How To View or Run .CLA files?
Avatar
Level 3
I've downloaded sample applications from Adobe LC web.
I've Unzipped the file, but then I don't know how to open it.
The file extension is .CLA
Can you help?
Avatar
Level 2
What is the sample application you downloaded?
Are you referring to *.LCA file? or the file you downloaded is not meant to be unzip and use.
The *.CLA file might be associated with Java Class files or a shortcut for *.CLASS file extension. (Something i retrieved from the internet search)
Avatar
Level 3
I've doanloaded
this file. Adobe-Samples-Application-EndToEndMortgageApplication.cla
Avatar
Level 10
Step1: Rename your file into .LCA
Step 2: Goto Adminui-> Services -> Applications & Services-> Archive Management-> Import Archive.
Step 3: Locate your file and click import.
Now you can see the updated processes and forms in your workbench.
Nith
DISCLAIMER:
"This communication is intended only for the named recipient and others authorized to receive it.
It contains confidential or legally privileged information. If you are not the intended recipient, please notify us immediately, and note that any disclosure, copying, distribution or action you may take in reliance on this communication is strictly prohibited and may be unlawful. Unless indicated otherwise, this communication is not intended, nor should it be taken to create any legal and/or contractual relation or otherwise. Ministry of Finance (MOF) is neither liable for the proper and complete transmission of the communication, nor for any delay in its receipt.
Whilst MOF undertakes all reasonable efforts to screen outgoing e-mails for viruses, it cannot be held liable for any viruses transmitted by this e-mail."
Avatar
Level 3
Hi Ninth
The file extention is LCA and not CLA.
Where is adminui located? is it an application?
Avatar
Level 2
http://<hostname>:<port>/adminui
It is an administrative web ui for adminstrator to manage LiveCycle ES services and processes.
The file you download is a LiveCycle Archive file that contain Livecycle Process, Resources and other information, which required to use AdminUI to import into the Livecycle Server.
There should be more information about the LCA you downloaded.
Avatar
Level 7
yes we can unzip .lca file. just rename the extn as .zip and unzip it by right clicking on zip file
Regards
Sunil
