Hey guys, so this is a Flash Builder 4 + Zend PHP question, hoping someone can help.
So I've been building a basic CRUD backend with Zend, using E_Schrade's tutorial as a basis - seems pretty rocking so far, from an ease-of-development standpoint.
Anyway, I've started the Flex project to see if my basic data model is working...I've followed all of the instructions, so far as I can tell, while getting up to speed.
Anyway, picking the service PHP file from the backend project works, it grabs the methods and creates the data object...but, when I try to test the service, I get:
Fatal error: Class 'Model_DbTable_Users' not found in G:\www\FlexProject\public\services\UserService.php on line 7
(line 7 is: $tbl = new Model_DbTable_Users(); )
So clearly I have a pathing/include problem. Trouble is, I'm not sure what the best way to FIX it is. In the tutorials I've watched they don't run into this issue, so I clearly have a misconfiguration. Ooooor do I actually need to put a require statement into UserService, even though that shouldn't be required when running the ACTUAL backend app?
Ugh, confused!
Please help!
I would imagine that require statement would be need to successfully interpret this PHP file since it refers the Model_DbTable_Users class on line 7:
-mayank
Flash Builder Engineering
