1 2 Previous Next 56 Replies Latest reply: Oct 15, 2010 12:34 PM by maltar7 RSS
    Photoshop CS5 Install Help Please !!!!!!!!!!!
    maltar7 Community Member
      Exit Code: 6
      -------------------------------------- Summary  --------------------------------------
      - 0 fatal error(s), 52  error(s), 51 warning(s)
      WARNING: OS requirements not met for  {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
      WARNING: Payload cannot be  installed due to dependent operation failure
      ERROR: The following  payload errors were found during install:
      ERROR:  - Adobe CSXS  Infrastructure CS5: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86:  Install failed
      ERROR:   - Adobe Media Player: Install failed
      ERROR:  - Adobe Linguistics CS5  x64: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR:   - Adobe Photoshop CS5 Support: Install failed
      ERROR:  - Adobe Bridge CS5:  Install failed
      ERROR:  - Recommended Common Fonts Installation x64:  Install failed
      ERROR:   - AdobePDFL x64 CS5: Install failed
      ERROR:  -  DeviceCentral_DeviceCentral3LP-en_GB: Install failed
      ERROR:  -  Microsoft_VC80_MFCLOC_x86_x64: Install failed
      ERROR:  - Adobe XMP Panels  CS5: Install failed
      ERROR:  - Photoshop Camera Raw: Install failed
      ERROR:  -  AdobeColorCommonSetCMYK: Install failed
      ERROR:  - Adobe Mini Bridge CS5:  Install failed
      ERROR:  - Microsoft_VC80_CRT_x86_x64: Install failed
      ERROR:   - AdobeColorJA CS5: Install failed
      ERROR:  - Adobe ReviewPanel CS5:  Install failed
      ERROR:  - Photoshop Camera Raw (64 bit): Install  failed
      ERROR:   - Microsoft_VC90_MFC_x86: Install failed
      ERROR:  - Adobe Photoshop CS5  Core_x64: Failed due to Language Pack installation failure
      ERROR:  -  Suite Shared Configuration CS5: Install failed
      ERROR:  - PDF Settings  CS5: Install failed
      ERROR:  - DeviceCentral: Failed due to Language Pack  installation failure
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  -  AdobeColorVideoProfilesCS CS5: Install failed
      ERROR:  -  AdobeColorCommonSetRGB: Install failed
      ERROR:  - Adobe Player for  Embedding x64: Install failed
      ERROR:  - Required Common Fonts Installation  x64: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
      ERROR:   - Adobe CSXS Extensions CS5: Install failed
      ERROR:  -  Microsoft_VC80_ATL_x86_x64: Install failed
      ERROR:  - AdobeOutputModule:  Install failed
      ERROR:   - Microsoft_VC80_CRT_x86: Install failed
      ERROR:  - AdobeCMaps x64 CS5:  Install failed
      ERROR:   - AdobeTypeSupport x64 CS5: Install failed
      ERROR:  -  Microsoft_VC90_MFC_x86_x64: Install failed
      ERROR:  - Adobe Photoshop CS5  International English Language Pack_x64_AdobePhotoshop12-en_GB_x64:  Install failed
      ERROR:   - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
      ERROR:  -  AdobeColorEU CS5: Install failed
      ERROR:  - AdobePDFL CS5: Install failed
      ERROR:   - AdobeCMaps CS5: Install failed
      ERROR:  - AdobeColorNA CS5: Install  failed
      ERROR:   - Microsoft_VC80_MFC_x86_x64: Install failed
      ERROR:  - Adobe SwitchBoard  2.0: Install failed
      ERROR:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR:   - AdobeColorPhotoshop CS5: Install failed
      ERROR:  -  Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR:  - Adobe Extension  Manager CS5: Install failed
      ERROR:  - Adobe ExtendScript Toolkit CS5:  Install failed
      ERROR:   - Adobe AIR: Install failed
      Any  help guys?
      Additional  infro: I am running windows 7 Home Premium x64.
                                   Processor: Pentium(R) Dual-Core CPU T4300 @ 2.10 GHz 2.10 GHz
                                         Installed memory(RAM): 4.00GB
                                        I have run CS5cleanscript and uninstalled  previous versions of photoshop.
                                  I am administrator and have enough space on my hardrive.
                                         Also i can install the msi. files manually.
        • 1. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
          Bill Hunt CommunityMVP
          Well, starting at the top, the first entry is troublesome:
          It would seem that your OS does meet the requirements, but maybe I am missing something.
          Here is a very general CHECKLIST for installing many Adobe programs.
          Good luck,
          Hunt
          • 2. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
            Thank you for your checklist, but i have done everything you said already on th
            e checklist.
            Can you recomed doing something else.
            Becasue this is costing me alot of time, as i need this programe for work.
            • 3. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
              p_c_e Employee Hosts
              Can you post the entire log please. This snippet does not contain the actual reason of failure. The OS Requirement messages are cosmetic.
              • 4. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                This is the entire log p c e , thats all of what a copied and pasted from the installation setup.
                • 5. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                  Harm Millaard CommunityMVP
                  What is your OS on what hardware?
                  • 6. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                    I dont understand "OS on what hardware", my operating sytem is windows 7.
                    Therefor my OS on hardware is windows 7.
                    • 7. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                      John Joslin Community Member
                      He means tell us the following System information:
                      Operating System/version
                      Photoshop version number
                      Amount of RAM installed
                      Hard drive(s) capacity/free space
                      Make and model number of video card
                      • 8. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                        Operating system : Windows 7 Home Premium.
                        Ram: 4.00 GB of Ram
                        Hard drive: 300GB, free Space 250GB
                        Video card: ATI Mobillity Radeon Hd 4500 series.
                        Processor: Pentium (R) Dual-Core CPU T4300 @ 2.10Ghz 2.10GHz
                        • 9. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                          Help please guys? Anyone please?
                          • 10. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                            Could adobe bridge Cs4 be causing the problem
                            • 11. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                              Curt Y Community Member
                              CS4 will not affect it.
                              I did a web search and you are not alone.  Read this thread. Payload
                              • 12. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                The complete log file would be lying in
                                32 Bit
                                <Drive>\program files\common files\Adobe\Installers
                                64 Bit
                                <Drive>\program files (x86)\common files\Adobe\Installers
                                • 13. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                  keenox Community Member
                                  My guess is that you are trying to install the 64bit version on a 32bit version of Windows 7. Go to start, right click on computer and select properties, then post a print screen.
                                  • 14. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                    Here is a print screen of my computer properties Keenox
                                    Message was edited by: maltar7    Here is a print screen of my computer properteis Keenox.
                                    Click the image to view better quality
                                    • 15. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                      weird. see this thread here.
                                      also, in adobe knowledge base: http://kb2.adobe.com/cps/829/cpsid_82942.html
                                      • 16. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                        Thanks for the help, but unfortunately i have come across these posts before and none of the things they say to
                                        try out Dont work for me.
                                        Its really frustrating, any other information or adivice you could give me.
                                        Can anyone recomend any information or help?
                                        • 17. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                          • 18. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                            Hi people how do you start windows 7 into "safe mode".
                                            • 19. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                              dec9 Community Member
                                              Just want to be clear on this thread.
                                              When you install the software you are installing the software in the admin mode? There is a difference being admin on your computer and installing software in the admin mode.
                                              Before you install the software look in Task Manager and ensure nothing Adobe is running. If it is turn it off.
                                              Turn off any anti-virus running in the background. If windows defender is running turn it off.
                                              Keep UAC on.
                                              When you put the disk in the drive don't install it. Choose explore. Look for the .exe file. Might be in the Photoshop folder. Right click on the .exe file and choose run as Admin. This will give Photoshop full security permissions to run on Windows 7.
                                              After install reboot computer.
                                              After reboot go to start, all programs and look for the Photoshop icon. Right click on the icon, choose properties, compatibility, then check run this program as an administrator. Close out and start Photoshop.
                                              If you have a problem with bridge opening photos do the same thing as above by checking run as admin.
                                              Hope this helps.
                                              • 20. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                When you mean admin mode, you mean " right click and run as admin.
                                                Is that what you are refering to.
                                                I have already tried the instructions that you have posted above.
                                                The only thing is it wont install photoshop cs5, the installer gets to about 15% or 10% and says " adobe photoshop cs5" then it stops installing and goes to the log file page.
                                                • 21. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                  on 32 Bit
                                                  on 64 Bit
                                                  Can you please share the same.
                                                  • 22. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                    Heres what i found in <Drive>\program files (x86)\common files\Adobe\Installers
                                                    [    1072] Mon May 31 18:06:32 2010  INFO
                                                    Visit http://www.adobe.com/go/loganalyzer/ for more information
                                                    START - Installer Session
                                                    RIBS version: 3.0.122.0
                                                    Win OS version: 5.1.2.0 64 bit Type: 1
                                                    ::START TIMER:: [Total Timer]
                                                    CHECK: Single instance running
                                                    CHECK : Credentials
                                                    Load Deployment File
                                                    Create Required Folders
                                                    Assuming install mode
                                                    ::START TIMER:: [Bootstrap]
                                                    Perform Bootstrapping ...
                                                    :: END TIMER :: [Bootstrap] took 11884.5 miliseconds (11.8845 seconds) DTR = 20.5309 KBPS (0.0200497 MBPS)
                                                    Looking up install source path
                                                    Sync Media DB ...
                                                    ::START TIMER:: [Sync Media DB]
                                                    Pre check media db sync
                                                    End of Pre check media db sync. Exit code: 0
                                                    :: END TIMER :: [Sync Media DB] took 8310.98 miliseconds (8.31098 seconds) DTR = 13.4761 KBPS (0.0131603 MBPS)
                                                    Ready to initialize session to start with ...
                                                    ::START TIMER:: [CreatePayloadSession]
                                                    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                                                    Updated source path: C:\Users\Administrator\Desktop\Adobe CS5
                                                    Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
                                                    Ignoring original data since install source is local
                                                      Type: 0, Volume Order: 1, Media Name: Photoshop CS5
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
                                                    Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
                                                    Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
                                                    Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
                                                    Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
                                                    Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
                                                    Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
                                                    Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
                                                    Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
                                                    Updating media info for: {15FEDA5F-141C-4127-8D7E-B962D1742728}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Driver\Install.db
                                                    Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
                                                    Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
                                                    Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
                                                    Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
                                                    Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
                                                    Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                                                    Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
                                                    Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
                                                    Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                                                    Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                                                    Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
                                                    Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
                                                    Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\Install.db
                                                    Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
                                                    Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
                                                    Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
                                                    Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
                                                    Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\Install.db
                                                    Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-en_US\Install.db
                                                    Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
                                                    Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
                                                    Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
                                                    Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
                                                    Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
                                                    Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
                                                    Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
                                                    Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
                                                    Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
                                                    Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Core\Install.db
                                                    Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
                                                    Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
                                                    Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-en_GB\Install.db
                                                    Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
                                                    Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
                                                    Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
                                                    Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                                                    Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                                                    Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
                                                    Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
                                                    Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
                                                    Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\Install.db
                                                    Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
                                                    Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
                                                    Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
                                                    Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
                                                    Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
                                                    Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
                                                    Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
                                                    Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
                                                    Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
                                                    Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
                                                    Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
                                                    Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
                                                    Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
                                                    Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
                                                    Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
                                                    Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
                                                    Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
                                                    Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                                                    Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
                                                    Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
                                                      Path: C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
                                                    --------------------  END  - Updating Media Sources -  END  --------------------
                                                    Supported RIBS version range: [0.0.66.0,3.0.122.0]
                                                    ----------------- CreatePayloadSession: machine is x64 ---------------
                                                    ______ Verify Dependency Subscribers ______
                                                    Setting property "INSTALLDIR" to: C:\Program Files\Adobe
                                                    Setting property "installLanguage" to: en_GB
                                                    Attempting to find the selected language in the set of available payload languages
                                                    Setting property "installSourcePath" to: C:\Users\Administrator\Desktop\Adobe CS5
                                                    Overwrite property "userASUPath" to: C:\Users\ADMINI~1\AppData\Local\Adobe\OOBE\PDApp\
                                                    Found payload actions:
                                                    Deciding what installer mode to use...
                                                    [    1072] Mon May 31 18:06:33 2010  INFO
                                                    BEGIN Setting requested payload actions
                                                    Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: false
                                                    Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
                                                    Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
                                                    Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
                                                    Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: false
                                                    Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
                                                    Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: false
                                                    Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
                                                    Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
                                                    Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
                                                    Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false
                                                    Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
                                                    Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: false
                                                    Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
                                                    Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: false
                                                    Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
                                                    Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false
                                                    Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
                                                    Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false
                                                    Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
                                                    Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: false
                                                    Action string for  {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5  is none
                                                    Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
                                                    Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
                                                    Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
                                                    Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
                                                    Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false
                                                    Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
                                                    Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false
                                                    Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
                                                    Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
                                                    Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
                                                    Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false
                                                    Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
                                                    Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
                                                    Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
                                                    Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
                                                    Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
                                                    Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
                                                    Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
                                                    Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
                                                    Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
                                                    Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
                                                    Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
                                                    Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: false
                                                    Action string for  {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support  is none
                                                    Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
                                                    Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
                                                    Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
                                                    Action string for  {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64  is none
                                                    Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: false
                                                    Action string for  {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64  is none
                                                    Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: false
                                                    Action string for  {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64  is none
                                                    Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: false
                                                    Action string for  {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64  is none
                                                    Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
                                                    Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
                                                    Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: false
                                                    Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
                                                    Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false
                                                    Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
                                                    Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
                                                    Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
                                                    Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false
                                                    Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
                                                    Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: false
                                                    Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
                                                    Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
                                                    Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
                                                    Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
                                                    Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
                                                    Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
                                                    Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
                                                    Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
                                                    Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
                                                    Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
                                                    Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
                                                    Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
                                                    Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
                                                    Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
                                                    Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
                                                    Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
                                                    Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
                                                    Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: false
                                                    Action string for  {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5  is none
                                                    Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: false
                                                    Action string for  {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5  is none
                                                    Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false
                                                    Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
                                                    Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
                                                    Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
                                                    Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: false
                                                    Action string for  {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5  is none
                                                    Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
                                                    Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
                                                    Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false
                                                    Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
                                                    Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                                                    Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
                                                    Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
                                                    Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
                                                    Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
                                                    Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
                                                    Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: false
                                                    Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
                                                    Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: false
                                                    Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
                                                    Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: false
                                                    Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
                                                    Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: false
                                                    Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
                                                    Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: false
                                                    Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
                                                    Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: false
                                                    Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
                                                    Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: false
                                                    Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
                                                    Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: false
                                                    Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none
                                                    Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: false
                                                    Action string for  {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64  is none
                                                    Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: false
                                                    Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none
                                                    Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: false
                                                    Action string for  {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64  is none
                                                    Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false
                                                    Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
                                                    Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: false
                                                    Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
                                                    Value returned on lookup of payload: {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5 is: false
                                                    Action string for  {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5  is install
                                                    Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: false
                                                    Action string for  {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core  is none
                                                    Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: false
                                                    Action string for  {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB  is none
                                                    Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
                                                    Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
                                                    Action string for  {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US  is none
                                                    Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
                                                    Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: false
                                                    Action string for  {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64  is install
                                                    Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: false
                                                    Action string for  {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64  is none
                                                    Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
                                                    Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
                                                    Action string for  {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64  is none
                                                    Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
                                                    END Setting requested payload actions
                                                    Collected advanced path check information for INSTALLDIR
                                                    INSTALLDIR is a well-formed path
                                                    INSTALLDIR is not the root path
                                                    INSTALLDIR is on a local volume
                                                    INSTALLDIR is on a writable volume
                                                    INSTALLDIR is not on a case sensitive volume
                                                    INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
                                                    [    1072] Mon May 31 18:06:34 2010  WARN
                                                    [    1072] Mon May 31 18:06:35 2010  INFO
                                                    ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
                                                    In InstallPreSystemCheckProc
                                                    Custom action return code: 0
                                                    :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 29.4655 miliseconds (0.0294655 seconds)
                                                    ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
                                                    :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 19.6399 miliseconds (0.0196399 seconds)
                                                    ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
                                                    CustomHooksTester -> In InstallPreSystemCheckProc
                                                    :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 60.9811 miliseconds (0.0609811 seconds)
                                                    ::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
                                                    Font Installer: Fonts STI Custom Hook 1.6 Release
                                                    :: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 27.3517 miliseconds (0.0273517 seconds)
                                                    ::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
                                                    :: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 55.7985 miliseconds (0.0557985 seconds)
                                                    ::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
                                                    :: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 27.2726 miliseconds (0.0272726 seconds)
                                                    ::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
                                                    :: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 38.876 miliseconds (0.038876 seconds)
                                                    [    1072] Mon May 31 18:06:41 2010  INFO
                                                    Payloads passed preflight validation.
                                                    Call PreSession Custom Hook
                                                    Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                                                    ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
                                                    [    4372] Mon May 31 18:06:41 2010  INFO
                                                    Installer Operation: InstallThirdPartyPayloadOperation
                                                    Installing third party payload
                                                    Installing payload
                                                    Attempting to install package from:C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                                                    Command line arguments:
                                                    [    4372] Mon May 31 18:06:42 2010  INFO
                                                    1: 0 2: 1033 3: 1252
                                                    === Logging started: 31/05/2010  18:06:42 ===
                                                    Message type: 0, Argument: 1033
                                                    Message type: 1, Argument: Microsoft_VC80_CRT_x86
                                                    Action 18:06:42: INSTALL.
                                                    Action start 18:06:42: INSTALL.
                                                    Action 18:06:42: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                                                    Action start 18:06:42: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                                                    Action ended 18:06:42: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                                                    Action 18:06:42: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                                                    Action start 18:06:42: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
                                                    Action ended 18:06:42: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
                                                    Action 18:06:42: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                                                    Action start 18:06:42: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                                                    Action ended 18:06:42: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                                                    Action 18:06:42: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                                                    Action start 18:06:42: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
                                                    Action ended 18:06:42: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
                                                    Action 18:06:42: AppSearch. Searching for installed applications
                                                    Action start 18:06:42: AppSearch.
                                                    Action ended 18:06:42: AppSearch. Return value 0.
                                                    Action 18:06:42: LaunchConditions. Evaluating launch conditions
                                                    Action start 18:06:42: LaunchConditions.
                                                    Action ended 18:06:42: LaunchConditions. Return value 0.
                                                    Action 18:06:42: FindRelatedProducts. Searching for related applications
                                                    Action start 18:06:42: FindRelatedProducts.
                                                    Action ended 18:06:42: FindRelatedProducts. Return value 0.
                                                    Action 18:06:42: ValidateProductID.
                                                    Action start 18:06:42: ValidateProductID.
                                                    Action ended 18:06:42: ValidateProductID. Return value 1.
                                                    Action 18:06:42: CostInitialize. Computing space requirements
                                                    Action start 18:06:42: CostInitialize.
                                                    Action ended 18:06:42: CostInitialize. Return value 1.
                                                    Action 18:06:42: FileCost. Computing space requirements
                                                    Action start 18:06:42: FileCost.
                                                    Action ended 18:06:42: FileCost. Return value 1.
                                                    Action 18:06:42: IsolateComponents.
                                                    Action start 18:06:42: IsolateComponents.
                                                    Action ended 18:06:42: IsolateComponents. Return value 0.
                                                    Action 18:06:42: CostFinalize. Computing space requirements
                                                    Action start 18:06:42: CostFinalize.
                                                    Action ended 18:06:42: CostFinalize. Return value 1.
                                                    Action 18:06:42: SetARPINSTALLLOCATION.
                                                    Action start 18:06:42: SetARPINSTALLLOCATION.
                                                    Action ended 18:06:42: SetARPINSTALLLOCATION. Return value 1.
                                                    Action 18:06:42: SetODBCFolders. Initializing ODBC directories
                                                    Action start 18:06:42: SetODBCFolders.
                                                    Action ended 18:06:42: SetODBCFolders. Return value 0.
                                                    Action 18:06:42: MigrateFeatureStates. Migrating feature states from related applications
                                                    Action start 18:06:42: MigrateFeatureStates.
                                                    Action ended 18:06:42: MigrateFeatureStates. Return value 0.
                                                    Action 18:06:42: InstallValidate. Validating install
                                                    Action start 18:06:42: InstallValidate.
                                                    Action ended 18:06:42: InstallValidate. Return value 1.
                                                    Action 18:06:42: RemoveExistingProducts. Removing applications
                                                    Action start 18:06:42: RemoveExistingProducts.
                                                    Action ended 18:06:42: RemoveExistingProducts. Return value 0.
                                                    Action 18:06:42: InstallInitialize.
                                                    Action start 18:06:42: InstallInitialize.
                                                    [    4372] Mon May 31 18:06:43 2010  INFO
                                                    Action ended 18:06:43: InstallInitialize. Return value 1.
                                                    Action 18:06:43: SxsInstallCA.
                                                    Action start 18:06:43: SxsInstallCA.
                                                    1: sxsdelca 2: traceop 3: 1256 4: 0
                                                    1: sxsdelca 2: traceop 3: 1257 4: 0
                                                    1: sxsdelca 2: traceop 3: 1258 4: 0
                                                    1: sxsdelca 2: traceop 3: 1284 4: 0
                                                    1: sxsdelca 2: traceop 3: 1288 4: 0
                                                    1: sxsdelca 2: traceop 3: 1289 4: 0
                                                    1: sxsdelca 2: traceop 3: 1290 4: 0
                                                    1: sxsdelca 2: traceop 3: 1292 4: 0
                                                    1: sxsdelca 2: traceop 3: 1318 4: 0
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    [    4372] Mon May 31 18:06:44 2010  INFO
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
                                                    1: sxsdelca 2: traceop 3: 1284 4: 259
                                                    1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
                                                    Action ended 18:06:44: SxsInstallCA. Return value 1.
                                                    Action 18:06:44: AllocateRegistrySpace. Allocating registry space
                                                    Action start 18:06:44: AllocateRegistrySpace.
                                                    Action ended 18:06:44: AllocateRegistrySpace. Return value 1.
                                                    Action 18:06:44: ProcessComponents. Updating component registration
                                                    Action start 18:06:44: ProcessComponents.
                                                    Action 18:06:44: GenerateScript. Generating script operations for action:
                                                    Action ended 18:06:44: ProcessComponents. Return value 1.
                                                    Action 18:06:44: UnpublishComponents. Unpublishing Qualified Components
                                                    Action start 18:06:44: UnpublishComponents.
                                                    Action ended 18:06:44: UnpublishComponents. Return value 0.
                                                    Action 18:06:44: MsiUnpublishAssemblies. Unpublishing assembly information
                                                    Action start 18:06:44: MsiUnpublishAssemblies.
                                                    Action ended 18:06:44: MsiUnpublishAssemblies. Return value 1.
                                                    Action 18:06:44: UnpublishFeatures. Unpublishing product features
                                                    Action start 18:06:44: UnpublishFeatures.
                                                    Action ended 18:06:44: UnpublishFeatures. Return value 1.
                                                    Action 18:06:44: StopServices. Stopping services
                                                    Action start 18:06:44: StopServices.
                                                    Action ended 18:06:44: StopServices. Return value 1.
                                                    Action 18:06:44: DeleteServices. Deleting services
                                                    Action start 18:06:44: DeleteServices.
                                                    Action ended 18:06:44: DeleteServices. Return value 1.
                                                    Action 18:06:44: UnregisterComPlus. Unregistering COM+ Applications and Components
                                                    Action start 18:06:44: UnregisterComPlus.
                                                    Action ended 18:06:44: UnregisterComPlus. Return value 0.
                                                    Action 18:06:44: SelfUnregModules. Unregistering modules
                                                    Action start 18:06:44: SelfUnregModules.
                                                    Action ended 18:06:44: SelfUnregModules. Return value 1.
                                                    Action 18:06:44: UnregisterTypeLibraries. Unregistering type libraries
                                                    Action start 18:06:44: UnregisterTypeLibraries.
                                                    Action ended 18:06:44: UnregisterTypeLibraries. Return value 0.
                                                    Action 18:06:44: RemoveODBC. Removing ODBC components
                                                    Action start 18:06:44: RemoveODBC.
                                                    Action ended 18:06:44: RemoveODBC. Return value 1.
                                                    Action 18:06:44: UnregisterFonts. Unregistering fonts
                                                    Action start 18:06:44: UnregisterFonts.
                                                    Action ended 18:06:44: UnregisterFonts. Return value 1.
                                                    Action 18:06:44: RemoveRegistryValues. Removing system registry values
                                                    Action start 18:06:44: RemoveRegistryValues.
                                                    Action ended 18:06:44: RemoveRegistryValues. Return value 1.
                                                    Action 18:06:44: UnregisterClassInfo. Unregister class servers
                                                    Action start 18:06:44: UnregisterClassInfo.
                                                    Action ended 18:06:44: UnregisterClassInfo. Return value 0.
                                                    Action 18:06:44: UnregisterExtensionInfo. Unregistering extension servers
                                                    Action start 18:06:44: UnregisterExtensionInfo.
                                                    Action ended 18:06:44: UnregisterExtensionInfo. Return value 0.
                                                    Action 18:06:44: UnregisterProgIdInfo. Unregistering program identifiers
                                                    Action start 18:06:44: UnregisterProgIdInfo.
                                                    Action ended 18:06:44: UnregisterProgIdInfo. Return value 0.
                                                    Action 18:06:44: UnregisterMIMEInfo. Unregistering MIME info
                                                    Action start 18:06:44: UnregisterMIMEInfo.
                                                    Action ended 18:06:44: UnregisterMIMEInfo. Return value 0.
                                                    Action 18:06:44: RemoveIniValues. Removing INI file entries
                                                    Action start 18:06:44: RemoveIniValues.
                                                    Action ended 18:06:44: RemoveIniValues. Return value 1.
                                                    Action 18:06:44: RemoveShortcuts. Removing shortcuts
                                                    Action start 18:06:44: RemoveShortcuts.
                                                    Action ended 18:06:44: RemoveShortcuts. Return value 0.
                                                    Action 18:06:44: RemoveEnvironmentStrings. Updating environment strings
                                                    Action start 18:06:44: RemoveEnvironmentStrings.
                                                    Action ended 18:06:44: RemoveEnvironmentStrings. Return value 1.
                                                    Action 18:06:44: RemoveDuplicateFiles. Removing duplicated files
                                                    Action start 18:06:44: RemoveDuplicateFiles.
                                                    Action ended 18:06:44: RemoveDuplicateFiles. Return value 1.
                                                    Action 18:06:44: RemoveFiles. Removing files
                                                    Action start 18:06:44: RemoveFiles.
                                                    Action ended 18:06:44: RemoveFiles. Return value 0.
                                                    Action 18:06:44: RemoveFolders. Removing folders
                                                    Action start 18:06:44: RemoveFolders.
                                                    Action ended 18:06:44: RemoveFolders. Return value 0.
                                                    Action 18:06:44: CreateFolders. Creating folders
                                                    Action start 18:06:44: CreateFolders.
                                                    Action ended 18:06:44: CreateFolders. Return value 0.
                                                    Action 18:06:44: MoveFiles. Moving files
                                                    Action start 18:06:44: MoveFiles.
                                                    Action ended 18:06:44: MoveFiles. Return value 1.
                                                    Action 18:06:44: InstallFiles. Copying new files
                                                    Action start 18:06:44: InstallFiles.
                                                    File: Copying new files,  Directory: ,  Size:
                                                    Action ended 18:06:44: InstallFiles. Return value 1.
                                                    Action 18:06:44: PatchFiles. Patching files
                                                    Action start 18:06:44: PatchFiles.
                                                    Action ended 18:06:44: PatchFiles. Return value 0.
                                                    Action 18:06:44: DuplicateFiles. Creating duplicate files
                                                    Action start 18:06:44: DuplicateFiles.
                                                    Action ended 18:06:44: DuplicateFiles. Return value 1.
                                                    Action 18:06:44: BindImage. Binding executables
                                                    Action start 18:06:44: BindImage.
                                                    Action ended 18:06:44: BindImage. Return value 1.
                                                    Action 18:06:44: CreateShortcuts. Creating shortcuts
                                                    Action start 18:06:44: CreateShortcuts.
                                                    Shortcut: Creating shortcuts
                                                    Action ended 18:06:44: CreateShortcuts. Return value 0.
                                                    Action 18:06:44: RegisterClassInfo. Registering class servers
                                                    Action start 18:06:44: RegisterClassInfo.
                                                    Action ended 18:06:44: RegisterClassInfo. Return value 0.
                                                    Action 18:06:44: RegisterExtensionInfo. Registering extension servers
                                                    Action start 18:06:44: RegisterExtensionInfo.
                                                    Action ended 18:06:44: RegisterExtensionInfo. Return value 0.
                                                    Action 18:06:44: RegisterProgIdInfo. Registering program identifiers
                                                    Action start 18:06:44: RegisterProgIdInfo.
                                                    Action ended 18:06:44: RegisterProgIdInfo. Return value 0.
                                                    [    4372] Mon May 31 18:06:45 2010  INFO
                                                    Action 18:06:44: RegisterMIMEInfo. Registering MIME info
                                                    Action start 18:06:45: RegisterMIMEInfo.
                                                    Action ended 18:06:45: RegisterMIMEInfo. Return value 0.
                                                    Action 18:06:45: WriteRegistryValues. Writing system registry values
                                                    Action start 18:06:45: WriteRegistryValues.
                                                    Action ended 18:06:45: WriteRegistryValues. Return value 1.
                                                    Action 18:06:45: WriteIniValues. Writing INI file values
                                                    Action start 18:06:45: WriteIniValues.
                                                    Action ended 18:06:45: WriteIniValues. Return value 1.
                                                    Action 18:06:45: WriteEnvironmentStrings. Updating environment strings
                                                    Action start 18:06:45: WriteEnvironmentStrings.
                                                    Action ended 18:06:45: WriteEnvironmentStrings. Return value 1.
                                                    Action 18:06:45: RegisterFonts. Registering fonts
                                                    Action start 18:06:45: RegisterFonts.
                                                    Action ended 18:06:45: RegisterFonts. Return value 1.
                                                    Action 18:06:45: InstallODBC. Installing ODBC components
                                                    Action start 18:06:45: InstallODBC.
                                                    Action ended 18:06:45: InstallODBC. Return value 0.
                                                    Action 18:06:45: RegisterTypeLibraries. Registering type libraries
                                                    Action start 18:06:45: RegisterTypeLibraries.
                                                    Action ended 18:06:45: RegisterTypeLibraries. Return value 0.
                                                    Action 18:06:45: SelfRegModules. Registering modules
                                                    Action start 18:06:45: SelfRegModules.
                                                    Action ended 18:06:45: SelfRegModules. Return value 1.
                                                    Action 18:06:45: RegisterComPlus. Registering COM+ Applications and Components
                                                    Action start 18:06:45: RegisterComPlus.
                                                    Action ended 18:06:45: RegisterComPlus. Return value 0.
                                                    Action 18:06:45: InstallServices. Installing new services
                                                    Action start 18:06:45: InstallServices.
                                                    Action ended 18:06:45: InstallServices. Return value 1.
                                                    Action 18:06:45: StartServices. Starting services
                                                    Action start 18:06:45: StartServices.
                                                    Action ended 18:06:45: StartServices. Return value 1.
                                                    Action 18:06:45: RegisterUser. Registering user
                                                    Action start 18:06:45: RegisterUser.
                                                    Registering user
                                                    Action ended 18:06:45: RegisterUser. Return value 1.
                                                    Action 18:06:45: RegisterProduct. Registering product
                                                    Action start 18:06:45: RegisterProduct.
                                                    Registering product
                                                    Action ended 18:06:45: RegisterProduct. Return value 1.
                                                    Action 18:06:45: PublishComponents. Publishing qualified components
                                                    Action start 18:06:45: PublishComponents.
                                                    Action ended 18:06:45: PublishComponents. Return value 0.
                                                    Action 18:06:45: MsiPublishAssemblies. Publishing assembly information
                                                    Action start 18:06:45: MsiPublishAssemblies.
                                                    Application Context:Publishing assembly information, Assembly Name:
                                                    Action ended 18:06:45: MsiPublishAssemblies. Return value 1.
                                                    Action 18:06:45: PublishFeatures. Publishing product features
                                                    Action start 18:06:45: PublishFeatures.
                                                    Feature: Publishing product features
                                                    Action ended 18:06:45: PublishFeatures. Return value 1.
                                                    Action 18:06:45: PublishProduct. Publishing product information
                                                    Action start 18:06:45: PublishProduct.
                                                    Action ended 18:06:45: PublishProduct. Return value 1.
                                                    Action 18:06:45: InstallFinalize.
                                                    Action start 18:06:45: InstallFinalize.
                                                    Action 18:06:45: ProcessComponents. Updating component registration
                                                    Action 18:06:45: RemoveODBC. Removing ODBC components
                                                    Action 18:06:45: InstallFiles. Copying new files
                                                    Error 1402.Could not open key: UNKNOWN\Components\DA42BC89BF25F5BD0AF18C3B9B1A1EE8\7E577B2224C65CF4E801A9E52375DB49.   Verify that you have sufficient access to that key, or contact your support personnel.
                                                    Action ended 18:06:45: InstallFinalize. Return value 3.
                                                    Message type: 2, Argument: 0
                                                    Action 18:06:45: Rollback. Rolling back action:
                                                    Copying new files
                                                    Message type: 2, Argument: 1
                                                    Action ended 18:06:45: INSTALL. Return value 3.
                                                    Property(S): DiskPrompt = [1]
                                                    Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
                                                    Property(S): ProductToBeRegistered = 1
                                                    Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                                                    Property(S): SOURCEDIR = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                                                    Property(S): PrimaryVolumeSpaceRemaining = 0
                                                    Property(S): PrimaryVolumeSpaceRequired = 0
                                                    Property(S): PrimaryVolumeSpaceAvailable = 0
                                                    Property(S): OutOfNoRbDiskSpace = 0
                                                    Property(S): OutOfDiskSpace = 0
                                                    Property(S): CostingComplete = 1
                                                    Property(S): ROOTDRIVE = C:\
                                                    Property(S): ACTION = INSTALL
                                                    Property(S): SHIMFLAGS = 512
                                                    Property(S): UILevel = 2
                                                    Property(S): OriginalDatabase = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
                                                    Property(S): DATABASE = C:\Windows\Installer\17acc99.msi
                                                    Property(S): Privileged = 1
                                                    Property(S): MsiRunningElevated = 1
                                                    Property(S): RedirectedDllSupport = 2
                                                    Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
                                                    Property(S): MsiNetAssemblySupport = 2.0.50727.4927
                                                    Property(S): Date = 31/05/2010
                                                    Property(S): Time = 18:06:45
                                                    Property(S): TTCSupport = 1
                                                    Property(S): ColorBits = 32
                                                    Property(S): TextInternalLeading = 3
                                                    Property(S): TextHeight = 16
                                                    Property(S): BorderSide = 1
                                                    Property(S): BorderTop = 1
                                                    Property(S): CaptionHeight = 22
                                                    Property(S): ScreenY = 768
                                                    Property(S): ScreenX = 1024
                                                    Property(S): SystemLanguageID = 2057
                                                    Property(S): ComputerName = MALOOQ-PC
                                                    Property(S): UserLanguageID = 2057
                                                    Property(S): UserSID = S-1-5-21-270187645-2713347059-3258507716-500
                                                    Property(S): LogonUser = Administrator
                                                    Property(S): MsiTrueAdminUser = 1
                                                    Property(S): AdminUser = 1
                                                    Property(S): VirtualMemory = 6333
                                                    Property(S): PhysicalMemory = 4061
                                                    Property(S): Intel = 6
                                                    Property(S): Msix64 = 6
                                                    Property(S): MsiAMD64 = 6
                                                    Property(S): ShellAdvtSupport = 1
                                                    Property(S): OLEAdvtSupport = 1
                                                    Property(S): GPTSupport = 1
                                                    Property(S): VersionNT = 601
                                                    Property(S): ProgramFilesFolder = C:\Program Files (x86)\
                                                    Property(S): ADOBE = C:\Program Files (x86)\Adobe\
                                                    Property(S): TARGETDIR = C:\
                                                    Property(S): ALLUSERSPROFILE = C:\
                                                    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
                                                    Property(S): AppDataFolder = C:\Users\Administrator\AppData\Roaming\
                                                    Property(S): CommonAppDataFolder = C:\ProgramData\
                                                    Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
                                                    Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
                                                    Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
                                                    Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
                                                    Property(S): DesktopFolder = C:\Users\Public\Desktop\
                                                    Property(S): FavoritesFolder = C:\Users\Administrator\Favorites\
                                                    Property(S): FontsFolder = C:\Windows\Fonts\
                                                    Property(S): GlobalAssemblyCache = C:\
                                                    Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
                                                    Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
                                                    Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
                                                    Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
                                                    Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
                                                    Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
                                                    Property(S): LocalAppDataFolder = C:\Users\Administrator\AppData\Local\
                                                    Property(S): MyPicturesFolder = C:\Users\Administrator\Pictures\
                                                    Property(S): PersonalFolder = C:\Users\Administrator\Documents\
                                                    Property(S): PrimaryVolumePath = C:\
                                                    Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
                                                    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
                                                    Property(S): SendToFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\SendTo\
                                                    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
                                                    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
                                                    Property(S): System16Folder = C:\
                                                    Property(S): System64Folder = C:\Windows\SysWOW64\
                                                    Property(S): SystemFolder = C:\Windows\SysWOW64\
                                                    Property(S): SourceDir = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
                                                    Property(S): TempFolder = C:\Users\ADMINI~1\AppData\Local\Temp\
                                                    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
                                                    Property(S): USERPROFILE = C:\
                                                    Property(S): WindowsFolder = C:\Windows\
                                                    Property(S): WindowsVolume = C:\
                                                    Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                                                    Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
                                                    Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
                                                    Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
                                                    Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                                                    Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                                                    Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                                                    Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                                                    Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
                                                    Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
                                                    Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
                                                    Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
                                                    Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
                                                    Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
                                                    Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
                                                    Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
                                                    Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
                                                    Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
                                                    Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
                                                    Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
                                                    Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
                                                    Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
                                                    Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
                                                    Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
                                                    Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
                                                    Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
                                                    Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
                                                    Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
                                                    Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
                                                    Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
                                                    Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
                                                    Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
                                                    Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
                                                    Property(S): ALLUSERS = 1
                                                    Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
                                                    Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
                                                    Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
                                                    Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
                                                    Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
                                                    Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
                                                    Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
                                                    Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                                                    Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
                                                    Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
                                                    Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
                                                    Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
                                                    Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
                                                    Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
                                                    Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
                                                    Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
                                                    Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
                                                    Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
                                                    Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
                                                    Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
                                                    Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
                                                    Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
                                                    Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
                                                    Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
                                                    Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
                                                    Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
                                                    Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
                                                    Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
                                                    Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
                                                    Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
                                                    Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
                                                    Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
                                                    Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
                                                    Property(S): RecentFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent\
                                                    Property(S): PrintHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
                                                    Property(S): NetHoodFolder = C:\Users\Administrator\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
                                                    Property(S): RemoteAdminTS = 1
                                                    Property(S): MsiNTSuitePersonal = 1
                                                    Property(S): MsiNTProductType = 1
                                                    Property(S): ServicePackLevelMinor = 0
                                                    Property(S): ISCHECKFORPRODUCTUPDATES = 1
                                                    Property(S): ApplicationUsers = AllUsers
                                                    Property(S): AgreeToLicense = No
                                                    Property(S): _IsMaintenance = Change
                                                    Property(S): SetupType = Typical
                                                    Property(S): _IsSetupTypeMin = Typical
                                                    Property(S): IS_SQLSERVER_USERNAME = sa
                                                    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
                                                    Property(S): RestartManagerOption = CloseRestart
                                                    Property(S): Display_IsBitmapDlg = 1
                                                    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
                                                    Property(S): DefaultUIFont = Tahoma8
                                                    Property(S): DialogCaption = InstallShield for Windows Installer
                                                    Property(S): DisplayNameCustom = Custom
                                                    Property(S): DisplayNameMinimal = Minimal
                                                    Property(S): DisplayNameTypical = Typical
                                                    Property(S): DWUSINTERVAL = 30
                                                    Property(S): ErrorDialog = SetupError
                                                    Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
                                                    Property(S): InstallChoice = AR
                                                    Property(S): INSTALLLEVEL = 100
                                                    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
                                                    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
                                                    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
                                                    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
                                                    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
                                                    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
                                                    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
                                                    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
                                                    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
                                                    Property(S): ISVROOT_PORT_NO = 0
                                                    Property(S): Manufacturer = Adobe
                                                    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
                                                    Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
                                                    Property(S): ProductID = none
                                                    Property(S): ProductLanguage = 1033
                                                    Property(S): ProductName = Microsoft_VC80_CRT_x86
                                                    Property(S): ProductVersion = 8.0.50727.4053
                                                    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
                                                    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
                                                    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
                                                    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
                                                    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
                                                    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
                                                    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
                                                    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
                                                    Property(S): ProgressType0 = install
                                                    Property(S): ProgressType1 = Installing
                                                    Property(S): ProgressType2 = installed
                                                    Property(S): ProgressType3 = installs
                                                    Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
                                                    Property(S): RebootYesNo = No
                                                    Property(S): ReinstallModeText = omus
                                                    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
                                                    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
                                                    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
                                                    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
                                                    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
                                                    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
                                                    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
                                                    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
                                                    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
                                                    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
                                                    Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
                                                    Property(S): ARPURLINFOABOUT = http://www.Adobe.com
                                                    Property(S): SHOWLAUNCHPROGRAM = 0
                                                    Property(S): REBOOT = ReallySuppress
                                                    Property(S): ARPSYSTEMCOMPONENT = 1
                                                    Property(S): MsiLogFileLocation = C:\Users\ADMINI~1\AppData\Local\Temp\MSIaca77.LOG
                                                    Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Adobe\My Product Name\
                                                    Property(S): ServicePackLevel = 0
                                                    Property(S): WindowsBuild = 7600
                                                    Property(S): VersionNT64 = 601
                                                    Property(S): VersionMsi = 5.00
                                                    Property(S): VersionDatabase = 200
                                                    Property(S): CLIENTPROCESSID = 4436
                                                    Property(S): MSICLIENTUSESEXTERNALUI = 1
                                                    Property(S): CLIENTUILEVEL = 3
                                                    Property(S): CURRENTDIRECTORY = C:\Users\Administrator\AppData\Local\Adobe\OOBE\PDApp\DWA
                                                    Property(S): PackagecodeChanging = 1
                                                    Property(S): USERNAME = Malooq
                                                    Property(S): ProductState = -1
                                                    Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
                                                    === Logging stopped: 31/05/2010  18:06:45 ===
                                                    1: 2 2: 0
                                                    1: 2 2: 1
                                                    Installation result: 1603
                                                    Third party payload succeded.  Testing return code: 1603
                                                    [    1072] Mon May 31 18:06:46 2010  INFO
                                                    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
                                                    :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 5017.43 miliseconds (5.01743 seconds) DTR = 37.4694 KBPS (0.0365912 MBPS)
                                                    User specified overrideFile:
                                                    Calling the ROLLBACK custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
                                                    [    1072] Mon May 31 18:06:46 2010  WARN
                                                    Payload cannot be installed due to dependent operation failure
                                                    Skipping payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 as payload is not cached
                                                    Skipping payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 as payload is not cached
                                                    Skipping payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 as payload is not cached
                                                    Calling the custom action code for pre-install for payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
                                                    ::START TIMER:: [Payload Operation :{2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}]
                                                    [    3524] Mon May 31 18:06:46 2010  INFO
                                                    Installer Operation: PayloadInstaller
                                                    Request to install payload
                                                    Extracting assets...
                                                    [    3524] Mon May 31 18:06:47 2010  INFO
                                                    Extracting assets complete. Number assets: 1
                                                    Beginning installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                                                    2 Setting permission for: C:\Program Files (x86)\Common Files\Adobe\APE\3.1 Group/User:Everyone Access:GENERIC_READ
                                                    [    3524] Mon May 31 18:06:48 2010  INFO
                                                    Completing installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
                                                    [    3524] Mon May 31 18:06:49 2010  INFO
                                                    UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}.db
                                                    [    1072] Mon May 31 18:06:49 2010  INFO
                                                    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
                                                    :: END TIMER :: [Payload Operation :{2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}] took 3024.84 miliseconds (3.02484 seconds) DTR = 5994.37 KBPS (5.85388 MBPS)
                                                    Updating driver data - Action: Add driver entry
                                                    Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                                                    [    1072] Mon May 31 18:06:50 2010  INFO
                                                    Calling the custom action code for post-install for payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding
                                                    Calling the custom action code for pre-install for payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
                                                    ::START TIMER:: [Payload Operation :{E5DD149F-8370-48F9-A32C-2E3DC776CFFB}]
                                                    [    2252] Mon May 31 18:06:50 2010  INFO
                                                    [    2252] Mon May 31 18:07:02 2010  INFO
                                                    Beginning installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                                                    [    2252] Mon May 31 18:07:20 2010  INFO
                                                    Completing installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
                                                    UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{E5DD149F-8370-48F9-A32C-2E3DC776CFFB}.db
                                                    [    1072] Mon May 31 18:07:21 2010  INFO
                                                    :: END TIMER :: [Payload Operation :{E5DD149F-8370-48F9-A32C-2E3DC776CFFB}] took 31084.3 miliseconds (31.0843 seconds) DTR = 2927.91 KBPS (2.85929 MBPS)
                                                    Calling the custom action code for post-install for payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE
                                                    [    1072] Mon May 31 18:07:21 2010  WARN
                                                    Skipping payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 as payload is not cached
                                                    Skipping payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 as payload is not cached
                                                    Calling the custom action code for pre-install for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                                                    ::START TIMER:: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}]
                                                    [    3468] Mon May 31 18:07:21 2010  INFO
                                                    [    3468] Mon May 31 18:07:44 2010  INFO
                                                    Beginning installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                                                    [    3468] Mon May 31 18:08:06 2010  INFO
                                                    Completing installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
                                                    UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{3F023875-4A52-4605-9DB6-A88D4A813E8D}.db
                                                    [    1072] Mon May 31 18:08:06 2010  INFO
                                                    :: END TIMER :: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}] took 45084.7 miliseconds (45.0847 seconds) DTR = 3732.44 KBPS (3.64496 MBPS)
                                                    [    1072] Mon May 31 18:08:07 2010  INFO
                                                    Calling the custom action code for post-install for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer
                                                    [    1072] Mon May 31 18:08:07 2010  WARN
                                                    Skipping payload {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 as payload is not cached
                                                    Skipping payload {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 as payload is not cached
                                                    Calling the custom action code for pre-install for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                                                    ::START TIMER:: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}]
                                                    [    4904] Mon May 31 18:08:07 2010  INFO
                                                    Installing payload
                                                    Attempting to install package from:C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                                                    Payload is already installed with MSI
                                                    MsiSourceListAddSource for  C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi is 0
                                                    MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86_x64.msi, Result: 0
                                                    Payload source is not removable so not updating media info
                                                    Command line arguments:  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
                                                    1: 0 2: 0 3: 1252
                                                    1: 0 2: 0 3: 1252
                                                    [    4904] Mon May 31 18:08:08 2010  INFO
                                                    === Logging started: 31/05/2010  18:08:08 ===
                                                    Message type: 1, Argument: Microsoft_VC90_CRT_x86_x64
                                                    Action 18:08:08: INSTALL.
                                                    Action start 18:08:08: INSTALL.
                                                    Action 18:08:08: AppSearch. Searching for installed applications
                                                    Action start 18:08:08: AppSearch.
                                                    Action ended 18:08:08: AppSearch. Return value 0.
                                                    Action 18:08:08: FindRelatedProducts. Searching for related applications
                                                    Action start 18:08:08: FindRelatedProducts.
                                                    Action ended 18:08:08: FindRelatedProducts. Return value 0.
                                                    Action 18:08:08: ValidateProductID.
                                                    Action start 18:08:08: ValidateProductID.
                                                    Action ended 18:08:08: ValidateProductID. Return value 1.
                                                    Action 18:08:08: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
                                                    Action start 18:08:08: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
                                                    Action ended 18:08:08: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812. Return value 1.
                                                    Action 18:08:08: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B.
                                                    Action start 18:08:08: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B.
                                                    Action ended 18:08:08: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B. Return value 1.
                                                    Action 18:08:08: CostInitialize. Computing space requirements
                                                    Action start 18:08:08: CostInitialize.
                                                    Action ended 18:08:08: CostInitialize. Return value 1.
                                                    Action 18:08:08: FileCost. Computing space requirements
                                                    Action start 18:08:08: FileCost.
                                                    Action ended 18:08:08: FileCost. Return value 1.
                                                    Action 18:08:08: IsolateComponents.
                                                    Action start 18:08:08: IsolateComponents.
                                                    Action ended 18:08:08: IsolateComponents. Return value 0.
                                                    Action 18:08:08: CostFinalize. Computing space requirements
                                                    Action start 18:08:08: CostFinalize.
                                                    Action ended 18:08:08: CostFinalize. Return value 1.
                                                    Action 18:08:08: SetODBCFolders. Initializing ODBC directories
                                                    Action start 18:08:08: SetODBCFolders.
                                                    Action ended 18:08:08: SetODBCFolders. Return value 0.
                                                    Action 18:08:08: MigrateFeatureStates. Migrating feature states from related applications
                                                    Action start 18:08:08: MigrateFeatureStates.
                                                    Action ended 18:08:08: MigrateFeatureStates. Return value 0.
                                                    Action 18:08:08: InstallValidate. Validating install
                                                    Action start 18:08:08: InstallValidate.
                                                    Action ended 18:08:08: InstallValidate. Return value 1.
                                                    Action 18:08:08: RemoveExistingProducts. Removing applications
                                                    Action start 18:08:08: RemoveExistingProducts.
                                                    Action ended 18:08:08: RemoveExistingProducts. Return value 0.
                                                    Action 18:08:08: InstallInitialize.
                                                    Action start 18:08:08: InstallInitialize.
                                                    Action ended 18:08:08: InstallInitialize. Return value 1.
                                                    Action 18:08:08: ProcessComponents. Updating component registration
                                                    Action start 18:08:08: ProcessComponents.
                                                    Action 18:08:08: GenerateScript. Generating script operations for action:
                                                    Action ended 18:08:08: ProcessComponents. Return value 1.
                                                    Action 18:08:08: UnpublishComponents. Unpublishing Qualified Components
                                                    Action start 18:08:08: UnpublishComponents.
                                                    Action ended 18:08:08: UnpublishComponents. Return value 0.
                                                    Action 18:08:08: MsiUnpublishAssemblies. Unpublishing assembly information
                                                    Action start 18:08:08: MsiUnpublishAssemblies.
                                                    Action ended 18:08:08: MsiUnpublishAssemblies. Return value 1.
                                                    Action 18:08:08: UnpublishFeatures. Unpublishing product features
                                                    Action start 18:08:08: UnpublishFeatures.
                                                    Action ended 18:08:08: UnpublishFeatures. Return value 1.
                                                    Action 18:08:08: StopServices. Stopping services
                                                    Action start 18:08:08: StopServices.
                                                    Action ended 18:08:08: StopServices. Return value 1.
                                                    Action 18:08:08: DeleteServices. Deleting services
                                                    Action start 18:08:08: DeleteServices.
                                                    Action ended 18:08:08: DeleteServices. Return value 1.
                                                    Action 18:08:08: UnregisterComPlus. Unregistering COM+ Applications and Components
                                                    Action start 18:08:08: UnregisterComPlus.
                                                    Action ended 18:08:08: UnregisterComPlus. Return value 0.
                                                    Action 18:08:08: SelfUnregModules. Unregistering modules
                                                    Action start 18:08:08: SelfUnregModules.
                                                    Action ended 18:08:08: SelfUnregModules. Return value 1.
                                                    Action 18:08:08: UnregisterTypeLibraries. Unregistering type libraries
                                                    Action start 18:08:08: UnregisterTypeLibraries.
                                                    Action ended 18:08:08: UnregisterTypeLibraries. Return value 0.
                                                    Action 18:08:08: RemoveODBC. Removing ODBC components
                                                    Action start 18:08:08: RemoveODBC.
                                                    Action ended 18:08:08: RemoveODBC. Return value 1.
                                                    Action 18:08:08: UnregisterFonts. Unregistering fonts
                                                    Action start 18:08:08: UnregisterFonts.
                                                    Action ended 18:08:08: UnregisterFonts. Return value 1.
                                                    Action 18:08:08: RemoveRegistryValues. Removing system registry values
                                                    Action start 18:08:08: RemoveRegistryValues.
                                                    Action ended 18:08:08: RemoveRegistryValues. Return value 1.
                                                    Action 18:08:08: UnregisterClassInfo. Unregister class servers
                                                    Action start 18:08:08: UnregisterClassInfo.
                                                    Action ended 18:08:08: UnregisterClassInfo. Return value 0.
                                                    Action 18:08:08: UnregisterExtensionInfo. Unregistering extension servers
                                                    Action start 18:08:08: UnregisterExtensionInfo.
                                                    Action ended 18:08:08: UnregisterExtensionInfo. Return value 0.
                                                    Action 18:08:08: UnregisterProgIdInfo. Unregistering program identifiers
                                                    Action start 18:08:08: UnregisterProgIdInfo.
                                                    Action ended 18:08:08: UnregisterProgIdInfo. Return value 0.
                                                    Action 18:08:08: UnregisterMIMEInfo. Unregistering MIME info
                                                    Action start 18:08:08: UnregisterMIMEInfo.
                                                    Action ended 18:08:08: UnregisterMIMEInfo. Return value 0.
                                                    Action 18:08:08: RemoveIniValues. Removing INI file entries
                                                    Action start 18:08:08: RemoveIniValues.
                                                    Action ended 18:08:08: RemoveIniValues. Return value 1.
                                                    Action 18:08:08: RemoveShortcuts. Removing shortcuts
                                                    Action start 18:08:08: RemoveShortcuts.
                                                    Action ended 18:08:08: RemoveShortcuts. Return value 0.
                                                    Action 18:08:08: RemoveEnvironmentStrings. Updating environment strings
                                                    Action start 18:08:08: RemoveEnvironmentStrings.
                                                    Action ended 18:08:08: RemoveEnvironmentStrings. Return value 1.
                                                    Action 18:08:08: RemoveDuplicateFiles. Removing duplicated files
                                                    Action start 18:08:08: RemoveDuplicateFiles.
                                                    Action ended 18:08:08: RemoveDuplicateFiles. Return value 1.
                                                    Action 18:08:08: RemoveFiles. Removing files
                                                    Action start 18:08:08: RemoveFiles.
                                                    Action ended 18:08:08: RemoveFiles. Return value 0.
                                                    Action 18:08:08: RemoveFolders. Removing folders
                                                    Action start 18:08:08: RemoveFolders.
                                                    Action ended 18:08:08: RemoveFolders. Return value 0.
                                                    Action 18:08:08: CreateFolders. Creating folders
                                                    Action start 18:08:08: CreateFolders.
                                                    Action ended 18:08:08: CreateFolders. Return value 0.
                                                    Action 18:08:08: MoveFiles. Moving files
                                                    Action start 18:08:08: MoveFiles.
                                                    Action ended 18:08:08: MoveFiles. Return value 1.
                                                    Action 18:08:08: InstallFiles. Copying new files
                                                    Action start 18:08:08: InstallFiles.
                                                    Action ended 18:08:08: InstallFiles. Return value 1.
                                                    Action 18:08:08: PatchFiles. Patching files
                                                    Action start 18:08:08: PatchFiles.
                                                    Action ended 18:08:08: PatchFiles. Return value 0.
                                                    Action 18:08:08: DuplicateFiles. Creating duplicate files
                                                    Action start 18:08:08: DuplicateFiles.
                                                    Action ended 18:08:08: DuplicateFiles. Return value 1.
                                                    Action 18:08:08: BindImage. Binding executables
                                                    Action start 18:08:08: BindImage.
                                                    Action ended 18:08:08: BindImage. Return value 1.
                                                    Action 18:08:08: CreateShortcuts. Creating shortcuts
                                                    Action start 18:08:08: CreateShortcuts.
                                                    Action ended 18:08:08: CreateShortcuts. Return value 0.
                                                    Action 18:08:08: RegisterClassInfo. Registering class servers
                                                    Action start 18:08:08: RegisterClassInfo.
                                                    Action ended 18:08:08: RegisterClassInfo. Return value 0.
                                                    Action 18:08:08: RegisterExtensionInfo. Registering extension servers
                                                    Action start 18:08:08: RegisterExtensionInfo.
                                                    Action ended 18:08:08: RegisterExtensionInfo. Return value 0.
                                                    Action 18:08:08: RegisterProgIdInfo. Registering program identifiers
                                                    Action start 18:08:08: RegisterProgIdInfo.
                                                    Action ended 18:08:08: RegisterProgIdInfo. Return value 0.
                                                    Action 18:08:08: RegisterMIMEInfo. Registering MIME info
                                                    Action start 18:08:08: RegisterMIMEInfo.
                                                    Action ended 18:08:08: RegisterMIMEInfo. Return value 0.
                                                    Action 18:08:08: WriteRegistryValues. Writing system registry values
                                                    Action start 18:08:08: WriteRegistryValues.
                                                    Action ended 18:08:08: WriteRegistryValues. Return value 1.
                                                    Action 18:08:08: WriteIniValues. Writing INI file values
                                                    Action start 18:08:08: WriteIniValues.
                                                    Action ended 18:08:08: WriteIniValues. Return value 1.
                                                    Action 18:08:08: WriteEnvironmentStrings. Updating environment strings
                                                    Action start 18:08:08: WriteEnvironmentStrings.
                                                    Action ended 18:08:08: WriteEnvironmentStrings. Return value 1.
                                                    Action 18:08:08: RegisterFonts. Registering fonts
                                                    Action start 18:08:08: RegisterFonts.
                                                    Action ended 18:08:08: RegisterFonts. Return value 1.
                                                    Action 18:08:08: InstallODBC. Installing ODBC components
                                                    Action start 18:08:08: InstallODBC.
                                                    Action ended 18:08:08: InstallODBC. Return value 0.
                                                    Action 18:08:08: RegisterTypeLibraries. Registering type libraries
                                                    Action start 18:08:08: RegisterTypeLibraries.
                                                    Action ended 18:08:08: RegisterTypeLibraries. Return value 0.
                                                    Action 18:08:08: SelfRegModules. Registering modules
                                                    Action start 18:08:08: SelfRegModules.
                                                    Action ended 18:08:08: SelfRegModules. Return value 1.
                                                    Action 18:08:08: RegisterComPlus. Registering COM+ Applications and Components
                                                    Action start 18:08:08: RegisterComPlus.
                                                    Action ended 18:08:08: RegisterComPlus. Return value 0.
                                                    Action 18:08:08: InstallServices. Installing new services
                                                    Action start 18:08:08: InstallServices.
                                                    Action ended 18:08:08: InstallServices. Return value 1.
                                                    Action 18:08:08: StartServices. Starting services
                                                    Action start 18:08:08: StartServices.
                                                    Action ended 18:08:08: StartServices. Return value 1.
                                                    Action 18:08:08: RegisterUser. Registering user
                                                    Action start 18:08:08: RegisterUser.
                                                    Action ended 18:08:08: RegisterUser. Return value 0.
                                                    Action 18:08:08: RegisterProduct. Registering product
                                                    Action start 18:08:08: RegisterProduct.
                                                    Registering product
                                                    Action ended 18:08:08: RegisterProduct. Return value 1.
                                                    Action 18:08:08: PublishComponents. Publishing qualified components
                                                    Action start 18:08:08: PublishComponents.
                                                    Action ended 18:08:08: PublishComponents. Return value 0.
                                                    Action 18:08:08: MsiPublishAssemblies. Publishing assembly information
                                                    Action start 18:08:08: MsiPublishAssemblies.
                                                    Action ended 18:08:08: MsiPublishAssemblies. Return value 1.
                                                    Action 18:08:08: PublishFeatures. Publishing product features
                                                    Action start 18:08:08: PublishFeatures.
                                                    Action ended 18:08:08: PublishFeatures. Return value 1.
                                                    Action 18:08:08: PublishProduct. Publishing product information
                                                    Action start 18:08:08: PublishProduct.
                                                    Action ended 18:08:08: PublishProduct. Return value 1.
                                                    Action 18:08:08: InstallFinalize.
                                                    Action start 18:08:08: InstallFinalize.
                                                    [    4904] Mon May 31 18:08:09 2010  INFO
                                                    Message type: 0, Argument: 0
                                                    Action 18:08:09: ProcessComponents. Updating component registration
                                                    Action 18:08:09: RemoveODBC. Removing ODBC components
                                                    Action 18:08:09: InstallFiles. Copying new files
                                                    Action 18:08:09: CreateShortcuts. Creating shortcuts
                                                    Shortcut: ARPPRODUCTICON.exe
                                                    Action 18:08:09: RegisterProduct. Registering product
                                                    240794a.msi
                                                    Action 18:08:09: MsiPublishAssemblies. Publishing assembly information
                                                    Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processor Architecture="amd64",type="win32"
                                                    Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b ",processorArchitecture="amd64",type="win32-policy"
                                                    Action 18:08:09: PublishFeatures. Publishing product features
                                                    Feature: Microsoft_VC90_CRT_x86_
                                                    Action 18:08:09: PublishProduct. Publishing product information
                                                    Action 18:08:09: RollbackCleanup. Removing backup files
                                                    File: C:\Config.Msi\17acca3.rbf
                                                    File: C:\Config.Msi\17acca4.rbf
                                                    Action ended 18:08:09: InstallFinalize. Return value 1.
                                                    Action ended 18:08:09: INSTALL. Return value 1.
                                                    Property(S): UpgradeCode = {54AE2BD2-7685-4215-9490-3BBF14C2BBB4}
                                                    Property(S): SourcedirProduct = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                                                    Property(S): Installed = 2009/03/10 18:02:22
                                                    Property(S): SOURCEDIR = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
                                                    Property(S): Preselected = 1
                                                    Property(S): QFEUpgrade = 1
                                                    Property(S): OriginalDatabase = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
                                                    Property(S): DATABASE = C:\Windows\Installer\17acc9e.msi
                                                    Property(S): Time = 18:08:09
                                                    Property(S): VirtualMemory = 6321
                                                    Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
                                                    Property(S): ProgramFiles64Folder = C:\Program Files\
                                                    Property(S): System64Folder = C:\Windows\system32\
                                                    Property(S): SourceDir = C:\Users\Administrator\Desktop\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
                                                    Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\
                                                    Property(S): payload_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371 c1d4\
                                                    Property(S): payload.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_a17e7c1e\
                                                    Property(S): WinSxsManifests.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Manifests\
                                                    Property(S): WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\
                                                    Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\
                                                    Property(S): policydir.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
                                                    Property(S): policydir_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
                                                    Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_050 6BF31308B = C:\Windows\winsxs\
                                                    Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31 308B = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_3 da38fdebd0e6822\
                                                    Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506 BF31308B = C:\Windows\winsxs\Policies\
                                                    Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF313 08B = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3 e195\
                                                    Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506B F31308B = C:\Windows\
                                                    Property(S): ProductCode = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
                                                    Property(S): ProductName = Microsoft_VC90_CRT_x86_x64
                                                    Property(S): ProductVersion = 1.00.0000
                                                    Property(S): DWUSLINK = CE1C879F4EDBE0A8A9ACB06F8E0B978FAE9CF08F598C9758CE1CB08FFE8CF0C8AE8CF0EF8EAC
                                                    Property(S): MsiLogFileLocation = C:\Users\ADMINI~1\AppData\Local\Temp\MSIaca78.LOG
                                                    Property(S): PRODUCTLANGUAGE = 0
                                                    Property(S): REINSTALLMODE = pvoums
                                                    Property(S): REINSTALL = ALL
                                                    Property(S): ProductState = 5
                                                    Property(S): PackageCode = {EBEBD87C-43F1-4673-9D38-D8BA645AA1C5}
                                                    === Logging stopped: 31/05/2010  18:08:09 ===
                                                    1: 2 2: 0
                                                    1: 2 2: 1
                                                    Installation result: 0
                                                    Third party payload succeded.  Testing return code: 0
                                                    [    1072] Mon May 31 18:08:10 2010  INFO
                                                    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
                                                    :: END TIMER :: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}] took 3021.14 miliseconds (3.02114 seconds) DTR = 34.4241 KBPS (0.0336173 MBPS)
                                                    [    1072] Mon May 31 18:08:11 2010  INFO
                                                    Calling the custom action code for post-install for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64
                                                    Calling the custom action code for pre-install for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593}
                                                    ::START TIMER:: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}]
                                                    [     380] Mon May 31 18:08:11 2010  INFO
                                                    Installer Operation: InstallThirdPartyPayloadOperation
                                                    Installing third party payload
                                                    Third party application path:C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
                                                    CommandLine: -airAppPath AdobeHelp.air -airRuntime AdobeAIRInstaller.exe -eulaAccepted -programMenu -silent
                                                    [     380] Mon May 31 18:08:19 2010  INFO
                                                    Third party payload succeded.  Testing return code: 7
                                                    [    1072] Mon May 31 18:08:19 2010  INFO
                                                    :: END TIMER :: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}] took 8025.49 miliseconds (8.02549 seconds) DTR = 105.165 KBPS (0.1027 MBPS)
                                                    [    1072] Mon May 31 18:08:20 2010  INFO
                                                    Calling the custom action code for post-install for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp
                                                    [    1072] Mon May 31 18:08:20 2010  WARN
                                                    Skipping payload {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 as payload is not cached
                                                    Skipping payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule as payload is not cached
                                                    Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
                                                    Skipping payload {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 as payload is not cached
                                                    Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
                                                    Skipping payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 as payload is not cached
                                                    Skipping payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 as payload is not cached
                                                    Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
                                                    Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
                                                    Skipping payload {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support as payload is not cached
                                                    Skipping payload {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 as payload is not cached
                                                    Skipping payload {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 as payload is not cached
                                                    Skipping payload {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 as payload is not cached
                                                    Skipping payload {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 as payload is not cached
                                                    Skipping payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 as payload is not cached
                                                    Skipping payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 as payload is not cached
                                                    Skipping payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR as payload is not cached
                                                    Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
                                                    Skipping payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player as payload is not cached
                                                    Skipping payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 as payload is not cached
                                                    Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
                                                    Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
                                                    Skipping payload {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 as payload is not cached
                                                    Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
                                                    Skipping payload {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 as payload is not cached
                                                    Skipping payload {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 as payload is not cached
                                                    Skipping payload {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 as payload is not cached
                                                    Skipping payload {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 as payload is not cached
                                                    Skipping payload {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 as payload is not cached
                                                    Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
                                                    Payload {1D830E80-28A4-11DF-A025-0024E8692489} can not be installed due to dependent operation failure.
                                                    Skipping payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB as payload is not cached
                                                    Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
                                                    Skipping payload {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 as payload is not cached
                                                    Skipping payload {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 as payload is not cached
                                                    Skipping payload {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 as payload is not cached
                                                    Skipping payload {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 as payload is not cached
                                                    Skipping payload {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 as payload is not cached
                                                    Skipping payload {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) as payload is not cached
                                                    Skipping payload {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 as payload is not cached
                                                    Skipping payload {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 as payload is not cached
                                                    Skipping payload {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 as payload is not cached
                                                    Calling the custom action code for pre-install for payload {15FEDA5F-141C-4127-8D7E-B962D1742728}
                                                    ::START TIMER:: [Payload Operation :{15FEDA5F-141C-4127-8D7E-B962D1742728}]
                                                    [    4624] Mon May 31 18:08:20 2010  INFO
                                                    Extracting assets complete. Number assets: 2
                                                    Beginning installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Driver\Install.db
                                                    [    4624] Mon May 31 18:08:22 2010  INFO
                                                    Evaluating condition# 1
                                                    Condition passed
                                                    Completing installation for payload at C:\Users\Administrator\Desktop\Adobe CS5\payloads\AdobePhotoshop12-Driver\Install.db
                                                    UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{15FEDA5F-141C-4127-8D7E-B962D1742728}.db
                                                    [    1072] Mon May 31 18:08:23 2010  INFO
                                                    :: END TIMER :: [Payload Operation :{15FEDA5F-141C-4127-8D7E-B962D1742728}] took 3037.4 miliseconds (3.0374 seconds) DTR = 1245.8 KBPS (1.21661 MBPS)
                                                    [    1072] Mon May 31 18:08:24 2010  INFO
                                                    Calling the custom action code for post-install for payload {15FEDA5F-141C-4127-8D7E-B962D1742728} Adobe Photoshop CS5
                                                    [    1072] Mon May 31 18:08:24 2010  WARN
                                                    Skipping payload {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 as payload is not cached
                                                    Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} can not be installed due to dependent operation failure.
                                                    Skipping payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 as payload is not cached
                                                    No operation.  We're done:
                                                    Updating driver data - Action: Remove driver entry
                                                    Updating driver data successful. Driver entry was added. ARP estimated size 278299KB
                                                    [    1072] Mon May 31 18:08:26 2010  INFO
                                                    Successfully installed 6 components:
                                                    - Adobe Photoshop CS5
                                                    - Adobe Player for Embedding
                                                    - AdobeHelp
                                                    - Camera Profiles Installer
                                                    - Microsoft_VC90_CRT_x86_x64
                                                    - AdobeJRE
                                                    Total components repaired: 0
                                                    Total components removed: 0
                                                    [    1072] Mon May 31 18:08:26 2010 ERROR
                                                    The following payload errors were found during install:
                                                    - Adobe CSXS Infrastructure CS5: Install failed
                                                    - Microsoft_VC90_ATL_x86: Install failed
                                                    - Adobe Media Player: Install failed
                                                    - Adobe Linguistics CS5 x64: Install failed
                                                    - Microsoft_VC90_CRT_x86: Install failed
                                                    - Adobe Photoshop CS5 Support: Install failed
                                                    - Adobe Bridge CS5: Install failed
                                                    - Recommended Common Fonts Installation x64: Install failed
                                                    - AdobePDFL x64 CS5: Install failed
                                                    - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
                                                    - Microsoft_VC80_MFCLOC_x86_x64: Install failed
                                                    - Adobe XMP Panels CS5: Install failed
                                                    - Photoshop Camera Raw: Install failed
                                                    - AdobeColorCommonSetCMYK: Install failed
                                                    - Adobe Mini Bridge CS5: Install failed
                                                    - Microsoft_VC80_CRT_x86_x64: Install failed
                                                    - AdobeColorJA CS5: Install failed
                                                    - Adobe ReviewPanel CS5: Install failed
                                                    - Photoshop Camera Raw (64 bit): Install failed
                                                    - Microsoft_VC90_MFC_x86: Install failed
                                                    - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
                                                    - Suite Shared Configuration CS5: Install failed
                                                    - PDF Settings CS5: Install failed
                                                    - DeviceCentral: Failed due to Language Pack installation failure
                                                    - AdobeTypeSupport CS5: Install failed
                                                    - AdobeColorVideoProfilesCS CS5: Install failed
                                                    - AdobeColorCommonSetRGB: Install failed
                                                    - Adobe Player for Embedding x64: Install failed
                                                    - Required Common Fonts Installation x64: Install failed
                                                    - Microsoft_VC90_ATL_x86_x64: Install failed
                                                    - Adobe CSXS Extensions CS5: Install failed
                                                    - Microsoft_VC80_ATL_x86_x64: Install failed
                                                    - AdobeOutputModule: Install failed
                                                    - Microsoft_VC80_CRT_x86: Install failed
                                                    - AdobeCMaps x64 CS5: Install failed
                                                    - AdobeTypeSupport x64 CS5: Install failed
                                                    - Microsoft_VC90_MFC_x86_x64: Install failed
                                                    - Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
                                                    - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
                                                    - AdobeColorEU CS5: Install failed
                                                    - AdobePDFL CS5: Install failed
                                                    - AdobeCMaps CS5: Install failed
                                                    - AdobeColorNA CS5: Install failed
                                                    - Microsoft_VC80_MFC_x86_x64: Install failed
                                                    - Adobe SwitchBoard 2.0: Install failed
                                                    - Microsoft_VC80_MFC_x86: Install failed
                                                    - AdobeColorPhotoshop CS5: Install failed
                                                    - Microsoft_VC80_MFCLOC_x86: Install failed
                                                    - Adobe Extension Manager CS5: Install failed
                                                    - Adobe ExtendScript Toolkit CS5: Install failed
                                                    - Adobe AIR: Install failed
                                                    Call PostSession Custom Hook
                                                    :: END TIMER :: [Total Timer] took 136009 miliseconds (136.009 seconds) DTR = 2084.95 KBPS (2.03608 MBPS)
                                                    -------------------------------------- Summary --------------------------------------
                                                    - 0 fatal error(s), 52 error(s), 51 warning(s)
                                                    WARNING: OS requirements not met for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
                                                    WARNING: Payload cannot be installed due to dependent operation failure
                                                    ERROR: The following payload errors were found during install:
                                                    ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
                                                    ERROR:  - Microsoft_VC90_ATL_x86: Install failed
                                                    ERROR:  - Adobe Media Player: Install failed
                                                    ERROR:  - Adobe Linguistics CS5 x64: Install failed
                                                    ERROR:  - Microsoft_VC90_CRT_x86: Install failed
                                                    ERROR:  - Adobe Photoshop CS5 Support: Install failed
                                                    ERROR:  - Adobe Bridge CS5: Install failed
                                                    ERROR:  - Recommended Common Fonts Installation x64: Install failed
                                                    ERROR:  - AdobePDFL x64 CS5: Install failed
                                                    ERROR:  - DeviceCentral_DeviceCentral3LP-en_GB: Install failed
                                                    ERROR:  - Microsoft_VC80_MFCLOC_x86_x64: Install failed
                                                    ERROR:  - Adobe XMP Panels CS5: Install failed
                                                    ERROR:  - Photoshop Camera Raw: Install failed
                                                    ERROR:  - AdobeColorCommonSetCMYK: Install failed
                                                    ERROR:  - Adobe Mini Bridge CS5: Install failed
                                                    ERROR:  - Microsoft_VC80_CRT_x86_x64: Install failed
                                                    ERROR:  - AdobeColorJA CS5: Install failed
                                                    ERROR:  - Adobe ReviewPanel CS5: Install failed
                                                    ERROR:  - Photoshop Camera Raw (64 bit): Install failed
                                                    ERROR:  - Microsoft_VC90_MFC_x86: Install failed
                                                    ERROR:  - Adobe Photoshop CS5 Core_x64: Failed due to Language Pack installation failure
                                                    ERROR:  - Suite Shared Configuration CS5: Install failed
                                                    ERROR:  - PDF Settings CS5: Install failed
                                                    ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
                                                    ERROR:  - AdobeTypeSupport CS5: Install failed
                                                    ERROR:  - AdobeColorVideoProfilesCS CS5: Install failed
                                                    ERROR:  - AdobeColorCommonSetRGB: Install failed
                                                    ERROR:  - Adobe Player for Embedding x64: Install failed
                                                    ERROR:  - Required Common Fonts Installation x64: Install failed
                                                    ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
                                                    ERROR:  - Adobe CSXS Extensions CS5: Install failed
                                                    ERROR:  - Microsoft_VC80_ATL_x86_x64: Install failed
                                                    ERROR:  - AdobeOutputModule: Install failed
                                                    ERROR:  - Microsoft_VC80_CRT_x86: Install failed
                                                    ERROR:  - AdobeCMaps x64 CS5: Install failed
                                                    ERROR:  - AdobeTypeSupport x64 CS5: Install failed
                                                    ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
                                                    ERROR:  - Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
                                                    ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
                                                    ERROR:  - AdobeColorEU CS5: Install failed
                                                    ERROR:  - AdobePDFL CS5: Install failed
                                                    ERROR:  - AdobeCMaps CS5: Install failed
                                                    ERROR:  - AdobeColorNA CS5: Install failed
                                                    ERROR:  - Microsoft_VC80_MFC_x86_x64: Install failed
                                                    ERROR:  - Adobe SwitchBoard 2.0: Install failed
                                                    ERROR:  - Microsoft_VC80_MFC_x86: Install failed
                                                    ERROR:  - AdobeColorPhotoshop CS5: Install failed
                                                    ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
                                                    ERROR:  - Adobe Extension Manager CS5: Install failed
                                                    ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
                                                    ERROR:  - Adobe AIR: Install failed
                                                    Search the same string above to find when the error occured.
                                                    Exit Code: 6 - Silent workflow completed with errors
                                                    END - Installer Session
                                                    • 23. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                      dec9 Community Member
                                                      Yes, right click on the .exe file (it is the installer) and choose run as Admin. But since you already tried that........... I just wanted to make sure you did as it was unclear to me.
                                                      So,
                                                      Is PS CS5 off of a disk? The disk may be defective (not the first time that has happened). Try downloading the trial version to see if that will work. All you have to do is put in the serial number to install.
                                                      Download the Trial in a folder on your desk top. There are 2 files in that folder. Right click on the .exe file in that folder. Another folder will be made with some extracted files. Open this folder and right click on the .exe file and choose run as Admin. PS will start to install.
                                                      Or: if this is a download try re-down loading. There have been lots of times where the download is corrupt for whatever reasons.
                                                      If you have already tried this then disregard.
                                                      • 24. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                        maltar7 Community Member
                                                        Thanks so much i have sucsefuly installed photoshop cs5 throught your private message guidlines
                                                        • 25. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                          I have now succefuly installed photoshop cs5
                                                          • 26. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                            This is how i did it
                                                            To find the Complete installer log which can  be found at
                                                            <drive>\Program  Files\Common Files\Adobe\Installer      ---> if you are on 32 bit
                                                            else at  <drive>\Program Files (x86)\Common Files\Adobe\Installers    ---> If you are on 64 bit
                                                            Then go to this website http://go.adobe.com/kb/ts_kb404622_en-us,
                                                            • 28. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
                                                              p_c_e Employee Hosts
                                                              That's nice. The complete logs are the first place to start with for any such troubleshooting.
                                                              Enjoy !
                                                              • 29. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Bill Hunt CommunityMVP
        Good. I just wanted to make sure that there was not something amiss early on.
        Good luck,
        Hunt
        • 30. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Good news and thanks for posting your steps.
        Hunt
        • 31. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Post a message in the forum if this worked for you?
        • 32. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Thank you all for your help guys?
        • 34. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Guys have any of you had a problem with content aware fill?
        When i use this to remove a certain object, the result is left blury.
        How come on youtube and in the press conference the rusults were really good?
        Mabye they have a better system with more ram, but i have 4gigs of ram that should be enought?
        • 35. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Noel Carboni Community Member
        The results are image dependent, and of COURSE they're going to show off really good results.  Would you think they would show the bad ones?  Clearly they tried it on each of their images and saw that it came out good before recording the podcast.
        -Noel
        • 36. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        Oh ok
        But my qwestion was to do with the computer?
        Say if i had 8GB of ram and 3GHz processor, and then i had a 4GB and a 2.5GHz processor.
        Would the 8GB system when using content aware fill perform and produce better results than the 4GB system?
        • 37. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        keenox Community Member
        i don't think the system hardware affects anything but the speed of the operation.
        • 38. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        KimRich2010 Community Member
        Hi Guys,
        Sorry but I am at my wits' end. I have tried for several hours to install Photoshop CS5 on my PC. I am running a Windows7 64 bit system. I have bounced from page to page on the Adobe web in a desperate attempt to get help. I rang Adobe support from my works and was advised they could only offer assistance between 9am & 5pm monday to friday. I work 9am to 5pm monday to friday, so dont' stand a snowballs chance in hell of getting assitance there.
        You guys are my only hope of finally cracking this nut.
        What I have done so far:
        1. uninstalled the failed attempt of CS5 installation.
        2. downloaded the Adope CS5 cleaner tool for Windows.
        3. ran the cleaner as described on the adobe website.
        4. made sure there wasn't any reference in the add/remove program listings
        5. Verified that the Adobe CS5 cleaner tool was completed successfully by finding the 'adobe cs5 cleaner tool.log and checking for any failed records. Cleaner was successful
        6. rebooted my pc.
        7. before attempting another installation, i brought up the task manager and under the processes tab, I clicked on 'show processes from all users' then clicked end process.
        8. tried to install again. FAILED! advised to download Adobe Setup Advisor.
        9. I ran the Adobe setup advisor which stated: spsid_83570: Conflicting processes 06/16/2010 22:51:46 running while installing - creative suite 5. click here to read the Knowledge base article.
        10. I found this forum and this thread, and after reading though, I realise I'm going to need a step by step to get this sorted.
        The comment below gave me the push to beg, plead and grovel for assistance:
        So please can someone be really kind & generous to help me. otherwise I've got nothing better than a very expensive coaster with Adobe CS5 on it.
        Thanks in advance.
        • 39. Re: Photoshop CS5 Install Help Please !!!!!!!!!!!
        The information you wrote is a little confusing: At the top you wrote PS CS5 but further down you wrote Creative Suite 5. What product is it? If it is Creative Suite 5 you will have better luck in that forum.
        http://forums.adobe.com/community/creativesuites/creativesuites_windows
        1 2 Previous Next
