I uninstalled coldfusion builder from flash builder and then when re-install I get a message:
installer has detected one or more adobe coldfusion builder plugins ....etc
How do I fix this?
Please make sure that you clean-up the plugins directory under ../Program Files/Adobe ColdFusion Builder Plugins/
If there are any jars remove them and try to install. You should be able to install now.
awesome mate,
As a caution to save your time please follow the following release note:
82284 - If you install ColdFusion Builder as a plug-in to Flash Builder and decide to uninstall ColdFusion Builder, make sure ColdFusion perspective is not active in Flash Builder. Failing which, some features may not work after restarting Flash Builder or ColdFusion Builder's perspective will not come up if installed again.
tricky buisiness building on that mamoth eclipse
I did the wrong thing here and I can't ever get coldfusion to reappear after unstalling into FB
I just can't get CFB to work when I reinstall it into FB , looks like a total reinstall with both FB and then CFB into it
Did you try to start FB with the -clean option after the CFB uninstall (or before the re-install)?
Yes, no luck
