For some reason the FlexPMD is throwing error when I open FlexPMD Outline.
My environment:
Windows 7 64 bit
Flex Builder 3.0.2 Standalone
FlexPMD 1.0.1
The error is:
Error creating the view.
org.eclipse.ui.IMemento.getBoolean(Ljava/lang/String;)Ljava/lang/Boolean;
When I click OK, it shows the Outline Window but it displays Error creating the view. Here are the full details:
java.lang.NoSuchMethodError: org.eclipse.ui.IMemento.getBoolean(Ljava/lang/String;)Ljava/lang/Boolean;
at com.adobe.ac.pmd.eclipse.flexpmd.view.OutlineView.restoreState(OutlineView.java:235)
at com.adobe.ac.pmd.eclipse.flexpmd.view.OutlineView.createPartControl(OutlineView.java:187)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:370)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:227)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:299)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:531)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:179)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:400)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:668)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:564)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:270)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:931)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2515)
at org.eclipse.ui.internal.WorkbenchWindow$23.run(WorkbenchWindow.java:2837)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2818)
at org.eclipse.ui.internal.WorkbenchWindow$17.runWithException(WorkbenchWindow.java:2135)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3296)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:801)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1342)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java:112)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
how did you resolve it ?
I have upgraded to Flash Builder since but not configured FlexPMD yet..
Check the preferences for FlexPMD It should be like this... Specify FlexPMD command line installation with latest jar file (flex-pmd-command-line-1.1.jar) and FlexCPD command line installation with latest jar file (flex-pmd-cpd-command-line-1.1.jar). I made mistake in specifying it as it looks same from last part... It solved the problem
But one more started as in the PMD view blank screen was coming ...that means FlexPMD failed working...which was solved by removing white space in workspace and project name too....http://bugs.adobe.com/jira/browse/FLEXPMD-127
