RoboHelp 8 crashing in HTML editor
Guest
May 25, 2010 May 25, 2010
I am making extensive changes to the xhtml such as deleting inline styles, adding and removing tags, and so on. However, RoboHelp keeps crashing while I am using the HTML editor, never while I am in design.
I have tried various things to eliminate the crashes such as dragging the scrollbars slowly (many crashes just after scrolling) and clicking in a line before selecting text to delete (some crashes while selecting text). At this point I am saving after practically every change.
Does anyone have a description of  behaviors to adopt while working in HTMl editor to avoid crashing?
John
628
Sorry John, no idea. I don't think I have seen it reported.
The only issue I have seen with this view is if the font has been changed from Courier at 100% but that just screws the display rather than crashing it.
Use the mouse wheel instead of scroll bars or vice versa?
@petergrainge
Hi there
In addition to what my esteemed colleague offered, I'll also suggest this.
If you find you prefer working in an HTML type of view, you will find RoboHelp HTML is very accommodating. You may configure RoboHelp HTML so that any editor you like is used. Perhaps you prefer Dreamweaver.
Click Tools > Options > Associations and configure the desired editor in the ensuing dialog.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
John is doing this to clean up some code so he needs to switch back and forth from HTML and Design.
@petergrainge
Guest
I was going to work in Visual Studio. I thought that if I just kept Design view open in Robohelp, I could edit the files in Visual Studio and then save them and observe the changes in Design, kind of like working on CSS in Notepad.
Is that not feasible? Or do I need to set it up in RoboHelp as Rick described?
John
You can right click any topic and choose Open With to edit with any tool you like. Try it and see how easy the workflow is, or isn't. I am not saying it won't be OK, just saying to check it out. But you can't edit the code in one and leave it open while look in Design View at the same time.
Create a temporary project and try it. Other editors will not understand some of the code and may write things their way that RH will not understand.
Just proceed with caution and back up first.
Rick will step in if their is an easy way to work with both.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
