hi friends,
i got error this program
lo.cfc
cfcomponent>
<cffunction name="logon1" access="remote" returntype="Any" >
<cfargument name="from_where" type="string" required="true" >
<cfset form.from_where=from_where>
<cfparam name="client.sec_user_id" default="">
<cfparam name="client.org_focus" default="">
<cfquery name="close_record" Datasource="#request.ds.auth#">
UPDATE logon_activity_track
SET record_closed = 1
WHERE (cfid = '#client.cfid#:#client.cftoken#' and
app = '#application.applicationname#' and
sec_user_id = #val(client.sec_user_id)# and
sec_organization_id = #val(client.org_focus)# and
def_system_id = #application.sys.def_system_id# and
record_closed = 0)
</cfquery>
<cfset client.vl = "">
<cfset client.suag = "">
<cfset client.sec_user_id = "">
<cfset client.sec_organization_id = "">
<cfset w = structdelete(session,"ap")>
</cffunction>
</cfcomponent>
result2.cfm
<cfobject name="TestObject1" component="IST_Business_Applications.IST_Docstor.file_access.lo" >
<cfset a=TestObject1.logon1("logout")>
<cfoutput >
#a#
</cfoutput>
i got undefined a error is coming
anybody give solution
Your function doesn't return anything, so - indeed - your variable "a" will be undefined.
I think you should read up on code encapsulation, btw. You're using an awful lot of external variables in the function, which is pretty poor practice. Other than in extreme circumstances, a function should only deal with variables it has passed in as arguments, and other variables in itself creates. It should not access external variables (like stuff in the client, session, form and request scope, like you're doing).
You should also parametrise your query, rather than hard-coding your variables into it.
Adam
I think Adam is talking about doing something like this, which is more in line with best programing practices. It's also a good idea to name-scope your variables within the component:
o.cfc
cfcomponent>
<cffunction name="logon1" access="remote" returntype="struct" >
<cfargument name="varsClient" type="struct" required="true" >
<cfargument name="appName" type="struct" required="true" >
<cfset loStruct = structNew()>
<cfparam name="loStruct.sec_user_id" default="">
<cfparam name="loStruct.org_focus" default="">
WHERE (cfid = '#arguments.varsClient.cfid#:#arguments.varsClient.cftoken#' and
app = '#arguments.appname#' and
sec_user_id = #val(arguments.varsClient.sec_user_id)# and
sec_organization_id = #val(arguments..varsClient.org_focus)# and
record_closed = 0)
</cfquery>
<cfset arguments.varsClient.vl = "">
<cfset arguments.varsClient.suag = "">
<cfset arguments.varsClient.sec_user_id = "">
<cfset arguments.varsClient.sec_organization_id = "">
<cfreturn varsClient />
</cffunction>
</cfcomponent>
result2.cfm
<cfset a=TestObject1.logon1("logout", varsClient = client, appName = application.applicationName)>
<cfdump var="#a#">
Yeah, something along those lines. lthough make sure you VAR scope your local variables in your function, ie: loStruct and close_record.
That said, close_record is actually redundant here, because UPDATE queries don't return anything. One might as well not bother specifying a NAME attribute in these cases.
Adam
Good point on everything....
Just one question from me: I've always wondered the benefits of using the VAR scope in the component.
What is the main reason for doing that?
Thanks.
Spider:
The VAR kewyword is used in any UDF – not just in CFCs – to make that variable local to the function being defined. This avoids name interference when you have a variable with the same name in the template using the UDF.
Note that you have to give these VARs a value, e.g. there must be a = in there. This
<cfset var someName> is not valid. You can do
<cfset var someName = “”>
and later in the function change that “” to a real value.
HTH,
Carlos
Spider, you may want to check out this blog entry, which points to several resources that address your very question ("why should I worry about VAR scoping?"):
The Ultimate Var Scope Resource list? Understanding/resolving problems with the var scope in CFML
http://www.carehart.org/blog/client/index.cfm/2010/3/4/resources_on_the_var_scope_problem
That said, none of this thread has been about CFBuilder, specifically.
To @welcomecan, your question really should have been directed to the general Adobe CF support forum (http://forums.adobe.com/community/coldfusion/coldfusion_general). FWIW, there are still others as well, which I point out it here:
CFML Lists and Forums (finding help and support)
http://www.cf411.com/#cflists
Hope that's helpful.
/charlie
Thanks for the link to this page... it is VERY useful. Looking at some of those articles, I can see what might be causing some mysterious CFTHREAD issues... good stuff.
hi spider,
Thanks for ur reply.i used that program . now i got a error this line.
Invalid CFML construct found
give solution.
regards
welcomecanv
Please try explicitly naming all the variables being passed into the CFC:
For example,
<cfset a=TestObject1.logon1( variableName = "logout", varsClient = client, appName = application.applicationName)
