Hello all,
I have a form with several pages. The first page contains a number of drop down lists. These drop down lists, when an option is chosen, is to populate a text field on another page. I can get the drop down list to populate the text field when it is on the same page, but as soon as I move the text field to another page, the script doesn't work. Can anyone offer a solution? I've used javascript on change for the scripts.
Solved! Go to Solution.
Total Likes
When ever you reference the other object ...so I am assuming in the code that is on the DDlist.
Paul
Total Likes
You woudl have to include the full path to the object .....something like Page#.subformName.objectName
Paul
Total Likes
Thanks for this, so far. Where in the script do I need to include the full path?
Nellie
Total Likes
Paul
Total Likes
Thank you! I was able to populate the text field on the third page from the drop down field on page 2.
Total Likes
Thanks Paul,
I have been able to solve the drop down list question, thanks to your help.
I have another question that involves locking specific fields in a four page form which contains approximately 100 fields that need to be locked before the end user completes the remaining fields. How do I lock individual subforms so that the remaining fields remain open and editable? The final version of the form, will have at least 200 fields in it that will also need to be locked in sections.
I can lock all the fields using the lock all fields button, but have been unable to make it work for just part of the form.
I've emailed the draft form. It would be really helpful if I had one example of a locked subform on the form I'm struggling with.
Thanks for your help.
Nellie
Total Likes
I have not recieved that message yet but the call to the function LockAllFields has a parameter that is passed to it. If you put the path to the subform in there then it will only lock the fields that are part ofthat subform. So the call woudl look something like this:
myScriptObject.LockAllFields(form1.Page1.subform1);
This woudl lock only the fields in subform1 on Page1 in form1.
If you need to lock down more than 1 subform you can call the scripting object again passing the second subform you want to lock
Hope that helps
paul
Total Likes
Hi Paul,
I've tried this, but seem to have misunderstood exactly how this works. Do all the subforms have to sit outside of any other forms?
If you don't mind having a look at the form I sent you, this may help to solve my problem.
Nellie
Total Likes
I did not recieve anything on this topic ..where did you send it?
Paul
Total Likes
Hello Paul,
Maybe I should resend the sample form. What email address do you suggest?
Nellie
Total Likes
Send it to LiveCycle8@gmail.com
Paul
Total Likes
Hello Paul,
I've sent a sample form to the livecycle address, as you suggested.
Thanks.
Total Likes
