I have a Flash File that runs with 12 Frames Per second and I need to integrate this with Adobe Presenter. The Frame Rate for Adobe Presenter is 30 Frames Per Second. Here is where I am facing an issue.
Is there a way to change the frame rate for Adobe Presenter??
Thanks in advance
Nope. Unless you want to get into reconfiguring the viewer.swf and other associated swf files, you're pretty much stuck w/ the 30fps setting.
Rob
Thanks Rob
