Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
If condiction in forms
Avatar
Level 2
Hi to all the community. I'm really a beginner, and I'd like to ask you "how to do".
I'm usign LC to realize a form to pick infos coming form different areas of the company.
What I'd like to do is to condiction the appearance of a piece of the form just in case the filler selects an answer. I try to explain better:
in a multiple chose box, if the filler selects the answer 1, it must appear a set of questions; if he selects the answer 2, it must appear an other set of questions.
I've red about subforms, but I think it's not exectly what I need.
Is there anywhere a guide (a simple guide) explaining the basis to do this?
Thanks in advance!
Avatar
Former Community Member
The easiest way to do this is to use the presence property to hide/show the parts of the form you want to control. I woudl wrap all of the questions that need to appear together in a subform. That way you can hide/show the subform and all of the contents of that subform will aquire the parent setting. If you do not then you will have to hide/show each individual object.
Now you can test the value of your choice box to see what the user selected then change the presence accordingly....somethig like this:
if (ChoiceListName == 1){
     subformQuestionsA.presence = "visible";
     subformQuestionsB.presence = "hidden";
} else {
     subformQuestionsB.presence = "visible";
     subformQuestionsA.presence ="hidden";
Paul
Avatar
Level 2
Hi Paul, thanks for your reply.
It seems this is the way to do what I need.
I've an other question for you. It's more "operative" than the previous.
Now is clear I can create a subform and let it appear when I like (VIZ when the filler gives certain answers). It's not really clear how I can directly connect the answer to the appearance of the subform. I've seen the code and I think I can undestand it, but can't realize where and when to write it down.
If it's not a problem for you, could you give me precise instruction of how to proceed?
Thanks again.
Luca
Avatar
It woudl be easier if you shared the form, then I coudl do the 1st question to show you and you could do the rest. If you send the file and and explanation to LiveCycle8@gmail.com I will have a look when I can.
paul
Avatar
Level 2
This will help.
Good, I'm sending.
Where to find a complete but SIMPLE guide for Livecycle beginners??
Luca
