Locked
Error Connecting to ColdFusion Data Service
May 14, 2010 May 14, 2010
I'm completely new to ColdFusion and Flash Builder (I've done some work with Flex 2 a while back) so forgive me if my terminology is not the best.
I have installed ColdFusion 9 locally and have Flash Builder 4 installed with Coldfusion Builder as a plug-in. Eeverything seems to be up and running correctly. I have several CFC files which I am trying to connect to as a data service however each one is returning the following error...
"The CFC file is invalid. Possible causes can be found by accessing:http//localhost:8500/.../CFIDE/componentutils/cgcexplorer.cfc?method=getCFCMetaData&name=cfcfile&path=/..."
One of the CFC files I copied direct from here just as a test http://help.adobe.com/en_US/Flex/4.0/FlexTutorials/WSbde04e3d3e6474c44e9f0a921210cbd7a14-8000.html
So I am assuming it's not an issue with the CFC file but a possible serve configuration error?
Any help would be much appreciated,
Mike.
761
Guest
Jun 01, 2010 Jun 01, 2010
did u try pasting the URL in the browser. could u tell me what result you got.
Nishad
I deleted the project and started again and it worked fine. Must have gotten corupt somewhere along the line.
Cheers anyway.
Mar 09, 2011 Mar 09, 2011
I have the same error but I know why I'm getting it:
If I create a project in the webroot: http://localhost (where /CFIDE resides) it create the data service as expected
However, when I create it in a different folder: http://localhost/test it throws an error:
http://localhost/test/CFIDE/componentutils/cfcexplorer.cfc?method=getCFCMetaData&name=users&path=%2Fcfc%2Fusers.cfc
Where can I edit this behavior? so it will always look for CFIDE in the root?
In my Coldfusion Admin it is set to /CFIDE
I would think this is a Flash Builder issue.
Ok I figured out the problem.
When creating a new project in flash builder, the first screen dictates where I'm putting my files:
E:\sites\test
on the 2nd screen (Configure Coldfusion Server) I had previously made the Web Root and Root URL
E:\sites\test
when they should have been:
E:\sites
http://localhost
Now when I create a data service... it all works in harmony.
