2 Replies Latest reply on May 31, 2010 10:18 PM by Dajji
    Line series Array Collection
    194642537
      Hi i am building a line chart.
      public var expenses:ArrayCollection = new ArrayCollection([
              {Month:"Jan", Profit:2000, Expenses:1500, Amount:450},
              {Month:"Feb", Profit:1000, Expenses:200, Amount:600},
              {Month:"Mar", Profit:1500, Expenses:500, Amount:300}
      In my case i do not know what will be the names (in this case Month , Profit )
      So how do i build me arraycollection without know the labels
        • 1. Re: Line series Array Collection
          BhaskerChari Level 4
          Is your problem is about how to populate the ArrayCollection or about assigning the datafields to the LineSeries...dynamically?
          Bhasker Chari
          • 2. Re: Line series Array Collection
            Dajji
            How will you get the data for your chart? Is it going to be an xml? With this assumption, I am quoting an example with xml here.
            Suppose you get the following xml.
            var x:XML = new XML(<root>
                 <items>
                      <item meta="month">Jan</item>
                      <item meta="profit">2000</item>
                      <item meta="expenses">1500</item>
                      <item meta="amount">450</item>
                 </items>
                 <items>
                      <item meta="month">Feb</item>
                      <item meta="profit">1000</item>
                      <item meta="expenses">200</item>
                      <item meta="amount">600</item>
                 </items>
            </root>);
            Now you need to convert this to ArrayCollection.
            public var expenses:ArrayCollection = new ArrayCollection();
            for each(var items:XML in x.children()){
                 var obj:Object = new Object();
                 for each(var item:XML in items.children()){
                      obj[item.meta] = item.text();
                 expenses.addItem(obj);
