Any Gurus in encryption?
Apr 04, 2006 Apr 04, 2006
Any gurus out there?
CFMX 6, Oracle9i
Does anyone know how I can easily search an encrypted column?
I have a whole bunch of sensitive material (text/html) stored as encrypted data but I can't see any easy way of searching that data for a keyword without openeing every record, decrypting the column, then searching it before moving on to the next record.
Is there an easy way to do this if at all?
Thanks for any help
Advanced techniques
545
The whole IDEA of encryption is to make it "difficult" to extract
information out of it without decrypting it.
So - almost by definition - no.
Adam
Apr 06, 2006 Apr 06, 2006
Hi Adam
Thanks for your response
Do you know if there's an easy way of determining if data is encrypted once retrieved from the DB?
Like isNumeric(value) but for encrypted data:
e.g. isEncrypted(value)
Jam
Not really. There are stacks of different encryption schemes, and
obviously the encrypted results all look different from scheme to scheme.
Adam
Mentor ,
How was your data encrypted? I found quite a lot of information regarding Data Encryption Using DBMS_OBFUSCATION_TOOLKIT in Oracle9i Application Developer's Guide - Fundamentals Release 2 (9.2) (Part Number A96590-01) documentation, which can be downloaded from Oracle.
Phil
Apr 07, 2006 Apr 07, 2006
Phil - Data was encrypted using a private key and coldfusion Encrypt(string,key)
Participant ,
May 22, 2006 May 22, 2006
Adam
FYI - It is indeed possible to search an encrypted column from a CF page. I have built a function to do this and it works very well!
Now I will answer all other similar posts (if you need the answer)
Documentation
