Hi guys,
I have made a form which when sent to a Mysql server adds a table to a database.
Here is the code that I use in Flash Builder:
<mx:HTTPService id="srv" url="http://mysite.com/addTeam.php" method="POST">
<mx:request>
<teamName>{teamName.text}</teamName>
<city>{city.text}</city>
</mx:request>
</mx:HTTPService>
<mx:Form x="25" y="10">
<mx:FormHeading label="Add a team"/>
<mx:FormItem label="Team name">
<s:TextInput id="teamName"/>
</mx:FormItem>
<mx:FormItem label="City">
<s:TextInput id="city"/>
</mx:FormItem>
<mx:FormItem>
<s:Button label="Add" click="srv.send()"/>
</mx:FormItem>
And here is my addTeam.php file:
<?php
$teamName = $_POST['teamName'];
$city = $_POST['city'];
$addteam = $teamName ." ". $city;
$connection = mysqli_connect("host", "username", "password", "db") or die(mysqli_connect_error());
mysqli_query($connection, "SET CHARACTER SET utf8"); //the added table will be in bulgarian language
$sql = "CREATE TABLE `$addteam`
FirstName varchar(20),
SurName varchar(20),
LastName varchar(20),
position varchar(20),
price int
mysqli_query($connection, $sql) or die ("Query failed: " . mysqli_error($connection));
My question is: How can I return some text to Flash Builder if the query was successful or failed (like "echo") so that the user (admin in this case) knows what is going on and not just clicking the add button and having to go to phpmyadmin to see if the table has been created or not?
You have this declared
<mx:HTTPService
just add
result="yourResultHandler()"/>
then create the function that would handle the result.
<mx:HTTPService
id="srv" url="http://mysite.com/addTeam.php" method="POST" result="yourResultHandler(event)">
After you do a mysql_query(
Mysql returns a rows affected, so just do PHP logic on that rows affected.
so if you're rows affected is 1, then it's success
return "Success"
If your rows affected is 0 then it didnt' get added to MySQL
return "Fail"
Well , the point is that I don't know how to use the return statement... Or at least how to include it in the mxml code.
Sorry I don't use MXML. Here's how you would do it in actionscript, there's probably a similar option in mxml.
private function submitResultHandler(event:ResultEvent):void
if(event.result == "Success")
else
Could you give me a full example. As I told you - I'm quite new, especially to ActionScript...
<mx:HTTPService
just add
<mx:HTTPService
I don't know why but this doesn't work... Can you copy the whole code that I should put both in my php and mxml files because I got rather confused. I'm trying to make an alert pop up but no mather if the table exists or not it shows 1 and the same result...
EDIT:
Actually I managed to fix it...
I replaced the return statement with echo and just made the text of the alert to be event.result and it showed as it should. Thanks for your help!
Appreciate it...
