2 Replies Latest reply: May 26, 2010 9:28 PM by WakeTabz RSS
    bridge CS4 not rendering images correctly
    WakeTabz Community Member
      i have macbook 10.4.11 with 60 GB free, and 2GB of RAM and when i hit the space bar in bridge to view my photos at full screen the photos do not sharpen. they used to but now they don't, they just remain blurry. i have tried "purge cache" and checking "generate monitor size preiews" and nothing. Anyone have any other advice?
        • 1. Re: bridge CS4 not rendering images correctly
          Omke Oudeman Community Member
          Usually that should do the trick, although it should be the other way round,
          after having set monitor size previews you use the purge cache for folder
          option to make it effective, did you used it in that order?
          Also if the problems keep occurring try a preference reset with restarting
          Bridge with option key and choose refresh preferences. Set prefs again to
          your wishes and try again.
          • 2. Re: bridge CS4 not rendering images correctly
            Thanks it seems to work!.  I reset the preferences like you said. But i think i "purged the cache" wrong as i hit the Purge Cache button, and i found some info saying you should delete the cache file and to not hit the button.
            One of my files of photos is not loading properley as you can't see the thumbnails. I am not really sure what i did? Can i rectify this?
