1. Re: Files Missing: what have I done?
Tai Lao May 12, 2010 5:16 PM (in response to Opus 111)Yes, the upgrade is a FULL INSTALLER.
The problem being reported is that the CS5 installer often messes up the permissions in various support folders so the needed files can't be written.
Uninstalling and re-installing may help. Use the Adobe uninstaller, don't just trash things.
The installer is written by a different team, and it has always been an embarrassment to Adobe engineers who have no input into it.
2. Re: Files Missing: what have I done?
Jeremy AB May 12, 2010 10:53 PM (in response to Opus 111)Opus 111 wrote:
"One or more files in the Adobe Application Support folder, necessary for running Photoshop, are missing. Please run the Photoshop installer and re-install Photoshop."
I got this or a very similar error a day after installing CS5. A re-install of just Photoshop and I haven't had the problem since. I also repaired permissions just to be on the safe side.
3. Re: Files Missing: what have I done?
sara_wildfield Sep 24, 2010 12:45 PM (in response to Jeremy AB)I too had the same error message as mentioned by OPUS 111, though I had uninstalled cs3, after having installed cs5, and then got the error message. Anyhow, I did an uninstall / reinstall of CS5 Photoshop and the error message went way. I did not repair permissions for this issue to be fixed.
4. Re: Files Missing: what have I done?
Niusha10000 Nov 7, 2010 7:30 AM (in response to Opus 111)I have the same problem.
I AM quite tech savy, and I must say, having not used Adobe products before, there is MUCH to be improved on the ease of installation side. Very confusing. I bought CS4 with a free upgrade to CS5. Upgrading still kept the CS4 files on my computer. I used the Adobe uninstall application to remove CS4, but now I get this error when running Photoshop for CS5.
I can see why Apple doesn't like Adobe products, like Flash.
5. Re: Files Missing: what have I done?
Tai Lao Nov 7, 2010 9:23 AM (in response to Niusha10000)Yes, the installer team is evidently made up of a bunch of incompetent, obviously Macromedia-oriented fools. The engineering teams for each of the point applications have no input into the installers and they probably would like to wring the necks of the individual members of the installer teams. A Photoshop Principal Product manager has publicly referred to the installer as "a huge embarrassment to all of us."
Niusha10000 wrote:
…bought CS4 with a free upgrade to CS5. Upgrading still kept the CS4 files on my computer…However, installing an upgrade has NEVER overwritten the previous version, nor should it ever do so. I have all versions of Photoshop from 7.0.1 through 11.0.2 installed on my machine and they coexist very nicely. On the Mac we can even run more than one version simultaneously, just by launching the older version(s) first.
The problem is that the Uninstaller is also messed up, and when users run it, it removes components necessary to all versions, or more than one version.
Therefore, if you do not plan to keep previous versions installed on your machine, you should uninstall older versions BEFORE installing the new one.
____________
Wo Tai Lao Le
我太老了
6. Re: Files Missing: what have I done?
Jeffrey Tranberry Nov 7, 2010 1:33 PM (in response to Opus 111)Have you updated to Photoshop to 12.0.1? It should correct any permissions errors.
7. Re: Files Missing: what have I done?
Wade_Zimmerman Nov 7, 2010 2:30 PM (in response to Niusha10000)I have often reported problems to
Adobe and they have returned to me on almost all occasions to tell me that
I was mistaken about the problem stating it did not exist
sending the complaint back three times gets the same result but sending it back the fourth time usually gets the same response;"oh, yes we see it now !"
As far as the installer for the master collection and point products it has not work this way the response has been we see it the very first time and th4e same response the second, third fourth and tenth time the only difference here is that before they actually fixed it or fixed it by lkistening to some suggestion as to how it might be made different and where to look for the problem no suggestions are even looked at or considered.
Before thyey were able to determined no matter how wrong you were about fixing the progblem at least where to look for a solution. Fort instrance if you had told them the problem is in the way it writes permissions and tries to exclude a hacker they would ignore it. That might be wrong but at least it points to an area where the problem is manifesting itself.
I don't bother reporting or making suggestion as far as installation goes anymore.
8. Re: Files Missing: what have I done?
Happy Camper Jan 23, 2011 1:10 PM (in response to Opus 111)I am at a job where I have to run Photoshop professionally away from home and away from my installation CDs... I just installed CS5, checked it to make sure it worked and then uninstalled CS4. Now I am getting this same error message and when I output a JPEG file it looks bitmapped despite being 150 dpi and not enlarged in Keynote (it's final desitnation). Is there any way around this without the CDs and re-installing?
9. Re: Files Missing: what have I done?
Jeffrey Tranberry Jan 23, 2011 1:47 PM (in response to Happy Camper)Your best bet would be to grab the FREE trial download from Adobe.com to install and get the missing files back.
10. Re: Files Missing: what have I done?
rschletty Jan 24, 2011 9:37 AM (in response to Jeffrey Tranberry)Adobe Unit Types.osax is missing from Library > ScriptingAdditions. Either retrieve it from a Previous Systems folder or snatch it from another machine running Photoshop CS 3, 4 or 5.
See this thread: http://kb2.adobe.com/cps/407/kb407726.html
