Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Customized Workspace directory in ES2
Avatar
Level 2
Hello,
This is a dummy question,,
In which directory of LiveCycle ES2 should I save my customized workspace ear file?
In LiveCycle 8.2 was the C:\Adobe\LiveCycle8.2\jboss\server\all\deploy
Thanks for any help!
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
On a turnkey install, it is C:\Adobe\Adobe LiveCycle ES2\jboss\server\lc_turnkey\deploy.
Hope that helps!
Avatar
Correct answer by
Hope that helps!
Avatar
Level 2
GilbertYu,
Worked just fine!
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
