Does anyone know when there will be an update to the final release, which I think was a final candidate that shouldn't have passed the test? I don't know if it's just me, or is everyone else having problems with weird editing bugs... like editing long lines of code, which is completely broken, and the code assist window barely working... just enough to be annoying.
Other than that, I like to be able to do line level debugging, but that's terribly slow and it doesn't save your expansion state of variables between steps.
It would be great to get some editor fixes ASAP!
yeah
It is available now:
Invoke Help --> Adobe ColdFusion Builder Updates.... to get the updates.
More info at:
super
no updates found
Can you please tell me your CF Builder's build number (Help->About Adobe ColdFusion Builder..)
ends in 911
By any chance following issue is applucable to you?
"If you have multiple ColdFusion Builder installations, only the latest installation can be updated"
nope
Can you let me know on what machine you are trying to update Builder and whether this is a standalone installation or a plugin installation.
Sagar.
XP plugin
Can you start eclipse with a clean option and try to invoke Adobe ColdFusion Builder Updates from Help menu. Please make sure you are running CFB with Administrator privileges.
Sagar.
done that no effect, no worries cf builder is relatively ok for me.
I'm able to update the build successfully. Can you try uninstalling the final build and reinstall the same and then try to invoke Adobe ColdFusion Builder Updates...
its not worth the hastle sorry
is there a manual update site?
No. I would still recommend you to uninstall and reinstall CFB.
Sagar.
maybe i should download the cf builder from the web instead of using the cd?
I uninstalled CFB and then reinstalled it, now FB gives message:
can't restore workbench state and none of the CF options are available.
Sigh.. looks like im gonna have to do a full FB + CFB reinstall again
I think this time im just gonna to a standalone for both Fb and CFB
If you haven't uninstalled/reinstalled yet you might want to try this first. Open FB and click "File > Switch Workspace > Other..." Then either leave the default path or choose your own. Then tick both of the Copy Settings options and hit OK.
That will create a new workspace, and is akin to the glorious Windows 95 reboot fix
I had an issue updating my FB+CFB install last night and that was the fix for me.
