1. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Harm Millaard May 29, 2010 1:39 PM (in response to Tom Mullica)Adobe Forums: Storage rules for an editing rig. Some...
You can install both versions without problems. They coexist quite happily and do not interfere.
2. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 1:43 PM (in response to Harm Millaard)Thanks a million, Harm. What about the storage questio...any help there!
3. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Bill Hunt May 29, 2010 2:02 PM (in response to Tom Mullica)Tom,
For the allocation of your HDD's, I would strongly recommend that your OS, programs (all versions of PrPro) and probably your Page File be on C:\. With only one more HDD (2 - 3 more would be better), then locate your media, your Project Files (PRPROJ's) and your Scratch Disks set to "Same As Project" on your D:\. Your Export files will go there too. Separate your OS/Programs from your Projects. In a perfect world, you'd have a separate, physical HDD for media, and one for Exports.
When you set up your Projects, create a unique folder (or sub-folder) for each Project. That will make life much easier later on.
For me, I do a "client" folder and each of their Projects is below, with Scratch Disks set to "Same As Project."
Good luck,
Hunt
4. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Harm Millaard May 29, 2010 2:02 PM (in response to Tom Mullica)Click on the link and read the article.
But your USB drive is maybe OK for backups, but not for editing. Get at least 1 but possibly 2 internal 7200 RPM SATA disks.
5. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Bill Hunt May 29, 2010 2:07 PM (in response to Harm Millaard)Duh! I completely missed that D:\ was USB.
I strongly agree with Harm on the additional internal HDD's. USB's are fine for archiving and storing media (Copy those over to the internal, before you Import), but horribly deficient for editing.
Now, if you cannot add physical HDD's (remember, no partitions!), then FW-800's will work, but eSATA's would be even better. I would not waste my time with FW-400's, as they are not THAT much faster than USB's.
Sorry about that, and thank you Harm, for pointing that out.
Hunt
6. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 2:28 PM (in response to Bill Hunt)Bill...
Perfect answer and well understood. I do have 2 USB external drives but use one for backup only...is that OK?
Thanks for your reply.
Tom
7. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 2:30 PM (in response to Bill Hunt)Bill...
The extra HDs are USB EXTERNAL.
tom
8. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Bill Hunt May 29, 2010 2:32 PM (in response to Tom Mullica)Tom,
For backing up, a good USB external should be perfectly fine. Where they fall very short is when one tries to edit to/from them. First, they are horribly slow, and second can suffer from read/write errors, especially the dreaded Delayed Write Failure. This can cost one data. My suspicion is that the computer is trying to transfer more data (in both directions), than the connection can provide, and it becomes a bottleneck, with the OS getting too far ahead of the drive. FW-400's did not seem to suffer from this issue, but were not much faster. FW-800's have served me well for some years, and eSATA's will be nearly as good as having more internal HDD's. Note: you will probably have to look into a controller card for either FW-800's (IEEE-1394b), or for eSATA.
Good luck,
Hunt
9. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 2:40 PM (in response to Harm Millaard)Harm...
Click WHAT link?
tom
11. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 2:56 PM (in response to Harm Millaard)Harm...
Just saw the link...ooops! THANKS
Tom
12. Re: (1) simple 'STORAGE' question (2) TWO VERSIONS INSTALLED
Tom Mullica May 29, 2010 3:23 PM (in response to shooternz)thank you, my friend...
tom
