3 Replies Latest reply: May 17, 2010 3:29 AM by John Joslin RSS
    Picture frame
    on5lb Community Member
      Hello,
      Stupid, don't you think ?
      I don't remember how to proceed, using Ps CS4, to create a frame around pictures.
      I should like to be able to design the frame type, color, texture...by myself, possible ?
      If the answer is YES, (hope so !), how to proceed ?
      Thanks in advance for your help,
      Jean
        • 1. Re: Picture frame
          John Joslin Community Member
          You could make a start by loading the set of frames in the Actions panel and see how they are created.
          That should give you some ideas.
          Just click the drop-down in the panel and choose the Frames set.
          • 2. Re: Picture frame
            Hi John,
            I'l luky you're still available !
            Can you please give some more details, wher to find this panel, because i'm using a french version, and don't find the Actions panel (should be the same, actually).
            We are talking about Photoshop CS4 Extended, right ?
            Kind regards,
            Jean
            • 3. Re: Picture frame
              In the menu, go to Window > Actions.
              In the Actions panel which appears, click the drop-down men in the top right corner and choose Frames.
              If you run an action you can examine the steps in the History Panel.
