Show 5 replies
1. Re: Premiere Pro, After Effects CS5 & the shared memory pool
Harm Millaard May 13, 2010 1:13 AM (in response to jabloomf1230)That is by design.
2. Re: Premiere Pro, After Effects CS5 & the shared memory pool
dradeke May 13, 2010 2:48 AM (in response to Harm Millaard)You can go into the Memory preference in Premiere Pro and change that amount. So in your example, you could change it to 2GB instead of 3GB when you have 12.
dennis
3. Re: Premiere Pro, After Effects CS5 & the shared memory pool
Harm Millaard May 13, 2010 3:33 AM (in response to dradeke)Dennis,
I have not found a way to lower the default 3 GB on a 12 GB system to anything less, you can reserve more to the detriment of Adobe.
4. Re: Premiere Pro, After Effects CS5 & the shared memory pool
jabloomf1230 May 13, 2010 8:40 PM (in response to Harm Millaard)Harm,
So far you're saving me money on 4GBs of new RAM.
J
5. Re: Premiere Pro, After Effects CS5 & the shared memory pool
jabloomf1230 May 13, 2010 8:46 PM (in response to dradeke)Dennis,
I noticed that there is a file memorybalancercs5.xml that seems to be used by the various CS5 programs to share the memory pool. I'm not about to play with it, but is that what controls the maximum CS5 usage? Or is it just a common location for all the 64 bit components to keep track of the RAM settings?
Jay
