15 Replies Latest reply: Jun 5, 2011 8:40 AM by kglad RSS
    FLV fullscreen problem
    Petteri_Paananen Community Member
      Hi again...=)
      I have a problem....again. Maybe someone can help me out with this.
      Little background:
      I have a main.swf inside html-wrapper. I load some external SWFs into it. Sometimes there is a FLV-video included into a SWF, sometimes not. Those external SWFs comes actually from an automated process, so I don´t have acces to any source codes of them, and I have no clue about instance names of any objects etc...
      Problem:
      Theres a fullscreen button in main.swf. It works perfectly if I use it with external SWF without FLV. But if I try to use it with external SWF with FLV video takes over the screen and all the other graphics etc. disappears.
      I´m looking for a solution to disable that fullscreen for FLV, but I still want my main.swf to go fullscreen... I know that I could use myFLVplayer.fullScreenTakeOver = false if I just knew the instance name of that FLV-player... but I don´t. And I actually doubt that it keeps changin all the time in a process that creates those SWFs, so there´s not much use to know how it is named in one SWF, name is probably totally different in another...
        • 1. Re: FLV fullscreen problem
          kglad CommunityMVP
          pass the content of your loader (after loading is complete and cast as a movieclip) to the below function:
          function flvTakeOverDisableF(mc:MovieClip){
              for(var i:uint=0;i<mc.numChildren;i++){
                  if(mc.getChildAt(i) is FLVPlayback){
                      FLVPlayback(mc.getChildAt(i)).fullScreenTakeOver = false;
                      break;
                  } else if(mc.getChildAt(i) is MovieClip){
                      flvTakeOverDisableF(MovieClip(mc.getChildAt(i)));
          • 2. Re: FLV fullscreen problem
            Thanks, that look promising...
            I have a function where I load my external SWF in. I put a listener inside that function:
            loader.contentLoaderInfo.addEventListener(Event.COMPLETE, flvTakeOverDisableF);
            Then I cast loaded SWF as a MovieClip inside the function you gave:
                    var mc = MovieClip(loader.content);  //casting loaded content as MovieClip mc
                        break;
            I still do something wrong, I get warning:
            TypeError: Error #1034: Type Coercion failed: cannot convert flash.events::Event@3d146a01 to flash.display.MovieClip.
            • 3. Re: FLV fullscreen problem
              kglad CommunityMVP
              no, don't edit the code i suggested.  use:
              function whatever(){
              //your loader code
              loader.contentLoaderInfo.addEventListener(Event.COMPLETE,loadCompleteF );
              function loadCompleteF(e:Event){
              flvTakeOverDisableF(MovieClip(loader.content));
                          break;
              • 4. Re: FLV fullscreen problem
                Ok, thanks...
                I did that and now I get warning:
                ReferenceError: Error #1065: Variable FLVPlayback is not defined.
                at sourceCS3_fla::MainTimeline/flvTakeOverDisableF()
                at sourceCS3_fla::MainTimeline/magLoaded()
                • 5. Re: FLV fullscreen problem
                  kglad CommunityMVP
                  are you using an flvplayback component?
                  • 6. Re: FLV fullscreen problem
                    I suppose there has been used FLVPlayback component, but actually I can´t be sure, it looks like one but I only see SWF, not any source.... I must try to ask that.
                    • 7. Re: FLV fullscreen problem
                      Have not heard a word from authors of that SWF file... but I open SWF into a decompiler and got lots of code... I picked up following function that was inside SWF:
                           public function get fullScreenTakeOver():Boolean
                                  return flvplayback_internal::uiMgr.fullScreenTakeOver;
                      Could I call that some way from my loading swf? And disable fullscreen of videoplayer that way?
                      • 8. Re: FLV fullscreen problem
                        kglad CommunityMVP
                        addt an flvplayback component to your loading swf's library.  retest using the code i suggested.  if that fails, delay the execution of the function i supplied for about 500ms after loading is complete and retest.
                        • 9. Re: FLV fullscreen problem
                          ok,thanks... I tried that. Without delay it didn´t work... what do you think. can I just use setTimeout like this:
                          setTimeout(flvTakeOverDisableF(MovieClip(loader.content)),500);
                          • 10. Re: FLV fullscreen problem
                            kglad CommunityMVP
                            no, use:
                            setTimeout(call_flvTakeOverDisableF,500);
                            function call_flvTakeOverDisableF(){
                            • 11. Re: FLV fullscreen problem
                              If I keep FLVPlayback component just in Library, it throws me:
                                  at sourceCS3_fla::MainTimeline/call_flvTakeOverDisableF()
                                  at Function/http://adobe.com/AS3/2006/builtin::apply()
                                  at SetIntervalTimer/onTimer()
                                  at flash.utils::Timer/_timerDispatch()
                                  at flash.utils::Timer/tick()
                              If I drag it to stage, it doesn´t give any warnings but it behaves strangely. If I open it to browser and push fullscreen button, it opens that empty FLVPlayback Component to fullscreen:
                              • 12. Re: FLV fullscreen problem
                                Never mind last one... I just named that extra FLVPlayback and used another fullScreenTakeOver = false; to it... now it works like a charm... million thanks to you (again)....
                                • 13. Re: FLV fullscreen problem
                                  kglad CommunityMVP
                                  you're welcome.
                                  • 14. Re: FLV fullscreen problem
                                    Ghost Of Death
                                    Whenever I search for a probelm and find a solution, I find that you are the one who posted that solution! Thanks for your great help!
                                    • 15. Re: FLV fullscreen problem
                                      kglad CommunityMVP
                                      you're welcome, too!
                                      (believe it not, it's not unusual for me to search for the solution to a problem only to find that i'd solved it before.)
