I have the same problem with the same build of RoboHelp.
Recently, I had a problem closing my project file.
The recommended solution, from this forum, was to delete the CPD file.
This resolved the problem closing my project file and being able to compile a new CHM file.
But, around the same time I noticed that all my Templates were no longer showing up in the Templates folder in the Project window.
The files were still on the hard drive.
So, I started importing them to my project.
Most of the Templates imported just fine.
But, some of them did not import. No error message during the import process, they just didn't import.
I have renamed the HTT files in Explorer (or whatever you want to call "computer" in Win 7).
These new Templates import just fine.
But, I have hundreds of topics using these missing Templates.
If I then try to rename the new Template to the original name in the Project window I am told that a folder or file of that name already exists.
When I create a new topic and want to assign one of the missing Templates it does not show up in the list of available Templates.
Any suggestions as to how to "purge" some listing of the problem Templates?
One, not so good solution:
Rename the missing Templates in Explorer.
Import the new Templates.
Use the new Templates when creating new topics.
But, what if I need to update a Template?
If I cannot edit a missing Template, I don't see how I can update it.
Please don't suggest that I spend a couple of days opening up each topic and selecting a new Template.
Dave
Hi Dave
I know you said not to suggest assigning a new template to existing topics, but that's probably exactly what you will find that you need to do. However, having said that, it's probably not nearly as painful as you are imagining.
If you open the Topic List pod you are able to select one, two, twenty or as many topics as you like. You are then free to right-click that selection and examine the properties. Then you may associate the desired template easily. Might take you all of 30 whole seconds to do this with thousands of topics.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi Rick,
That was too easy and I would not have thought of it.
But, when I selected all topics in a given folder it shows "multiple
templates" as the choice.
I guess this means that I may have assigned a the wrong template to one or
more of my topics in this folder.
Thank you,
Dave
