1. Re: Saving project as JPEG loses adjustment layers
shoot me now-d3u3se May 19, 2010 11:15 AM (in response to Webshark2000)jpeg is not a format that recognizes or preserves layers. So, you need to save as a psd if you want layers as well as a smaller file size (compared to tiff).
2. Re: Saving project as JPEG loses adjustment layers
Webshark2000 May 19, 2010 11:25 AM (in response to shoot me now-d3u3se)shoot me now wrote:
My intention isn't to save the file with layers. The problem I'm having is that when it is saved as a JPEG file, the adjustments to the contrast, saturation, etc that should be applied to the photo from the adjustment layers isn't there.
3. Re: Saving project as JPEG loses adjustment layers
shoot me now-d3u3se May 19, 2010 11:30 AM (in response to Webshark2000)Sorry, I misunderstood. What version of ps are you using?
4. Re: Saving project as JPEG loses adjustment layers
Zeno Bokor May 19, 2010 11:31 AM (in response to Webshark2000)Nothing you can do about it, the JPEG file format doesn't support layers.
5. Re: Saving project as JPEG loses adjustment layers
Gyno-jiz May 19, 2010 11:32 AM (in response to Webshark2000)What happens when you flatten the image in PS? Does it look good, or the way the JPG does?
6. Re: Saving project as JPEG loses adjustment layers
Webshark2000 May 19, 2010 11:33 AM (in response to Zeno Bokor)Zeno Bokor wrote:
Again, not trying to save it as a JPEG with layers. I know that JPEGs don't support layers.
I'm using CS3.
7. Re: Saving project as JPEG loses adjustment layers
Yes, it looks fine in PS. It's only after it's been saved as a JPEG that it seems to lose the adjustments.
8. Re: Saving project as JPEG loses adjustment layers
shoot me now-d3u3se May 19, 2010 11:38 AM (in response to Webshark2000)Make a radical adjustment like adding a Hue/Saturation adj layer and pull the saturation all the way to -100 (or whatever).
Save as a jpeg and see if the adj. holds (should be a grayscale).
Also, are you saving using Save for Web or the Save As? Whichever it is, try the other.
Just shooting in the dark here...
9. Re: Saving project as JPEG loses adjustment layers
Zeno Bokor May 19, 2010 11:41 AM (in response to Webshark2000)Photoshop acting weird? try resetting the preferences: http://forums.adobe.com/thread/375776?tstart=0
10. Re: Saving project as JPEG loses adjustment layers
Webshark2000 May 19, 2010 5:35 PM (in response to Zeno Bokor)Trashing the prefs fixed the problem. Thanks for the help guys!
