2 Replies Latest reply: May 25, 2010 10:09 AM by Gyno-jiz RSS
    Problem rasterizing EPS files...dimensions reduced
    RKSinNC2 Community Member
      I have some Illustrator files (17" x 16") that I need to convert to 1-bit TIFF files at 2400 dpi. Illustrator apparently can't export them at that resolution, so I saved them as EPS and opened them in Photoshop. The file dimensions appeared correct in the dialog box, and I changed the settings to 2400 dpi grayscale. Rasterization seemed to work without problem, but I later discovered that Photoshop had reduced the file dimensions by about 25%...without any warning or error!
      I worked around the problem by creating the correct file size in Photoshop and pasting the Illustrator art into the file.
      Anybody know if this is a limitation in Photoshop, or did it do this because of a lack of RAM, etc.?
      Using CS5 on a MacPro with 10.6.3
