
               ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
              cr2: 0x0000000c
            Binary Images:
                0x1000 -  0x17c5fe0 +com.adobe.flash 11.0.0.485 (11.0.0) <2343CC5D-89F9-6FED-DC01-7365A3714AB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
            0x20f4000 -  0x226cffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
            0x2310000 -  0x23ddfe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
            0x244c000 -  0x24ddff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
            0x24fc000 -  0x25c9ff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
            0x262c000 -  0x2706fef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
            0x2746000 -  0x30f6fff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
            0x30f9000 -  0x3104fef +libChar16.dylib ??? (???) <0221EB9E-35A8-64CC-5A72-FC3CB24D9854> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libChar16.dylib
            0x310c000 -  0x3123fe0 +libCoreTypes.dylib ??? (???) <6CE8917C-AB39-4A09-2E6B-59C4AEF06701> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libCoreTypes.dylib
            0x3140000 -  0x314ffef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/ZLib.dylib
            0x3154000 -  0x334fff7  com.apple.carbonframeworktemplate 1.0 (1.0) <C10F12ED-AEA6-63FA-7212-A170F37FE049> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
            0x35f1000 -  0x38eafef  com.apple.QuickTime 7.6.6 (1729) <4C99ED7D-5A4B-E41E-602D-2D01A99168CD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
            0x3996000 -  0x39d3ff7  com.apple.SystemConfiguration 1.10.2 (1.10.2) <830FED9E-3E24-004C-35D5-2C1273F79734> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
            0x39f0000 -  0x3c52ff3  com.apple.security 6.1.1 (37594) <1AC07F75-7E27-9662-21DA-B05DFF047B26> /System/Library/Frameworks/Security.framework/Versions/A/Security
            0x3d2d000 -  0x3d2dff7  com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
            0x3d30000 -  0x3ea9ffb  com.apple.CoreFoundation 6.6.1 (550.19) <1E97FB1E-9E42-B8EB-E463-5C75315FDA31> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
            0x3fa1000 -  0x3fa1ff7  com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
            0x3fa9000 -  0x408dff7  com.apple.WebKit 6531.22 (6531.22.7) <87C81D6F-77B1-C517-93E6-5DEF214326A7> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
            0x4114000 -  0x4114ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
            0x4117000 -  0x411eff7  com.apple.JavaVM 13.1.0 (13.1.0) <2842C4EE-869D-81E6-E771-062F583A1044> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
            0x4127000 -  0x4eb2fe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
            0x5c97000 -  0x5cdbfff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
            0x5d3e000 -  0x5d84fff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
            0x5df9000 -  0x5df9fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
            0x5dfd000 -  0x5e19ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
            0x5e33000 -  0x5f47fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
            0x5f6a000 -  0x646cfef +AdobeAGM ??? (???) <5B8478AC-5DD0-F116-5B3E-45596CF551C6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
            0x65a8000 -  0x65e3fff +AdobeARE ??? (???) <CEE507DA-9B96-FAF9-7894-445C427C3D7A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
            0x65ec000 -  0x6606fff +AdobeBIB ??? (???) <5533CDC7-676C-0CF0-97B7-8EDD26837FFC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
            0x660f000 -  0x6630ff7 +AdobeBIBUtils ??? (???) <726B8463-9301-CE6C-0F2C-5CA81795A4CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
            0x663c000 -  0x692eff7 +AdobeCoolType ??? (???) <2BF62C8A-D715-FDE8-650C-1984CFFCE33C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
            0x69b6000 -  0x6d8eff7 +AdobeMPS ??? (???) <272DAEDE-FC7E-B412-7C97-CF47FF6BF242> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
            0x6ebd000 -  0x6f9bfef +AdobePDFPort ??? (???) <324E65FD-0011-F93F-9B92-FB4E17968181> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
            0x6fd1000 -  0x7605feb +AdobePDFL ??? (???) <1A619F3E-A9D4-A99C-791E-92B564F64609> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
            0x7731000 -  0x7757ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
            0x7768000 -  0x778ffed +AdobeAXE16SharedExpat ??? (???) <66F4E782-C848-AD92-686D-5A479A4B333A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
            0x77a1000 -  0x77f9ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
            0x7808000 -  0x7875fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
            0x7890000 -  0x7a2ffe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
            0x7a98000 -  0x87dbfff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
            0x8b1a000 -  0x8b75ff7  com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
            0x8b94000 -  0x8d7aff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
            0x8e08000 -  0x8e0cffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
            0x8e13000 -  0x8f14fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
            0x8f38000 -  0x91f1fe7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54AE7B13-C660-531F-B508-33372008A21E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
            0x94f2000 -  0x9647fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <5BEA3AAE-2865-D8AF-F798-704D00DACC17> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
            0x979c000 -  0x9ab1fe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <AFDABF21-752A-2341-6A4E-62DA544BEA94> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
            0x9f76000 -  0xa0a2fff  com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
            0xa108000 -  0xa16effb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
            0xa19e000 -  0xa1f1ffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
            0xa239000 -  0xa24bfff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
            0xa254000 -  0xa38cfe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
            0xa3ce000 -  0xa3d4fef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <44362FE9-5F8A-A2EE-88E4-6876D6D8507F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
            0xa3e5000 -  0xa3f0ff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <27F6A491-0234-ED1A-CC83-A792D5865E97> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
            0xa404000 -  0xa482fe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <4B98FD95-A873-1A50-FFC7-BC6D90759A1A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
            0xa4e6000 -  0xa4f0fff +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <6D8C35A9-703F-852C-6CF0-D7DC36796BC6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
            0xa503000 -  0xa505ffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <CE5A959A-AA4D-5983-79B3-8C47CFDDC446> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
            0xa50d000 -  0xa514ff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <E752F69B-EA07-7079-CFF1-118E97A4A8FD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
            0xa524000 -  0xa6b5ff3 +aflamingo ??? (???) <C4136948-FE16-15C4-F1B9-040E014AF2CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
            0xa878000 -  0xa87bff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
            0xa881000 -  0xa979ff7 +FlashIK Framework ??? (1.0) <3982AF5C-BAE4-1FC6-DB73-4EF99B23994A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
            0xaa10000 -  0xaa50ffb +PFF Framework ??? (1.0) <8DB6CAC7-8E77-7FD0-140B-D60BE8D0556E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
            0xaa7d000 -  0xb479fef +aflame ??? (???) <B07806FD-0449-CBC6-FB92-0745A6D914D5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
            0xb63c000 -  0xb6a6fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
            0xb701000 -  0xb8a6feb  libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
            0xb926000 -  0xb9d3fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
            0xb9e7000 -  0xb9e7ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
            0xb9ef000 -  0xbc5fffb  com.apple.Foundation 6.6.2 (751.21) <DA7A173A-4435-ECD6-F4AF-977D722FD2F7> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            0xbd6e000 -  0xc64dff7  com.apple.AppKit 6.6.5 (1038.29) <E76A05A6-27C6-DA02-0961-5C8EEDC5F0A7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            0xcae6000 -  0xcaf0fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
            0xcaf8000 -  0xcafefff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
            0xcb06000 -  0xcb09ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
            0xcb0e000 -  0xce32fef  com.apple.HIToolbox 1.6.2 (???) <F5F99E78-5377-DD54-6138-9FC84467F938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
            0xcf72000 -  0xcfd6ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
            0xcff8000 -  0xd00dfff  com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
            0xd023000 -  0xd0d1ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
            0xd0fb000 -  0xd13eff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
            0xd167000 -  0xd183fe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
            0xd193000 -  0xd195ff7  com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
            0xd19a000 -  0xd1a4ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
            0xd1ad000 -  0xd227fef  com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
            0xd259000 -  0xd25cfe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
            0xd25f000 -  0xd57ffeb  com.apple.CoreServices.CarbonCore 861.6 (861.6) <D3D5D9F1-01ED-DCAD-6AA9-4ABE60C7A112> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            0xd5f3000 -  0xd69cff7  com.apple.CFNetwork 454.9.4 (454.9.4) <2F8B5BA5-099F-6CDA-F500-4CA188BBCDBC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
            0xd700000 -  0xd744fe7  com.apple.Metadata 10.6.3 (507.8) <53BB360A-1813-170D-827F-C1863EF15537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
            0xd76b000 -  0xd835fef  com.apple.CoreServices.OSServices 357 (357) <764872C3-AE30-7F54-494D-4BA3CE4F4DFB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
            0xd894000 -  0xd914feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
            0xd948000 -  0xd97bff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
            0xd993000 -  0xda30fe3  com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
            0xda6f000 -  0xda95fff  com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
            0xdaac000 -  0xdc2efe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
            0xdc90000 -  0xdc99ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
            0xdca3000 -  0xdcb7fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
            0xdcc0000 -  0xdccdff7  com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
            0xdcd6000 -  0xdce4fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
            0xdce9000 -  0xdcf5ff7  libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
            0xdcf9000 -  0xdd3fff7  libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
            0xdd4c000 -  0xde05fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
            0xde13000 -  0xde3bff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
            0xde46000 -  0xe635537  com.apple.CoreGraphics 1.543.33 (???) <C57E2964-80AF-6346-6D3E-23AED9D26977> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
            0xe6fd000 -  0xe8b9ff3  com.apple.ImageIO.framework 3.0.2 (3.0.1) <CB39B067-58B8-70DB-3E40-160604664A6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
            0xe913000 -  0xe974fe7  com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
            0xe9ac000 -  0xea47ff7  com.apple.ApplicationServices.ATS 4.2 (???) <3BEB7210-4C85-7309-B22D-695765526524> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
            0xea6e000 -  0xeb1eff3  com.apple.ColorSync 4.6.3 (4.6.3) <68B6A1B9-86CF-0C5A-7D63-56ED4BB2EB5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
            0xeb55000 -  0xeba6ff7  com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
            0xebd0000 -  0xebe1ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
            0xebee000 -  0xec96ffb  com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
            0xecc3000 -  0xecd7ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
            0xece5000 -  0xece5ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
            0xece8000 -  0xed31fe7  libTIFF.dylib ??? (???) <E45B169E-253E-E865-1501-97777D2702F2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
            0xed3c000 -  0xed40ff7  libGIF.dylib ??? (???) <03880BA1-7A86-0F2B-617A-C66B1D05DD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
            0xed45000 -  0xed60ff7  libPng.dylib ??? (???) <929FE8EE-277D-F6EB-D672-E6F4CEBF1504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
            0xed67000 -  0xed69ff7  libRadiance.dylib ??? (???) <9358E1EF-F802-B76E-8E23-2D0695787CFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
            0xed6d000 -  0xed91ff7  libJPEG.dylib ??? (???) <EDA86712-F49C-760C-BE55-9B899A4A5D1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
            0xed98000 -  0xee75ff7  com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
            0xee83000 -  0xee83ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
            0xee86000 -  0xeec8ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
            0xeed1000 -  0xef40ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
            0xef49000 -  0xf35fff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
            0xf3a1000 -  0xf7d6ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
            0xf95c000 -  0xfa4eff7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7482933B-4AF6-ED55-AD72-4FBD1E134958> /usr/lib/libcrypto.0.9.8.dylib
            0xfaa0000 -  0xfaa1ff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
            0xfaa5000 -  0xfb5bfff  libFontParser.dylib ??? (???) <5935E105-1E45-886C-6420-C1CCA886C375> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
            0xfbeb000 -  0xfc20ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <458E819A-4E3F-333E-28CE-671281B318D3> /usr/lib/libcups.2.dylib
            0xfc2d000 -  0xfc4dfe7  libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <03019DD7-993D-AC88-6636-179F92F315C4> /usr/lib/libresolv.9.dylib
            0xfc57000 -  0xfc9bff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
            0xfcba000 - 0x10021ff7  com.apple.QuartzCore 1.6.1 (227.18) <8A65F233-4C77-BA7C-5DDA-2423F5C1B7A1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
            0x100f0000 - 0x101cbfe7  com.apple.DesktopServices 1.5.5 (1.5.5) <ECEDFDF2-C40E-8DF0-F8FC-249CCA762E62> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
            0x10216000 - 0x10266ff7  com.apple.framework.familycontrols 2.0.1 (2010) <50E74916-19A5-F2FC-AB57-76F2C8DDF0A7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
            0x1027d000 - 0x1028fff7  com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <6BB58E90-21FA-C491-F0E4-54B69CCDBBC0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
            0x1029c000 - 0x102baff7  com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
            0x102d1000 - 0x102dfff7  com.apple.opengl 1.6.7 (1.6.7) <3C529790-DEE9-AC27-A879-806E4C23323C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
            0x102e7000 - 0x10318ff7  libGLImage.dylib ??? (???) <AF110892-B10A-5B61-F898-21FB2BCE63BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
            0x10320000 - 0x10341fe7  com.apple.opencl 12.1 (12.1) <1BCA4F60-E612-5C1B-EF50-A810D70CDF05> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
            0x1034a000 - 0x1034eff7  IOSurface ??? (???) <4B825ADA-8DBE-6BA2-1AB3-307D2C3AFCA8> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
            0x10356000 - 0x10399ff7  libGLU.dylib ??? (???) <CE02968E-930D-E63B-7B21-B87205F8B19A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
            0x103a7000 - 0x103b2ff7  libGL.dylib ??? (???) <EAD85409-9036-831B-C378-E50780305DA6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
            0x103c1000 - 0x104cdff7  libGLProgrammability.dylib ??? (???) <CA0A975B-2BEE-44E7-CFA6-8105CFE6FE00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
            0x104ec000 - 0x104efff7  libCoreVMClient.dylib ??? (???) <98CB96B1-85FE-25AF-AB19-ED061912FC3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
            0x104f4000 - 0x104f8ff7  libGFXShared.dylib ??? (???) <286F466C-2856-B579-B87F-4E9A35C80263> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
            0x104fd000 - 0x104feff7  com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
            0x10503000 - 0x10503ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
            0x10506000 - 0x10588ffb  SecurityFoundation 36840.0.0 (compatibility 1.0.0) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
            0x105bf000 - 0x105c4ff7  com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
            0x105cc000 - 0x105e4ff7  com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
            0x105f5000 - 0x10642feb  com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
            0x1065e000 - 0x10680fef  com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
            0x1068a000 - 0x1069aff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
            0x106a1000 - 0x107cffe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
            0x10833000 - 0x10833ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
            0x10837000 - 0x109d5feb  com.apple.JavaScriptCore 6531.22 (6531.22.5) <3FB9AF5B-17DD-D4C8-C7B1-4F79B404496E> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
            0x10a24000 - 0x11257fe7  com.apple.WebCore 6531.22 (6531.22.7) <952A0D34-63F5-F7F7-D6E5-D0AD78002F89> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
            0x116e2000 - 0x116e9ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6BF89127-C18C-27A9-F94A-981836A822FE> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
            0x116f0000 - 0x117e4ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
            0x117f2000 - 0x11830ff7  com.apple.QuickLookFramework 2.2 (327.4) <88A59C42-A200-FCB6-23EC-E848D0E14963> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
            0x11853000 - 0x11893ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
            0x118ac000 - 0x11961fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
            0x119db000 - 0x119ddffd +com.macromedia.Flash.FLfile 11.0.0.485 (11.0.0) <5DA72BFA-D78D-94E0-0F0F-9EAC705646C6> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
            0x11c48000 - 0x11c49ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
            0x11edc000 - 0x11f43fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
            0x11f82000 - 0x11ff2feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
            0x174d5000 - 0x174ddfff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
            0x17700000 - 0x1770bff7  libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <F914F427-98EA-98BC-923D-47274A90D441> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
            0x17714000 - 0x17720ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.5 (2.2.5) <CD6C7A74-BA03-F3A7-0D1E-460E6A043024> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
            0x1772a000 - 0x1776bff7  libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <C6E50C7E-EBEE-32AF-FF07-8E325E21A838> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
            0x177eb000 - 0x177ecff7  ATSHI.dylib ??? (???) <B370C4CD-44F6-1241-EC63-F8F02A96275B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
            0x177f1000 - 0x177f4ff7  libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <69BE578C-A364-A150-35E3-53EE00F56F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
            0x177fc000 - 0x177fcff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
            0x1862d000 - 0x1863bfe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <4C9CC2D9-2F13-4465-5447-2516FCD9255B> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
            0x1863f000 - 0x18651ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <C4E0D62B-4D1A-8DAD-D10B-2C055AA0479C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
            0x18655000 - 0x18690feb  libFontRegistry.dylib ??? (???) <F50A60E1-3757-D007-A20D-A5504C17334C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistry.dylib
            0x186ab000 - 0x186dcff3  libTrueTypeScaler.dylib ??? (???) <F6A32C01-CD82-54F6-218E-0406D40D1D9A> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libTrueTypeScaler.dylib
            0x186e8000 - 0x18761ff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
            0x18797000 - 0x187beff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
            0x187dc000 - 0x187e2ff7  com.apple.DisplayServicesFW 2.2.2 (251) <D8BB3A1F-29C7-A957-C781-794CC9550525> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
            0x187eb000 - 0x187ecff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
            0x187f6000 - 0x187faff3  com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <C36F9194-6DB6-0AA8-4839-71191EEBAC65> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
            0x194a3000 - 0x19df2ff3 +com.macromedia.Flash Player.authplaylib 10.1.52.14 (1.0.1d333) <23ED9968-F20E-1132-26B1-0BC42DC14A05> /Applications/Adobe Flash CS5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
            0x19e94000 - 0x19fd6fe3  com.apple.QTKit 7.6.6 (1729) <1EC021FB-AB8F-F8BF-0434-78C0A7B78EB2> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
            0x1a08c000 - 0x1a2b7ff3  com.apple.QuartzComposer 4.1 (156.13) <FE0BF06B-8D32-C712-7CCD-63D8918B8B6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
            0x1a398000 - 0x1a57afff  com.apple.imageKit 2.0.3 (1.0) <56AE34CD-4406-8AA2-DDBF-DBF902BD0E0A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
            0x1a64c000 - 0x1a6baff7  com.apple.QuickLookUIFramework 2.2 (327.4) <5B6A066B-B867-D3A3-BDEE-3D68FA5385B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
            0x1a6f6000 - 0x1a726ff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
            0x1a745000 - 0x1a79bff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
            0x1a7cb000 - 0x1a8cdfef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
            0x1a934000 - 0x1a972ff7  com.apple.CoreMedia 0.484.5 (484.5) <35725D22-4549-5568-8E8C-62E0AD0E90F7> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
            0x1a98d000 - 0x1ab0dfeb  com.apple.MediaToolbox 0.484.5 (484.5) <6996E5E1-18B6-C734-8335-FE43670C1F9C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
            0x1ab7d000 - 0x1b03affb  com.apple.VideoToolbox 0.484.5 (484.5) <DA9B4FA8-B91C-43AC-1D84-0BFF46BB5BCE> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
            0x1b0e3000 - 0x1b129ffb  com.apple.CoreMediaIOServices 130.0 (1035) <397101F4-BA80-C8C2-F816-E2FBE5E15D4F> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
            0x1b14a000 - 0x1b1bbff7  com.apple.AppleVAFramework 4.8.11 (4.8.11) <BDDDFA36-4B53-4B57-B3D4-427DA8226A80> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
            0x1b1c4000 - 0x1b21cfe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
            0x1b245000 - 0x1b29ffe7  com.apple.CorePDF 1.1 (1.1) <E4608FF6-A27D-7DFC-5620-D86762502AC0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
            0x1b2ce000 - 0x1b2deff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
            0x1b2e9000 - 0x1b328ff7  com.apple.ImageCaptureCore 1.0.1 (1.0.1) <A03C5D7E-54CD-D56D-E120-9B35EBC9D8F1> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
            0x1b588000 - 0x1b58effb  com.apple.audio.AppleHDAHALPlugIn 1.8.4 (1.8.4fc3) <89AF8F46-15E4-2066-BDDB-05E92C1368D4> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
            0x1b593000 - 0x1b597ffc +com.srslabs.iwow ??? (3.1) /Library/Audio/Plug-Ins/HAL/iWow.plugin/Contents/MacOS/iTea
            0x1b67b000 - 0x1b9faff3  com.apple.RawCamera.bundle 3.0.2 (527) <981AB834-6C34-6FA5-F886-01DF06C56609> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
            0x1bca4000 - 0x1bcaeff7  com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
            0x1bccb000 - 0x1bea6ff3  libType1Scaler.dylib ??? (???) <944F686E-9CC2-03F0-A139-8F322F0AC49F> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libType1Scaler.dylib
            0x1c406000 - 0x1c42ffeb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
            0x1c43f000 - 0x1c45affb +com.adobe.adobe_oobe_launcher Adobe OOBE Launcher 1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00) (1.0.0.64) <985DF5E7-CB4E-4CED-A47A-FA080D9EDBBE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_launcher
            0x1c700000 - 0x1c739ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
            0x1c754000 - 0x1c768ffb +com.yourcompany.PointGrid ??? (1.0) <97938B0E-FD0E-BC24-12A5-90D33523249D> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
            0x1dc5b000 - 0x1dc60ff7  libFontStreams.A.dylib 543.33.0 (compatibility 64.0.0) <8120797D-291E-FD6A-D96B-055E01B468C1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
            0x1ddab000 - 0x1ddb3ff7  libverify.dylib 1.0 (1.0) <0E0C6835-68C5-A72F-8CA0-77857B632513> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
            0x1debc000 - 0x1debdffd +com.1passwd.InputManager 2.6.5 (6911) <FE6F08FC-7E91-4653-2523-F18286CF5EBF> /Library/InputManagers/1PasswdIM/1PasswdIM.bundle/Contents/MacOS/1PasswdIM
            0x1df8b000 - 0x1df92ff7  JavaNativeFoundation ??? (???) <1107BBC2-DFC1-CF1F-44EE-27F7D4349BE6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
            0x1f3dc000 - 0x1f3fffe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
            0x1f435000 - 0x1f441ff7  libzip.jnilib ??? (???) <1317EACC-2494-70C3-4B43-FC9D04579EAF> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
            0x1f48a000 - 0x1f4a7ff7  libjava.jnilib ??? (???) <C4C57812-6A25-85AB-441B-DE1A71A8DF18> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
            0x1f93f000 - 0x1f962fe7  GLRendererFloat ??? (???) <65E1E174-28E0-3FA9-E391-504891B69818> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
            0x1f9dc000 - 0x1f9e2ff7  libCGXCoreImage.A.dylib 543.33.0 (compatibility 64.0.0) <DD359830-97D4-0CD4-8666-DFE450E8D633> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
            0x1f9fb000 - 0x1f9ffff7  com.apple.qldisplay.Generic 2.2 (327.4) <FFAE5FA3-DFAD-3906-E575-5C342F3D034E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/Resources/DisplayBundles/Generic.qldisplay/Contents/MacOS/Generic
            0x1fa2b000 - 0x1fa2dfff +com.unsanity.menuextraenabler 1.0.3 (1.0.3) /Library/InputManagers/Menu Extra Enabler/Menu Extra Enabler.bundle/Contents/MacOS/Menu Extra Enabler
            0x1fa3c000 - 0x1fa3efff +net.culater.SIMBL 0.8.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
            0x1faeb000 - 0x1fb09ffb +com.adobe.flash.anemoi 11.0.0.485 (11.0.0) <0A4316BC-6FFE-C2FA-8F58-20BD7D720A40> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Air2_0.bundle/Contents/MacOS/Air2_0
            0x20000000 - 0x20098fe7  edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
            0x30b00000 - 0x30bd1fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <0A608513-31AD-D533-8386-10245FD62057> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
            0x31700000 - 0x31873fe7  GLEngine ??? (???) <F0181B85-962E-508D-4912-056D87F8E96E> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
            0x32f9c000 - 0x32fdaffb +com.adobe.flash.flbridge 11.0.0.485 (11.0.0) <10AA8563-6870-61EE-1CEE-0FB603AD2BE4> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
            0x33f00000 - 0x33f67ffb +com.yourcompany.Brush ??? (1.0) <25E6C744-6FCC-CF39-C01F-C14BAA743519> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
            0x33f9c000 - 0x34027feb +com.yourcompany.Collision ??? (1.0) <258F5AD8-2C92-833F-1076-105635401C53> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
            0x34547000 - 0x3494bfe7  libclh.dylib 3.1.1 C  (3.1.1) <FBDA4CAC-EBB3-2129-7EE3-E8E9381974C9> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
            0x34bf5000 - 0x34c68fff  com.apple.iLifeMediaBrowser 2.1.5 (368) <30261504-7533-5424-DD15-32739DED6FB0> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
            0x359ac000 - 0x35da2fe7  libclient.dylib ??? (???) <6B8B4A7E-2844-3AD6-239E-122121D37485> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
            0x36e18000 - 0x36e42ff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
            0x36e5b000 - 0x36e91fff  libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
            0x38700000 - 0x38809ff7 +com.yourcompany.Stroke ??? (1.0) <42A62A75-F5EB-27E7-47B3-B14FEABA4693> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
            0x3e672000 - 0x3e7a9ff7  com.apple.CoreAUC 6.04.00 (6.04.00) <0551FB8D-0894-B40B-B924-4AF51E3648AF> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
            0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <EF392886-5A95-6A96-C95D-43DA0322925C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
            0x4070f000 - 0x41660fe7  com.apple.QuickTimeComponents.component 7.6.6 (1729) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
            0x64b00000 - 0x64b07ff3  com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
            0x8f12c000 - 0x8f7b4fff  com.apple.GeForceGLDriver 1.6.10 (6.1.0) <EFC80A22-4F62-3DFC-A391-738B2A8A4E56> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
            0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
            0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
            0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <4FB5CEEB-8D3E-8C57-1718-81D7CAFBFE69> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
            0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <A23F9980-5CC8-A44D-6FD6-DBFCBFF4FF28> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
            0xbb100000 - 0xbb103fe7  libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <59D12876-5E0C-803C-EC99-832012CF3416> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
            0xfa100000 - 0xfa192fe3  com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
            0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
            • 3. Re: Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
              nrajbhan Level 3
              It looks like a crash in an Apple library:  libicucore.A.dylib.  However, we can't tell what the root cause of the crash is from the log.
              Are you still encountering this crash?
              Nivesh
              • 4. Re: Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
                spudnut Level 1
                Hi Nivesh,
                So far so good after the uninstall/reinstall. Hopefully it was a just a weird fluke. I appreciate your time!
                • 5. Re: Flash CS5 crash and corruption during previewing attempt Mac OSX 10.6.3
                  kwadwoadu
                  MY flash cs5 crashede everytime i try to change things or watch it in preview mode
                  Process:         Adobe Flash CS5 [3862]
                  Parent Process:  launchd [94]
                  Date/Time:       2010-09-10 12:04:22.371 +0200
                  Report Version:  6
                  Interval Since Last Report:          7535051 sec
                  Crashes Since Last Report:           103
                  Per-App Interval Since Last Report:  489930 sec
                  Per-App Crashes Since Last Report:   16
                  Anonymous UUID:                      80D87894-64DF-4BC6-9FF7-234A37EE570F
                  Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000048
                  Java information:
                  Exception type: Bus Error (0xa) at pc=0x03104bb7
                  Current thread (0x2e800c00):  JavaThread "main" [_thread_in_native, id=-1605589792, stack(0xbf800000,0xc0000000)]
                    0x3e024400 JavaThread "Thread-2" [_thread_blocked, id=-1312194560, stack(0xb1b98000,0xb1c98000)]
                    0x3e01e000 JavaThread "RegisterThread" [_thread_blocked, id=-1313804288, stack(0xb1a0f000,0xb1b0f000)]
                    0x2e8cf000 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1316081664, stack(0xb17e3000,0xb18e3000)]
                    0x2e8ce400 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1317138432, stack(0xb16e1000,0xb17e1000)]
                    0x2e8c2400 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1318195200, stack(0xb15df000,0xb16df000)]
                    0x2e8c1c00 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1319251968, stack(0xb14dd000,0xb15dd000)]
                    0x2e8bbc00 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1320886272, stack(0xb134e000,0xb144e000)]
                    0x3e042800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1322999808, stack(0xb114a000,0xb124a000)]
                    0x3e041800 JavaThread "CompilerThread0" daemon [_thread_blocked_trans, id=-1324056576, stack(0xb1048000,0xb1148000)]
                    0x3e040c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1325113344, stack(0xb0f46000,0xb1046000)]
                    0x3e03fc00 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1326170112, stack(0xb0e44000,0xb0f44000)]
                    0x2e876800 JavaThread "Finalizer" daemon [_thread_in_vm, id=-1327226880, stack(0xb0d42000,0xb0e42000)]
                    0x2e875800 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1328283648, stack(0xb0c40000,0xb0d40000)]
                  =>0x2e800c00 JavaThread "main" [_thread_in_native, id=-1605589792, stack(0xbf800000,0xc0000000)]
                  Other Threads:
                    0x2e871c00 VMThread [stack: 0xb0b3e000,0xb0c3e000] [id=-1329340416]
                    0x3e04b400 WatcherThread [stack: 0xb124c000,0xb134c000] [id=-1321943040]
                  VM state:synchronizing (normal execution)
                  VM Mutex/Monitor currently owned by a thread:  ([mutex/lock_event])
                  [0x2e301890] Safepoint_lock - owner thread: 0x2e871c00
                  [0x2e3018f0] Threads_lock - owner thread: 0x2e871c00
                  Heap
                  par new generation   total 14336K, used 2173K [0x40100000, 0x41100000, 0x41100000)
                    eden space 12288K,   1% used [0x40100000, 0x4011f588, 0x40d00000)
                    from space 2048K, 100% used [0x40d00000, 0x40f00000, 0x40f00000)
                    to   space 2048K,   0% used [0x40f00000, 0x40f00000, 0x41100000)
                  concurrent mark-sweep generation total 49152K, used 18K [0x41100000, 0x44100000, 0x48100000)
                  concurrent-mark-sweep perm gen total 12288K, used 7231K [0x48100000, 0x48d00000, 0x4c100000)
                  Physical Memory: Page Size = 4k, Total = 3840M, Free = 491M
                  0   libCoreTypes.dylib            0x03104bb7 CString::operator+=(CString const&) + 13
                  1   com.adobe.flash               0x007887d1 CURI::~CURI() + 13775
                  2   com.adobe.flash               0x00788bb0 CURI::~CURI() + 14766
                  3   com.adobe.flash               0x00789065 CURI::~CURI() + 15971
                  4   com.adobe.flash               0x007891c0 CURI::~CURI() + 16318
                  5   com.adobe.flash               0x0073ab4c AuthASCPackageManager::GetSourcePath() + 18
                  6   com.adobe.flash               0x007391e0 CBitmapComboBox::GetRuntimeClass() const + 61538
                  7   com.adobe.flash               0x00361575 std::vector<CPicAction, std::allocator<CPicAction> >::push_back(CPicAction const&) + 78571
                  8   com.adobe.flash               0x00361c21 std::vector<CPicAction, std::allocator<CPicAction> >::push_back(CPicAction const&) + 80279
                  9   com.adobe.flash               0x0005f922 MFIVideoModuleDefinition::~MFIVideoModuleDefinition() + 1518
                  10  com.adobe.flash               0x00077f9b MFIVideoModuleDefinition::~MFIVideoModuleDefinition() + 101479
                  11  com.adobe.flash               0x00d9e9db TArray<LAttachment*>::~TArray() + 565
                  12  com.adobe.flash               0x00156527 std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> >::operator=(std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> > const&) + 3617
                  13  com.adobe.flash               0x001a3c25 CSketchViewPrintContext::CSketchViewPrintContext() + 131817
                  14  com.adobe.flash               0x00f1cfa4 MMUI::COwlFrameWnd::~COwlFrameWnd() + 2378
                  15  com.adobe.flash               0x00106157 non-virtual thunk to CMainFrame::ActivateAccelerators(TAcceleratorVector) + 5345
                  16  com.adobe.flash               0x00d7da65 non-virtual thunk to CStdioFile::~CStdioFile() + 18475
                  17  com.adobe.flash               0x00d7a0e7 non-virtual thunk to CStdioFile::~CStdioFile() + 3757
                  18  com.adobe.flash               0x00d79fb2 non-virtual thunk to CStdioFile::~CStdioFile() + 3448
                  19  com.adobe.flash               0x00f1aa3c CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::~CList() + 2184
                  20  com.adobe.flash               0x00f1918a std::vector<CSize, std::allocator<CSize> >::~vector() + 2032
                  21  com.adobe.flash               0x00d12efc non-virtual thunk to CButtonOwnerDrawImpl::~CButtonOwnerDrawImpl() + 9070
                  22  com.adobe.flash               0x00d45d5e CRadioGroupImpl::~CRadioGroupImpl() + 1372
                  23  com.adobe.flash               0x001c18d1 CPrintDialog::~CPrintDialog() + 7029
                  24  com.adobe.flash               0x001bfef8 CPrintDialog::~CPrintDialog() + 412
                  25  com.adobe.flash               0x00d39f82 non-virtual thunk to CFormViewImpl::~CFormViewImpl() + 1690
                  26  com.adobe.flash               0x0016ed77 std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> >::operator=(std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> > const&) + 104049
                  27  com.adobe.flash               0x00534070 std::vector<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >::push_back(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&) + 36812
                  28  com.adobe.flash               0x00e3b44e non-virtual thunk to LMLTEPane::DontBeTarget() + 201214
                  29  com.adobe.flash               0x00e358ba non-virtual thunk to LMLTEPane::DontBeTarget() + 177770
                  30  com.adobe.flash               0x00e3acf5 non-virtual thunk to LMLTEPane::DontBeTarget() + 199333
                  31  com.adobe.flash               0x00e0c667 non-virtual thunk to LMLTEPane::DontBeTarget() + 9239
                  32  com.adobe.flash               0x00e0c6e4 non-virtual thunk to LMLTEPane::DontBeTarget() + 9364
                  33  com.adobe.flash               0x00542c17 JSInterp::EvaluateScript(JSContext*, JSObject*, unsigned short const*, unsigned int, unsigned short const*, unsigned int, long*) + 225
                  34  com.adobe.flash               0x00541b9b std::vector<CSwfPanel*, std::allocator<CSwfPanel*> >::push_back(CSwfPanel* const&) + 21551
                  35  com.adobe.flash               0x00542539 std::vector<CSwfPanel*, std::allocator<CSwfPanel*> >::push_back(CSwfPanel* const&) + 24013
                  36  com.adobe.flash               0x004ac375 CArray<int, int&>::CArray() + 6739
                  37  ...ia.Flash Player.authplaylib 0x21c2ba58 0x21be3000 + 297560
                  38  ...ia.Flash Player.authplaylib 0x21f2770e 0x21be3000 + 3426062
                  39  ...ia.Flash Player.authplaylib 0x21e51c33 0x21be3000 + 2550835
                  40  ...ia.Flash Player.authplaylib 0x21e4ee73 0x21be3000 + 2539123
                  41  ...ia.Flash Player.authplaylib 0x22000720 0x21be3000 + 4314912
                  42  ...ia.Flash Player.authplaylib 0x22002b8d 0x21be3000 + 4324237
                  43  ...ia.Flash Player.authplaylib 0x220609d9 ExternalPlayer_Initialize + 209705
                  44  ...ia.Flash Player.authplaylib 0x2202e979 ExternalPlayer_Initialize + 4809
                  45  com.adobe.flash               0x004bea51 CFlashPlayerView::AllowTabOnCreation() + 13693
                  46  com.adobe.flash               0x00d8b568 CDC::~CDC() + 4504
                  47  com.adobe.flash               0x00d7071d non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 7985
                  48  com.adobe.flash               0x00d6ec22 non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 1078
                  49  com.apple.HIToolbox           0x95d440a9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
                  50  com.apple.HIToolbox           0x95d43370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                  51  com.apple.HIToolbox           0x95d65b55 SendEventToEventTarget + 52
                  52  com.apple.HIToolbox           0x95d7763b ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
                  53  com.apple.HIToolbox           0x95d444fa DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
                  54  com.apple.HIToolbox           0x95d43370 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
                  55  com.apple.HIToolbox           0x95d65b55 SendEventToEventTarget + 52
                  56  com.apple.HIToolbox           0x95eeedf7 ToolboxEventDispatcher + 86
                  57  com.apple.HIToolbox           0x95eeef2f RunApplicationEventLoop + 243
                  58  com.adobe.flash               0x00d6f8ba non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
                  59  com.adobe.flash               0x00d460df CTimerImpl::~CTimerImpl() + 297
                  60  com.adobe.flash               0x00d4618b CTimerImpl::~CTimerImpl() + 469
                  61  com.adobe.flash               0x00004036 0x1000 + 12342
                  Thread 1:  Dispatch queue: com.apple.libdispatch-manager
                  0   libSystem.B.dylib             0x93807b42 kevent + 10
                  1   libSystem.B.dylib             0x9380825c _dispatch_mgr_invoke + 215
                  2   libSystem.B.dylib             0x93807719 _dispatch_queue_invoke + 163
                  3   libSystem.B.dylib             0x938074be _dispatch_worker_thread2 + 240
                  4   libSystem.B.dylib             0x93806f41 _pthread_wqthread + 390
                  5   libSystem.B.dylib             0x93806d86 start_wqthread + 30
                  Thread 2:
                  0   libSystem.B.dylib             0x937e1342 semaphore_wait_signal_trap + 10
                  1   libSystem.B.dylib             0x9380eeb8 _pthread_cond_wait + 1089
                  2   libSystem.B.dylib             0x9385742f pthread_cond_wait + 48
                  3   com.adobe.amt.services        0x20c9d126 AMTConditionLock::LockWhenCondition(int) + 46
                  4   com.adobe.amt.services        0x20c95db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
                  5   com.adobe.amt.services        0x20c9d18c AMTThread::Worker(void*) + 24
                  6   libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  7   libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 3:
                  0   libSystem.B.dylib             0x9380f262 __semwait_signal + 10
                  1   libSystem.B.dylib             0x9380ef1e _pthread_cond_wait + 1191
                  2   libSystem.B.dylib             0x93810bb8 pthread_cond_wait$UNIX2003 + 73
                  3   ...ple.CoreServices.CarbonCore 0x9670aaee TSWaitOnCondition + 126
                  4   ...ple.CoreServices.CarbonCore 0x966f643d TSWaitOnConditionTimedRelative + 202
                  5   ...ple.CoreServices.CarbonCore 0x966f1e0f MPWaitOnQueue + 250
                  6   AdobeACE                      0x0533c6f1 0x5302000 + 239345
                  7   AdobeACE                      0x0533c0ed 0x5302000 + 237805
                  8   ...ple.CoreServices.CarbonCore 0x966d5eb6 PrivateMPEntryPoint + 68
                  9   libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  10  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 4:
                  0   libSystem.B.dylib             0x93800286 select$DARWIN_EXTSN + 10
                  1   com.apple.CoreFoundation      0x9067b82d __CFSocketManager + 1085
                  2   libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  3   libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 5:
                  0   libSystem.B.dylib             0x9381e572 recvfrom$UNIX2003 + 10
                  1   libSystem.B.dylib             0x9383e383 recv$UNIX2003 + 54
                  2   ServiceManager-Launcher.dylib 0x22bb56cf Invoke + 54887
                  3   ServiceManager-Launcher.dylib 0x22bb476e Invoke + 50950
                  4   ServiceManager-Launcher.dylib 0x22bb361f Invoke + 46519
                  5   ServiceManager-Launcher.dylib 0x22bb3671 Invoke + 46601
                  6   ServiceManager-Launcher.dylib 0x22bb36fb Invoke + 46739
                  7   ServiceManager-Launcher.dylib 0x22badafe Invoke + 23190
                  8   ServiceManager-Launcher.dylib 0x22badce7 Invoke + 23679
                  9   ServiceManager-Launcher.dylib 0x22bae8c7 Invoke + 26719
                  10  ServiceManager-Launcher.dylib 0x22bae9c5 Invoke + 26973
                  11  ServiceManager-Launcher.dylib 0x22bb1db0 Invoke + 40264
                  12  ServiceManager-Launcher.dylib 0x22bb2059 Invoke + 40945
                  13  ServiceManager-Launcher.dylib 0x22bb2687 Invoke + 42527
                  14  ServiceManager-Launcher.dylib 0x22bb2884 Invoke + 43036
                  15  ServiceManager-Launcher.dylib 0x22ba4826 Login + 1654
                  16  ServiceManager-Launcher.dylib 0x22ba5c71 Login + 6849
                  17  ServiceManager-Launcher.dylib 0x22bb2df3 Invoke + 44427
                  18  ServiceManager-Launcher.dylib 0x22bb5341 Invoke + 53977
                  19  libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  20  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 6:  Java: Exception Handler Thread
                  0   libSystem.B.dylib             0x937e12fa mach_msg_trap + 10
                  1   libSystem.B.dylib             0x937e1a67 mach_msg + 68
                  2   libSystem.B.dylib             0x9384d048 mach_msg_server + 520
                  3   libclient.dylib               0x2d3dce25 JNI_CreateJavaVM_Impl + 61045
                  4   libclient.dylib               0x2d3dcdca JNI_CreateJavaVM_Impl + 60954
                  5   libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  Thread 7:  Java: Gang worker#0 (Parallel GC Threads)
                  2   libclient.dylib               0x2d3dbf23 JNI_CreateJavaVM_Impl + 57203
                  3   libclient.dylib               0x2d3dbdab JNI_CreateJavaVM_Impl + 56827
                  4   libclient.dylib               0x2d3db928 JNI_CreateJavaVM_Impl + 55672
                  5   libclient.dylib               0x2d3db588 JNI_CreateJavaVM_Impl + 54744
                  6   libclient.dylib               0x2d3f1931 jio_vsnprintf + 321
                  7   libclient.dylib               0x2d3f186a jio_vsnprintf + 122
                  8   libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  Thread 8:  Java: Gang worker#1 (Parallel GC Threads)
                  Thread 9:  Java: Concurrent Mark-Sweep GC Thread
                  2   libclient.dylib               0x2d3dc037 JNI_CreateJavaVM_Impl + 57479
                  3   libclient.dylib               0x2d3f8bb0 jio_vsnprintf + 29632
                  4   libclient.dylib               0x2d3db9b7 JNI_CreateJavaVM_Impl + 55815
                  6   libclient.dylib               0x2d4b5b8c JVM_Available + 29852
                  7   libclient.dylib               0x2d3f8992 jio_vsnprintf + 29090
                  Thread 10:  Java: VM Thread
                  0   libclient.dylib               0x2d4d7d1c JVM_EnableCompiler + 13212
                  1   libclient.dylib               0x2d4d7ced JVM_EnableCompiler + 13165
                  2   libclient.dylib               0x2d4a787b JVM_Write + 16859
                  3   libclient.dylib               0x2d4a67e7 JVM_Write + 12615
                  4   libclient.dylib               0x2d471126 JVM_Lseek + 143222
                  5   libclient.dylib               0x2d470c8a JVM_Lseek + 142042
                  6   libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  7   libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  8   libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 11:  Java: Reference Handler
                  4   libclient.dylib               0x2d485c95 JVM_MonitorWait + 5461
                  5   libclient.dylib               0x2d484bfe JVM_MonitorWait + 1214
                  6   libclient.dylib               0x2d48487a JVM_MonitorWait + 314
                  7   ???                           0x3b80b839 0 + 998291513
                  8   ???                           0x3b803db1 0 + 998260145
                  9   ???                           0x3b803db1 0 + 998260145
                  10  ???                           0x3b8012d3 0 + 998249171
                  11  libclient.dylib               0x2d4727d0 JVM_Lseek + 149024
                  12  libclient.dylib               0x2d472576 JVM_Lseek + 148422
                  13  libclient.dylib               0x2d48411b JVM_InternString + 2123
                  14  libclient.dylib               0x2d483f8a JVM_InternString + 1722
                  15  libclient.dylib               0x2d483d74 JVM_InternString + 1188
                  16  libclient.dylib               0x2d48380f JVM_StartThread + 2175
                  17  libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  18  libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  19  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 12:  Java: Finalizer
                  4   libclient.dylib               0x2d3da9a2 JNI_CreateJavaVM_Impl + 51698
                  5   libclient.dylib               0x2d3da8ba JNI_CreateJavaVM_Impl + 51466
                  6   libclient.dylib               0x2d4dd564 JVM_MonitorNotify + 1588
                  7   libclient.dylib               0x2d3db45f JNI_CreateJavaVM_Impl + 54447
                  8   libclient.dylib               0x2d4d746f JVM_EnableCompiler + 10991
                  9   libclient.dylib               0x2d462ff8 JVM_Lseek + 85576
                  10  libclient.dylib               0x2d462d84 JVM_Lseek + 84948
                  11  libclient.dylib               0x2d4a898f JVM_Write + 21231
                  12  ???                           0x3b812831 0 + 998320177
                  13  ???                           0x3b803db1 0 + 998260145
                  14  ???                           0x3b803db1 0 + 998260145
                  15  ???                           0x3b8012d3 0 + 998249171
                  16  libclient.dylib               0x2d4727d0 JVM_Lseek + 149024
                  17  libclient.dylib               0x2d472576 JVM_Lseek + 148422
                  18  libclient.dylib               0x2d48411b JVM_InternString + 2123
                  19  libclient.dylib               0x2d483f8a JVM_InternString + 1722
                  20  libclient.dylib               0x2d483d74 JVM_InternString + 1188
                  21  libclient.dylib               0x2d48380f JVM_StartThread + 2175
                  22  libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  23  libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  24  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 13:  Java: Surrogate Locker Thread (CMS)
                  5   libclient.dylib               0x2d3db4a9 JNI_CreateJavaVM_Impl + 54521
                  6   libclient.dylib               0x2d49b097 JVM_IsPrimitiveClass + 7639
                  7   libclient.dylib               0x2d49ac11 JVM_IsPrimitiveClass + 6481
                  8   libclient.dylib               0x2d483d74 JVM_InternString + 1188
                  9   libclient.dylib               0x2d48380f JVM_StartThread + 2175
                  10  libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  11  libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  12  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 14:  Java: Signal Dispatcher
                  0   libSystem.B.dylib             0x937e1336 semaphore_wait_trap + 10
                  1   libclient.dylib               0x2d49bb5e JVM_IsPrimitiveClass + 10398
                  2   libclient.dylib               0x2d49b92e JVM_IsPrimitiveClass + 9838
                  3   libclient.dylib               0x2d483d74 JVM_InternString + 1188
                  4   libclient.dylib               0x2d48380f JVM_StartThread + 2175
                  Thread 15:  Java: CompilerThread0
                  7   libclient.dylib               0x2d3db541 JNI_CreateJavaVM_Impl + 54673
                  8   libclient.dylib               0x2d49cec2 JVM_IsPrimitiveClass + 15362
                  9   libclient.dylib               0x2d49cc9b JVM_IsPrimitiveClass + 14811
                  10  libclient.dylib               0x2d483d74 JVM_InternString + 1188
                  11  libclient.dylib               0x2d48380f JVM_StartThread + 2175
                  12  libclient.dylib               0x2d3db33b JNI_CreateJavaVM_Impl + 54155
                  13  libSystem.B.dylib             0x9380ea19 _pthread_start + 345
                  14  libSystem.B.dylib             0x9380e89e thread_start + 34
                  Thread 16:  Java: Low Memory Detector
                  6   libclient.dylib               0x2d4a0e32 JVM_IsPrimitiveClass + 3160
